Old 02-08-2014, 08:34 PM   #71
pche
Guy on internet
Drives: Slowly
Do radar detectors really work...? Had a few in the past, to me they're more of a annoyance than an functioning device.
pche is offline   Reply With Quote
Old 02-08-2014, 11:49 PM   #72
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
A good detector can work pretty well on the highway. My valentine 1 can see several miles long before I can actually get a visual. I get false positives in certain places, but since I frequent those area's I know what the number count is and if it goes up I know its most likely a LEO driving around.
I find it helpful, but every now and then if you just speed or drive recklessly. You are eventually going to get tagged.
Ranatsu is offline   Reply With Quote
Old 02-09-2014, 11:46 AM   #73
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Just Lucky!
I'm driving South on 1-95 about ten miles North of the Florida Georgia Border, approaching St Mary's Road Exit (last interchange before the state line) CAMDEN COUNTY.
V1 starts singing LASER! I lift, start to brake, it's too late, Camden County Unmarked Deputy Sheriff on the overpass has me dead to rights with Laser, darn!
I set cruise at 75, pass under overpass and see Camden County Sheriffs cars lined up for the chase. I move to the center lane expecting a quick closure but instead the car just hangs back there, weird. A full mile goes by and the Deputy slowly passes me, slowly, and heads South. 30 seconds later he lights up the Gold Nissan 370Z that was in front of me the whole time. They shoulder their cars and I continue onward.
Probably thought, "no way the thing is doing 90".
I wasn't in my daughters Raven FRS, I was in my 06 Toyota Sienna Limited.
They had plenty of chase cars....Go figure
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 04-12-2014, 11:30 PM   #74
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Originally Posted by modena View Post
Ran my V1 power cord on the drivers side, needed power from the ODB2 port.
Using the V1's Bluetooth and SAVVY adapter.
Running YaV1 app, and have GPS lockouts, custom sweeps ext.
This setup removes almost all false and bogus treats and makes the V1 a whole lot less "Chatty"
I am considering this setup in my FRS. Does the SAVVY adapter connect to the OBD2 port? Then the detector plugs into SAVVY? And V1Connection LE connector plugs into SAVVY?
AVodka14 is offline   Reply With Quote
Old 04-13-2014, 08:20 AM   #75
modena
modena's Avatar
Drives: BRZ Limited WRB MT
Correct... Easy as pie...
(Best picture i have)
KartBoy SS | BlackVue DR550GW | Valentine1
GrimmSpeed MC Brace | GrimmSpeed Hood Struts
OEM Armrest | OEM STI Badges | 20% Tint
Rydeen duo | Halo's as DRL
Rexpeed Wide Mirrors
modena is offline   Reply With Quote
Old 04-13-2014, 01:41 PM   #76
AVodka14
AVodka14's Avatar
Excellent. One more question...how did you run the wire from the V1 to SAVVY?
Old 04-13-2014, 01:56 PM   #77
modena
modena's Avatar
Have the V1 mounted on the "dot matrix" passenger side.
(Next to the rear view mirror) You can hardly see it, and the forward and rear antenna's have a real good view.
Cable is a black phone wire, runs under the roof liner by the windshield,
strait down the drivers A pillar, exiting underneath the steering wheel.
Panel removes very easy with 2 Philips screws.
Old 04-13-2014, 03:28 PM   #78
AVodka14
AVodka14's Avatar
Gotcha. That makes sense. You sound quite electronically adept. Much appreciation.
Old 04-18-2014, 05:43 PM   #79
idanvan
idanvan's Avatar
Drives: WRB BRZ
thanks for this!
idanvan is offline   Reply With Quote
Old 04-18-2014, 05:47 PM   #80
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
A bit late to the party, but I figured I'd add my thanks as well - I used this guide to figure out which wires to tap for my V1 and dashcam the day after I drove the car home
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
Old 09-01-2014, 05:11 PM   #81
kdmxdgt
Drives: 2014 WR Blue BRZ Lmtd
do these direct wires tap into the existing wires (pierce through the shielding) or do they just make contact and sit next to them in the harness? i tried to wire in an escort smartradar which came with one of these "direct wires" and it broke towards the Y connection after the fuse while i was trying to feed it in. i guess i pushed too hard and/or twisted it.
thanks
kdmxdgt is offline   Reply With Quote
Old 09-02-2014, 09:29 AM   #82
codesplice
codesplice's Avatar
thanks
Got pictures of the "direct wire"? I'm not familiar enough with Escort hardware to recall what their hardwire kit looks like.
I used a couple of wire taps for wiring my V1 - similar to [ame=http://www.amazon.com/Install-Bay-3MBTT-T-Tap-Connector/dp/B001JT72D4/ref=sr_1_1?ie=UTF8&qid=1409664488&sr=8-1&keywords=wire+taps]these[/ame]. With the taps, you need to make sure you get the right size - too big, and they won't pierce the insulation to make contact with the power wire; to small, and they may shear straight through the wire.
G+
Old 09-02-2014, 06:39 PM   #83
kdmxdgt
It's basically the same as what is in the original post.
It can be seen here at the bottom of the page. https://www.escortradar.com/escort-blendmounts/
Old 09-03-2014, 09:18 AM   #84
codesplice
codesplice's Avatar
I believe those should just push into the back of the connector - no need to pierce the wire's insulation when you can just make good contact with the connector itself. They may take some finesse to get them wedged in there properly, but I don't think you should have to push on them too hard.
G+
diy, radar detector, speedracer38
Direct wire radar detector Kieranz Electronics | Audio | NAV | Infotainment 25 11-02-2015 12:01 AM
Mounting a radar detector Bg8780 Cosmetic Modification (Interior/Exterior/Lighting) 24 02-06-2014 12:39 PM
Win a Laser/Radar detector! raul Off-Topic Lounge [WARNING: NO POLITICS] 0 10-10-2012 01:57 PM
Radar Detector? Longhorn248 Other Vehicles & General Automotive Discussions 68 07-14-2012 04:31 PM
Mounting radar detector video ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 10 06-07-2012 11:29 AM
