06-06-2015, 09:10 AM | #71 |
Drives: 2014 Subaru BRZ
I had similar problems. I found that a second person with a small lever or crowbar at the rear of the transmission to provide the forward force while wiggling worked well. I used a shop towel to protect metal surfaces.
06-06-2015, 09:45 AM | #72 |
Drives: 2013 BRZ Premium Dark Gray Metallic
when the car is hot it's hard to go on 1st gear
Installed a ACT 3 days ago, my issue is when the car is hot it's hard to go on 1st gear and really very hard to get in reverse. Everything normal when cold. Can go on all gears with car off. I'm thinking I really need to mess around more with the clutch pedal. Any input guys? I also bleed the SC many times already.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler |
06-06-2015, 10:03 AM | #73 |
I have an ACT also. It took about 500 miles before it stopped dragging and making it difficult to engage all lower gears. Adjusting the pedal helped a bit, but not much. After the first 500 things are fine apart from the chatter from the light flywheel.
06-10-2015, 07:19 PM | #74 | |
Sent from my SM-N900T using Tapatalk
12-25-2015, 06:37 PM | #75 |
Drives: None
This may be a dumb question, but is it necessary to remove the shifter? I removed all the screws and plastic prices getting it ready for tomorrow and am just wondering if I really need to take out the pin and bar that holds the shifter in place. I can't just bring it down like that?
Sent from my LG-D850 using Tapatalk |
12-29-2015, 02:24 AM | #76 | |
Drives: DGM BRZ limited
I am just now finishing up my clutch swap, and if I were to do it again, I wouldn't touch the shifter from inside, I'd just remove the pin from under the car after I removed the driveshaft. With the pin being under the level of the sheet metal, there seems to be better access from under anyway. If it weren't for the driveshaft being removed already, maybe I'd consider it worth the time to remove the shifter from above. |
12-29-2015, 11:55 PM | #77 | |
Drives: None
Am I doing something wrong? Am I suppose to move the flywheel until the transmission's nose fits into the clutch disc? Sent from my LG-D850 using Tapatalk |
12-30-2015, 12:00 AM | #78 | |
Drives:
That or wiggle the trans until the spline shaft slides it smooth. If it's not sliding in smoothly then the splines on the clutch disc and shaft are not aligned. I have a transmission jack adaptor for a floor jack you can use if you like. The brz trans is lite enough to get under it and shimmy it in. Sent from my iPhone using Tapatalk |
12-30-2015, 12:03 AM | #79 | |
Drives: None
12-30-2015, 12:06 AM | #80 | |
Drives:
You may need to play with both the Angel of the motor and trans to mate the 2. Pay close attention to the guide pins. They will tell you when you're straight and true.then all you need to do is turn the fly wheel a bit to align the teeth. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to 08stiguy For This Useful Post: | Astroboy (12-30-2015) |
12-30-2015, 12:09 AM | #81 | |
Drives: None
12-30-2015, 12:11 AM | #82 | |
Drives:
Correct. Other wise you risk damaging the clutch disc. Just wiggling the trans should get the teeth to align. Sent from my iPhone using Tapatalk |
12-30-2015, 01:07 AM | #83 | |
It might take awhile of jiggling and screwing around, but it will eventually go in. Mine took maybe 3 minutes of screwing around, not including breaks. |
The Following User Says Thank You to rusty959 For This Useful Post: | Astroboy (12-30-2015) |
12-30-2015, 07:16 PM | #84 | |
Drives: None
The Following User Says Thank You to Astroboy For This Useful Post: | Killianti (12-30-2015) |
Similar Threads | ||||
Clutch engagement issue. Possible clutch cylinders upgrade? | wu_dot_com | Engine, Exhaust, Transmission | 42 | 04-05-2016 12:11 PM |
Chase Bays Clutch Line, Full Replacement | Chase Bays | Transmission and Driveline | 1 | 02-11-2013 02:57 PM |
Clutch/flywheel replacement? | bucket | BRZ First-Gen (2012+) -- General Topics | 1 | 11-19-2012 12:25 PM |
Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 12:22 PM |
Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 12:06 PM |
