Old 03-06-2013, 12:56 AM   #71
ProjectD
ProjectD's Avatar
Drives: '04 350Z/ 2013 LR BRZ (LM)
Originally Posted by sinigang_guy View Post
this is how i mounted mine:
I really like this setup. Short and sweet - to the point. You wouldn't happen to have a DIY thread on this would ya?
ProjectD is offline   Reply With Quote
Old 03-06-2013, 05:26 PM   #72
Cheeseballs
Cheeseballs's Avatar
Drives: Really slow
I emailed Radium asking for a 90° 2-piece in 0.425" and they told me the closest they have is the 0.5", which is selectable from their website. I guess they aren't making any more custom sizes.
Cheeseballs is offline   Reply With Quote
The Following User Says Thank You to Cheeseballs For This Useful Post:
ProjectD (03-06-2013)
Old 03-06-2013, 11:53 PM   #73
sinigang_guy
sinigang_guy's Avatar
Drives: argento frs; 90 mustang gt
i used this diy for my install. credit goes to dezoris and f1point4. i merely changed the mounting solution
sinigang_guy is offline   Reply With Quote
Old 03-07-2013, 10:15 AM   #74
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Did anyone else course stainless steel wool type material in theirs rather then the stackable screens? It looks like Radium has switched (didn't notice this before I ordered) judging by some of the pics on their website now.
https://radiumauto.com/index.php?p=p...id=28&parent=0
Not sure if this really matters or not, but the stackable screens seemed to be one of their selling points.
Old 03-07-2013, 10:57 AM   #75
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
I just followed dezoris and took a few pictures for science. He's the man here.
F1point4 is offline   Reply With Quote
Old 03-07-2013, 11:21 AM   #76
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
That's how mine came, I was a bit disappointed not to get the stackable screens, but it's working great!
Sent from my Nexus S using Tapatalk 2
Old 03-07-2013, 11:30 AM   #77
neutron256
neutron256's Avatar
That's how mine came, I was a bit disappointed not to get the stackable screens, buy it's working great!
I assume they changed it because either it was cheaper for the same effect, or because it works better then the screens. Just mostly wanted to confirm that I'm not the only one who didn't get the screens, and let others know of the change.
Thanks for the confirmation that it's working well without the screens.
Old 03-08-2013, 10:46 PM   #78
F1point4
Photo Specialist
F1point4's Avatar
The rustoleum isn't holding up
Please don't use steel. I used it because I goofed at the store.
20130308-DieHardBattery-003 by VictorN07, on Flickr
Old 03-10-2013, 05:31 AM   #79
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Well I have a prototype version installed...not completely though as I bought 2 clamps but my father who was helping modify them cut the length too short on one and it wasn't usable. I can say with only one modified clamp in the middle it's totally solid on the bar, silicone grip tape on the bar clamp pieces works great. The Radium mount is now the weakest link actually. Super easy to get to and remove the bottom of the can too with all that space between the battery and strut brace with this layout. It's fairly close to the hood, but clears fine in this position - further to the rear on the strut brace by a little over 1" is when the Radium intake fitting will make contact with the hood. I do plan on making a better version (TIG welded 1 piece upper), but this will do for now - with 2 more modified clamps added for massive overkill...
The reinforced racing rubber hose (1/2" for catch can to Intake manifold location and 3/8" for PCV valve to catch can location) was extremely hard to get on the fittings... see no need for clamps on them.
Custom Mount images:
Installed Images:
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following 4 Users Say Thank You to Vracer111 For This Useful Post:
ChrisD (02-27-2016), F1point4 (03-14-2013), ProjectD (03-12-2013), TofuJoe (07-10-2016)
Old 03-14-2013, 02:08 AM   #80
sinigang_guy
thats pretty creative. at first glance, it looks as though there isnt enough room to remove the can, but youre saying youve more than enough room. i think ive seen people drill directly into the bar. might be bad for rigidity..
thumbs up for coming up with a mounting solution!
Old 03-14-2013, 11:29 AM   #81
xwd
My first go at attaching the can I just drilled another set of three holes in the Radium bracket and used a piece of 7/8 rubber tubing around the bar (it's 7/8) along with three 1/4" high strength zip ties. Honestly it would have worked fine, the can wasn't going anywhere but the one issue was the output port was facing the rear of the car. I didn't feel like spending the money on a 90 degree fitting to make the hose not loop around so I just changed the mounting.
Old 03-20-2013, 12:16 AM   #82
Cheeseballs
Drives: Really slow
I mounted my catch can just like sinigang_guy and it could not have been any easier. It is the exact same method as Dezoris showed except you don't have to bend the mounting bar, obviously. The bar is held nice and securely and doesn't grind on any of the wiring.
As a side note, I used the 3/8" 90° 2-piece fitting since Radium doesn't offer it in .425" and my 11/32" hose fit very nice and snug even without a clamp. I used a clamp anyway for peace of mind.
Old 03-27-2013, 03:38 PM   #83
FR-S Neck
Drives: FR-S Black Beauty
Originally Posted by F1point4 View Post
It's been a while, but I'd like to return to post some of my install photos from the catch can. Thanks @Dezoris for the guide. Worked a charm.
So I'm definitely doing this setup once I get my tax refund check. Most likely going to go ahead and buy the double can setup for future expansion. How is that holding up so far? Any added noise (rattle)? Also did you buy a specific thickness of the metal that you bent?
side note: Would it matter if I used the 8AN outlet instead of the ones listed?
FR-S Neck is offline   Reply With Quote
Old 04-02-2013, 03:18 AM   #84
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
Alternative sources of fittings
As many have noted, the fittings and adapters that Radium sells with their catch cans are very expensive (they're also great quality, but still expensive). After some trial and error, I think I've worked out what would be needed to install a Radium can and not buy the fittings from Radium.
Male -10 AN to hose barb this one is a bit hard to find, this is the only model I came across. Used to connect the catch can outlet to the intake manifold.
Male -10 AN to Male -6 AN Reducer used to connect a Female -6 AN to hose barb 90 degree adapter* These two are much easier to find at various online retailers. The -6 AN size matches up well with 3/8ths hoses.
The total cost of these items at this particular vendor is $21.15 + shipping, so far they're the cheapest source of these parts, but most places will be less expensive than Radium.
Of course, you'll also need 3/8ths and 5/8ths hose (or -6AN and -10AN if you can find push-fit hoses sold in AN sizing). A hose clamp is definitely needed to secure the 5/8ths hose to the intake manifold. I would recommend using a hose clamp on all connections, just to be safe. Also optional are AN fitting O-rings. (Radium includes these)
Hopefully this can help save some money on future catch can installs!
*Edit: Backordered, here's an alternate part.
The Following 3 Users Say Thank You to Ninjin For This Useful Post:
chrisbfrs (05-02-2013), MJones_RB (07-07-2017), Sportsguy83 (04-03-2013)
2013 FR-S Product Technical Info and Specs (from Las Vegas press event) ichitaka05 Scion FR-S / Toyota 86 GT86 General Forum 53 07-19-2021 06:59 PM
Fifth Gear reviews the GT86 (Full Video) lazyluka Scion FR-S / Toyota 86 GT86 General Forum 20 10-10-2012 07:09 AM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
Full Specs and Info on GREDDY SCION FR-S vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 109 01-03-2012 12:11 AM
