Old 01-23-2013, 02:18 PM   #71
SanDiegoFRS
SanDiegoFRS's Avatar
Drives: 86, Santa Fe, bicycle, sailboat
STI wing is bad-ass. It makes it a STI and not a WRX imo. (addditional HP and parts aside)
SanDiegoFRS is offline   Reply With Quote
Old 01-24-2013, 10:49 AM   #72
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Originally Posted by pkny View Post
According to the offical Toyota press releases, the GT86 in Europe has the same front spring rate as the FR-S.
From the offical Toyota EU press kit:
"The GT86’s 23 N/mm front spring rates allow for slight body roll on initial turn-in, creating the perfect relationship between steering feel and vehicle behaviour exhibited by a classic front-engined, rear-drive platform"
From the offical Toytoa UK's press pack:
"The 23N/mm front spring rates allow for slight body roll on initial turn-in, creating the kind of perfect relationship between steering feel and vehicle behaviour shown by classic front-engine/rear-drive platforms."
Does anyone has a source showing the OEM Toyota spring rate is F3.0k and R3.3K? I could not find anything except the Wingsofwar's thread or the thread that refer to his thread.
Huh?? Your quotes say NOTHING about the FRS spring rates relative to the Euro or UK GT86, they just prove the Euro and UK versions of the GT86 are identical. I was never claiming otherwise.
Sport-Tech is offline   Reply With Quote
The Following User Says Thank You to Sport-Tech For This Useful Post:
Mango22 (01-30-2013)
Old 01-24-2013, 11:12 AM   #73
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Originally Posted by Enemies View Post
Interesting. Does that mean because of the springs, that the BRZ handles more like the GT86 than the FR-S does?
Given the F/R spring rate differences from that table (shown below):
OEM Toyota 86 3.0k / 3.3k
OEM Scion FR-S M/T 2.3k / 3.8k
OEM Subaru BRZ M/T 2.7k / 3.5k
And assuming no other significant differences in suspension setup (shock rates, sway bars), then
Level of oversteer: FR-S > BRZ > 86.
BRZ is a little closer in setup to the 86 than to the FR-S (.4 spring rate difference F and R vs FR-S; .3 difference F and R vs 86) so should handle a bit more like the 86.
That's a big difference in rates between the FR-S and the GT86 - going from a .3 difference front to rear to a 1.2 difference, a value four times higher - so the takeaway is that UK and Euro reviews of the 86's handling have very little relevance for the NA market.
What is not made explicit is whether the Euro and UK versions of the 86 have different spring rates from the JDM 86, although WoW's table lacks separate entries for these versions which suggests they don't. And we are still missing the shock rate piece; differences across the three models in that parameter could shift the understeer/oversteer balance somewhat.
Old 01-24-2013, 12:00 PM   #74
GNS
Drives: .
STI wing is factory rice. Tasteless and extroverted.
GNS is offline   Reply With Quote
Old 01-24-2013, 06:16 PM   #75
pkny
Drives: Firestorm FR-S 6MT
The front spring rate are the same across all of the JDM 86, EU GT86, UK GT 86, and FR-S.
JDM 86 -- See the Japanese Toyota 86 Product Notes (On the upper right look for the words "フロントスプリング (front spring)" and "23 N/mm"
Originally Posted by DarrenDriven View Post
EU and UK GT86 -- See my previous post.
FR-S -- See the Eibach Pro kit pdf.
2013 Scion Firestorm FR-S MT
pkny is offline   Reply With Quote
Old 01-25-2013, 02:36 AM   #76
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Should have added this reference at the start and saved a lot of confusion! So either WoW or Eibach is wrong, it's still inconclusive without official FR-S specs available. Eibach numbers are probably right but it would be good to nail it down. Wonder what WoW's source was?
Looks like that Eibach Pro kit would be a literal PITA in a daily driver!
Old 01-26-2013, 05:27 AM   #77
pkny
WoW (or the OP, DarrenDriven) got the FR-S and BRZ spring rate values from Eibach. See the post#72 in that thread.
Do you know the values are in different units? 23 N/mm = 2.3 kg/mm w/ rounding.
Old 01-26-2013, 06:26 AM   #78
ryn004
Drives: BMW E46
Pics of the show to be aired next sunday: http://www.carsaddiction.com/article...nce-experience
ryn004 is offline   Reply With Quote
Old 01-27-2013, 02:09 AM   #79
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
WoW (or the OP, DarrenDriven) got the FR-S and BRZ spring rate values from Eibach. ...Do you know the values are in different units? 23 N/mm = 2.3 kg/mm w/ rounding.
I was only looking at the relative spring rate ratios, which removes the issue of the different units used (assuming both units are linear). If the Eibach FR-S and BRZ rate data are correct then the GT86 rate data in the WoW/DarrenDriven table is wildly off, given that the GT86 value for the front spring rate shown in the Toyota PR materials you quoted matches the Eibach FR-S front value and is (presumably) accurate (but note that no value is given in the Toyota PR kit for the GT86 rear rate) .
TL;DR: That spring rate FAQ table really needs to be fixed!
Old 01-27-2013, 05:36 AM   #80
Enemies
Drives: '13 SWP Sport-Tech (Limited)
I wonder whose job it is to go through the audience and pick out hot girls and put them at the front. :P
Enemies is offline   Reply With Quote
Old 01-27-2013, 04:42 PM   #81
pkny
Talked to WoW about 2 weeks ago. He said the values of the 86 spring rate were from a brochure, but the values were never confirmed. He said he would update the table.
Given the front spring rate of FR-S and 86 are the same and the 86's more tail-happy characteristic from all the 86 vs BRZ reviews, it is very likely the rear spring rate of 86 is very close to FR-S if they are not the same.
The Following User Says Thank You to pkny For This Useful Post:
WingsofWar (01-27-2013)
Old 01-27-2013, 04:49 PM   #82
was385
Drives: MT WRB BRZ Limited, 2007 911s
The ricey wing on the Limited doesn't do it for me, so I'll vote for the Premium... wish they had a wing delete option.
I understand if you don't like the spoiler on the limited, that's a matter of preference, but ricey? That wing is the furthest thing from ricey I can imagine. It's incredibly understated and subtle.
was385 is offline   Reply With Quote
Old 01-27-2013, 05:14 PM   #83
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
I am going to have to make some calls to get some facts straight... the table its maybe 95% accurate to most of its standings so its not like you can't trust it.
Sorry for any confusions to anyone looking at the tables and trying to interpret the other mixed information.
I should have some OFFICIAL word about the factory spring rates made available for our cars internationally soon.
WingsofWar is offline   Reply With Quote
The Following 4 Users Say Thank You to WingsofWar For This Useful Post:
Fly Guy (01-30-2013), Mango22 (01-30-2013), pkny (01-27-2013), Sport-Tech (01-30-2013)
Old 01-30-2013, 02:34 AM   #84
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Certainly there are ricier ones out there, that's for sure, but I find the raised "flutes" or whatever you want to call them along the top surface and above the mounting points unneeded detailing that adds "riciness". Also the shape of the ends appears overdone.
One caveat: I have yet to see one IRL, BRZs with spoilers are rare around here - I may have to go to a meet just to see one as dealers don't have them.
I'd prefer this - even though it's a bit more prominent, it is more "plain-speaking" and its curves better fit the character of the car's body:
Dadhawk (01-30-2013)
Jeremy Clarkson names GT86 car of the year in Top Gear 2012 Awards! Panda Grahams Scion FR-S / Toyota 86 GT86 General Forum 60 01-03-2013 01:35 AM
GT86 vs RCZ vs Scirocco vs Genesis Coupé rick FR-S / BRZ vs.... 12 12-26-2012 10:19 AM
gt86 vs mini coupe JCW vs peugeot rcz EvoTME FR-S / BRZ vs.... 2 12-25-2012 11:19 AM
Top gear name 86 as best car of the year Ryan86 AFRICA 4 12-19-2012 09:43 AM
Winding Road Comparo: Hyundai Genesis Coupe 2.0T R-Spec vs. Scion FR-S vs. Subaru BRZ DjDATZ Scion FR-S / Toyota 86 GT86 General Forum 26 08-22-2012 07:45 PM
