Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 11-07-2013, 12:02 PM   #71
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
Here is another option for you guys
ISC Suspension has just announced the release of their N1 coilover suspension systems for the Scion FR-S/Subaru BRZ. Pricing is $955 Installed or FREE SHIPPING anywhere in the lower 48.
ISC N1 Features
2000R Certified, ARTC Certified 5 Year Limited Warranty: All service, rebuilds and warranty support are done here at ISC's USA facility. All custom coilover orders are hand assembled in ISC's New Hampshire location. ISC's goal is to have the best customer service in the industry.
32 Step Damper Adjustable:
Rebound/ Compression adjusted in unison via 32 step adjustment.
Pillowball Upper mounts:
For optimal performance Pillowball Upper mounts are a great feature. ISC Coilovers include pillowball upper mounts on all N1's.
Thrust Bearing Kit:
Thrust Bearing upgrades are included on all N1 ISC coilovers. This helps eliminate the chance of spring bind; a common side effect of running aftermarket coilovers.
Front Camber Plates:
FR-S/BRZ ISC N1's come with front adjustable camber plates standard.
Piston Rod Design:
High rigidity steel piston rods meet with race/sport standards. Shafts are valved according to the spring rate you choose. A Shock Dyno is used to ensure quality and consistent results.
Single Cylinder Design:
Larger cylinder and piston design to advance driving stability and dexterity. Mono-Tube damper with high pressure nitrogen.
Sports Spring:
Made from high quality SAE9254 steel Dyno tested over 500,000 times on compression inspection with less than 5% deformation.
PrimeMotoring is offline   Reply With Quote
Old 11-07-2013, 12:08 PM   #72
PrimeMotoring
Another option for everyone to consider
Tanabe Concept G: Scion FRS & Subaru BRZ - $655.50 w/FREE INSTALLATION
Tanabe USA has announced the release of their Concept G for the Scion FRS & Subaru BRZ.
CONCEPT G is a motorsports-developed exhaust system that features high power benefits, while maintaining responsible sound levels.
Using the all new 'continuous strand' ADVANTEX packing material technology, CONCEPT G acheives extremely high levels of exhaust system efficiency, while maintaining a street driveable, extremely clean sound output that is under 93db.
The full SUS304 stainless CONCEPT G is designed for optimal pipe routing as well as ground clearance. It's sporty appearance and angle-cut tip is ideal for the sports car & sport compact driver.
Part #: T80166R* Exhaust System Weight: 22 lbs (Factory Exhaust System Weight: 40 lbs)
Old 11-09-2013, 12:54 PM   #73
PrimeMotoring
Hey guys, make sure to follow us on either Instagram @primemotoring or Facebook at www.facebook.com/primemotoring
Old 11-18-2013, 04:49 PM   #74
PrimeMotoring
Lets get this party started with this Ferrari 360 Spyder. One of three 6-Speed Grigio Titanio Spyder's in the country and the owner was kind enough to trust us with fixing his fenders after a nasty dip had his wheels "bacon" them. Lets just say we saved him a BIG bill and was very happy with the results.
Before...
After...
Tightened up the handling on this Evo X GSR with H&R Sport Springs
GR WRX Hatch feeling like a new car thanks to a Cobb V3 Accesport, Invidia Turboback Exhaust, Cobb Intake and upgraded Perrin Top Mount
Intercooler
Customer with a B6 Audi A4 came to us with cold air blowing instead of his heat. Diagnosed the problem as a clogged Heater Core...check out the nastiness that was blocking the flow of coolant.
New Heater core in place and in time for cold winter days!
Brand new MK6 GTI left the dealer lot right to us to get Automatic Lights installed
HID Fog Lights on this GR WRX Sedan
Some custom powder coated parts for a customer's 190E 2.3 16v Cosworth
BMW 335 shredded its serpentine belt which wrapped around the crank pulley and blew out the front main seal causing a massive oil leak. Very scary!
Another Evo X came in for an AMS Widemouth Downpipe
Jazz Blue Driver's Edition MK3 GTI ready to go another 150k miles with all new Timing Chains and Clutch/Flywheel Combo
Broken chain guide next to a new one...
All new chains and guides are in, no more rattling noises!
BMW 335 #2 for 3" Catless Downpipes
BMW 335 #3 getting a new oil pan gasket
Old 11-20-2013, 03:38 PM   #75
PrimeMotoring
Black Friday is fast approaching...more specials will be announced next week!
Old 11-20-2013, 03:39 PM   #76
PrimeMotoring
Old 12-03-2013, 12:12 PM   #77
PrimeMotoring
Our Mustang AWD150 Dyno is up and running everyone! So anyone looking for Dyno pulls or simply the best tuning available for the FA20, please contact us and schedule and appointment!
As soon as the dyno was installed, we through our very own Chris' B7 Audi A4 on for calibration.
And then they quickly started to fill in to get tuned...
Another shop installed this Full Blown Turbo Kit on this FRS and was brought to us to get the car running correctly. Here is Vince installing a set of Injector Dynamics 1000cc injectors. Once finished, JR did his thing tuning the car and due to a stock clutch, car was able to put down a very nice 310whp at only 7 Lbs of boost on pump 93!
We offer full performance engine building and OEM rebuilding in house.
Injector Dynamics fuel injectors always in stock for FRS/BRZ, STI, EVO and GTR's.
Deatsch Werks Fuel Pump for FRS/BRZ, STI, EVO and GTR are also always in stock. If we happen to run out that day, a new order is only one day away!
Déjà vu? Nope...another Ultramarine FRS getting a P&L Motorsports Turbo Kit and Dyno Tune.
We wasted no time tearing into her...
2013 Subaru STI with 1700 miles on the Odometer getting a P&L Motorsports Rotated Mount Turbo Kit with Precision 6266 Turbo
Stay tuned for finished pictures and videos of those two Beasts making power on the dyno!
JR tuning this bolt on Evo X
[ame="https://www.youtube.com/watch?v=SU_PMIl6CgU"]https://www.youtube.com/watch?v=SU_PMIl6CgU[/ame]
2012 Honda Civic Si getting some baseline pulls in before the performance mods begin.
[ame="https://www.youtube.com/watch?v=yIf1466Xh0g"]https://www.youtube.com/watch?v=yIf1466Xh0g[/ame]
Here is a video of an Invidia N1 Catback and Resonated Front pipe
[ame="https://www.youtube.com/watch?v=rRspPZRiFPE"]https://www.youtube.com/watch?v=rRspPZRiFPE[/ame]
A gorgeous 2012 Audi S4 came in for a Stasis Catback Exhaust System
[ame="https://www.youtube.com/watch?v=NtS27K2zfCc"]https://www.youtube.com/watch?v=NtS27K2zfCc[/ame]
Baseline pulls for this 2008 VW R32. Strong outing at 227 awhp
[ame="https://www.youtube.com/watch?v=Is8o8DKVURQ"]https://www.youtube.com/watch?v=Is8o8DKVURQ[/ame]
Old 12-03-2013, 01:02 PM   #78
sklimo
Invidia 12+ Subaru BRZ / 12+ Scion FR-S Front Pipe w/ High Flow Cat.
Would I pass emissions with this?
Old 12-03-2013, 01:38 PM   #79
PrimeMotoring
Would you still be keeping your stock header? If so then absolutely. If you do an aftermarket header, there is always a possibility to throw a code. At that point we can tune the car for a catless or high flow cat system and help you eliminate any codes associated with a free flowing exhaust system.
Old 12-03-2013, 01:43 PM   #80
PrimeMotoring
Prime Motoring is your Premier Tri-State Dyno and Tuning Specialist
Prime Motoring is proud to introduce our newest addition to the shop and one that will greatly benefit the Tri-State area. We recently have taken delivery of our brand new Mustang AWD150SE Dynamometer and wanted to announce that it is finally fully operational and we are currently taking appointments for dyno pulls and Ecutek Tuning.
The reason why we chose Mustang for our Dyno is because Full time AWD vehicles are designed to provide maximum performance regardless of road conditions. This does not apply to you guys but with the broad range of vehicles we work with that have very intricate AWD systems, we had to take in account that in order to properly test an AWD vehicle for peak performance, an AWD chassis dynamometer must be able to simulate ideal road-load conditions to the vehicle. This approach allows the vehicle to be evaluated under “optimum” operational conditions; whereby torque is distributed to the vehicle’s tires in the same manner that would normally occur when a vehicle has equal traction at all four drive wheels, and is therefore operating at peak efficiency.
To achieve this, Mustang’s AWD-150 incorporates a linked drive system that synchronizes the front and back rollers to simulate a flat, dry road condition. Synchronization, or linkage, insures that the front and rear rollers are always spinning at precisely the same road speed. This process eliminates the possibility of activating a vehicle’s traction control system and also insures that a vehicle’s torque management system is operating under the assumption that the vehicle is not skidding, turning or slipping.
FULL CUSTOM ECU DYNO TUNING AND REFLASH
Prime Motoring is the new home of JR Tuned!
Full custom Ecutek ECU tune - PM/Call
Fuel system Install - $225
-Injectors
-Fuel Pump
Dyno Pull - 3 pulls - $100
There is a $100 non-refundable deposit required when scheduling your appointment. This deposit is a necessary evil in order to maintain our schedule due to the number of cars tuned. Please call 10 or more business days prior to your appointment if there is a need to reschedule for any reason (mechanical, weather, illness, etc). Failure to arrive on time to your appointment may result in forfeiture of your time slot and the deposit.
Pre-Dyno Inspection
One of our strongest recommendations is to perform a PDI (Pre-Dyno Inspection). Which consists of a Boost Pressure test, Vacuum Leak test, and a visual inspection to ensure proper functionality of components (example: boost controller, intake, etc). If an issue is found during the inspection we will make our best effort to repair the issue, however if issue is not able to be rectified you may lose your appointment. This service is only $65 and could potentially save you hundreds if your car has an issue during its session. Also, if you forego the inspection and an issue does arise you may lose your session and deposit.
Also DeatschWerks Fuel Pump and Injector Dynamics Fuel Injectors for FRS/BRZ, STI, EVO and GTR are also always in stock. If we happen to run out that day, a new order is only one day away!
Old 12-03-2013, 01:55 PM   #81
PrimeMotoring
Old 12-03-2013, 01:56 PM   #82
PrimeMotoring
Subaru BRZ taking advantage of the savings!
Old 12-03-2013, 02:44 PM   #83
sklimo
See you guys on the 14th!!
Old 12-03-2013, 03:36 PM   #84
PrimeMotoring
Thank you very much @sklimo, you finally get to stop by the shop!
Prime Motoring Black Friday/Cyber Monday Specials for the Entire Status Racing Line! PrimeMotoring Interior Parts (Incl. Lighting) 1 11-15-2012 08:21 AM
Garage Life: We bring your dreams to life! Garage Life Southern California 0 08-17-2012 07:33 PM
Status Racing - Prime Motoring Is Your Northeast Distributor!!! PrimeMotoring Interior Parts (Incl. Lighting) 0 07-21-2012 12:40 PM
BRZ on Motoring TV diddy CANADA 9 05-24-2012 04:22 PM
Best MOTOring? Whered it go, is there a substitute? ahausheer Off-Topic Lounge [WARNING: NO POLITICS] 3 03-25-2012 11:54 PM
