Old 01-19-2013, 08:22 PM   #71
cruzinbill
Drives: Argento 6spd FR-S
Originally Posted by lbroskee View Post
Y is it not possible for just a box? I already have a sub from my old car, just need a box to fit this car
They dont sell stealth boxes alone, if its a ported box I doubt it will be tuned for the sub you have. If its sealed it still doesnt mean it would be optimal for it.
Thats why they sell it as a set, so that you actually get somthin that sounds good.
cruzinbill is offline   Reply With Quote
Old 01-19-2013, 08:40 PM   #72
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
O ok that makes sense, didnt know the subs made much of a difference also
lbroskee is offline   Reply With Quote
Old 01-19-2013, 08:41 PM   #73
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
It also uses the new Tw3 10" shallow sub, it's probable that not many other subs would even fit unless they were very shallow too. There was a company selling corner boxes but somebody mentioned them not using a mdf ring to mount the sub which is not recommended.
JoeBoxer is offline   Reply With Quote
Old 01-19-2013, 09:20 PM   #74
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
if a box is all you want though, you can get this: http://www.ft86club.com/forums/showthread.php?t=7373
mezdup is offline   Reply With Quote
Old 01-19-2013, 09:27 PM   #75
lbroskee
lbroskee's Avatar
Naw, now that i know the dif its time to get something newer and higher quality
Old 01-20-2013, 09:18 AM   #76
JoeBoxer
JoeBoxer's Avatar
If you guys need amps too let me know if you just want a mono to power it or the jl xd500/3 so you can run some components up front also. I'm sure the more we get the better discount they will give me.
Old 01-20-2013, 11:15 AM   #77
lbroskee
lbroskee's Avatar
can u sub up to the stock amp or do u run str8 to the HU? i haven't looked at the stock amp bc truck is always full of crap
Old 01-20-2013, 11:24 AM   #78
JoeBoxer
JoeBoxer's Avatar
The stock amp powers the door speakers, you will have to add an amp to go with the stealthbox also.
Old 01-20-2013, 11:25 AM   #79
lbroskee
lbroskee's Avatar
or u can jus get a new amp that will power both, correct?
Old 01-20-2013, 12:03 PM   #80
JoeBoxer
JoeBoxer's Avatar
Yeah you can add a mono amp to power the stealthbox or add a 3 or 5 channel amp to power the stealthbox and front component speakers. You could power the factory speakers with an aftermarket amp if you wanted to though, I think the door speakers are 2ohm so you would have to be careful.
Old 01-20-2013, 12:48 PM   #81
rbizzle004
I wouldn't mind adding a mono amp and maybe some C5-650's.
rbizzle004 is offline   Reply With Quote
Old 01-20-2013, 02:17 PM   #82
JoeBoxer
JoeBoxer's Avatar
Here are the JL amps that are available and what their pricing is on JL's website just to give you guys an idea hopefully we can do quite a bit better.
JX250/1 $199
http://www.jlaudio.com/jx250-1-car-a...plifiers-99398
XD300/1 $299
http://www.jlaudio.com/xd300-1-car-a...plifiers-98266
or my suggestion if you plan on adding some components
XD500/3 $419
http://www.jlaudio.com/xd500-3-car-a...plifiers-98267
A little over $100 more or maybe right at it with a discount and you get 2 channels to power some front components or coaxials. The XD200/2 would cost you another $300 if you wanted to add it later to amp the front stage and you would have to wire 2 amps instead of one.
Components
C2-650 $249
http://www.jlaudio.com/c2-650-car-au...-systems-99617
C3-650 $429
http://www.jlaudio.com/c3-650-car-au...-systems-99022
C5-650 $499
http://www.jlaudio.com/c5-650-car-au...-systems-99104
Old 01-20-2013, 03:26 PM   #83
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Originally Posted by JoeBoxer View Post
Morel and Hybrid are both excellent, if i had $900 for speakers i'd get the Morel Virtus 3 way but i'm not spending that much on speakers for this car.
I got a 2-way set or Morel Elites, used, but in great shape for $500. Just gotta hunt around.
michaelahess is offline   Reply With Quote
Old 01-20-2013, 04:46 PM   #84
JoeBoxer
JoeBoxer's Avatar
There is a new set of those morel 3 ways on eBay for 600, probably no warranty but I wish I had it to get them.
Wheel Directory: XXR 527 18x8.75 +35 Bmore_Raven86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 06-11-2016 02:40 PM
Stealth Bulbs? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 27 05-11-2016 08:06 PM
FR-S Audio Build - SQ (Illusion Audio/Mosconi) DekaMori Electronics | Audio | NAV | Infotainment 28 04-17-2013 04:34 AM
Stealth bulb for side marker? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 9 12-05-2012 06:02 PM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 09:45 PM
