Old 05-16-2013, 03:44 AM   #71
DSOmegaX
DSOmegaX's Avatar
Originally Posted by mrdanyo View Post
Did you do the dash yourself or order it?
It was ordered from JPM. It's listed on their website now. It's the bonded one-piece with the option to not have a logo embroidered on. Reason I didn't get it embroidered is I will be putting my badge of ownership there. Currently waiting on a new one to come in.
Originally Posted by JB1 View Post
Great build ! Thanks for providing links to everything. You my friend are a bonus to the forum.
Thanks! Haha yeah I learned from my past car because everyone would ask me where I get stuff all the time. I figured I'd just put it all up for easy access.
Originally Posted by clzzical View Post
Can't wait to see the steering wheel installed.
It'll be a little bit longer. I actually returned the wheel back to them. The center indicator that was put on got off-set from the center, most likely when it was being stitched together. With the wheel being hand-made, the tolerance there can be easily off. Unfortunately, I'm very OCD so they are actually just going to redo it for me without the indicator this time. Top will be red alcantara only now. Kinda bummed about not having the indicator, but I know if it's not perfectly centered it would drive me nuts over time haha
@dsomegax.cars
Old 05-23-2013, 02:54 AM   #72
DSOmegaX
DSOmegaX's Avatar
Calm before the storm that is every Tuesday in Irvine: Tuesday Irvine FR-S/BRZ Meet
Please come check out both mine and all the other owners' if you're in SoCal and have not had the opportunity to come!
@dsomegax.cars
Old 05-23-2013, 09:42 AM   #73
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Lookin good bro! Keep up the good work.
Beyer Subaru is offline   Reply With Quote
Old 05-23-2013, 11:47 AM   #74
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
Ugh the rims! I want the sti rims
Marcoscrdo is offline   Reply With Quote
Old 05-24-2013, 11:06 PM   #75
DSOmegaX
DSOmegaX's Avatar
@dsomegax.cars
Old 05-25-2013, 04:26 AM   #76
Mercury
Mercury's Avatar
Drives: 2010 Subaru Forester
Good stuff, mate. WRB + STI lip kit =
He who shall be last, shall be sideways and smiling..
- Baby Jesus
Mercury is offline   Reply With Quote
Old 05-27-2013, 03:47 PM   #77
BRZebra
Thanks for sharing so much info about your outstanding car! How much did the STI springs affect your alignment?
BRZebra is offline   Reply With Quote
Old 05-27-2013, 06:27 PM   #78
DSOmegaX
DSOmegaX's Avatar
I had it realigned a week after installation. Only slight adjustments needed to be made. The springs are designed for the stock suspension setup so it shouldn't make any significant impact to the alignment
@dsomegax.cars
Old 06-02-2013, 03:34 PM   #79
chjno86
a/k/a ikuzOtaku
chjno86's Avatar
Drives: Whiteout FRancheSka
im assuming yes, but would the Push Start Kit work on the FR-S as well? where'd you get it installed?
Thanks
instagram.com/chjno86 __ #TEAMFRANCHESKA _ #SOCALVALLEY86
chjno86 is offline   Reply With Quote
Old 06-02-2013, 04:21 PM   #80
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Great! I follow your style (more or less the same parts you get)....to transform my BRZ in STI BRZ! a question, please...STI front lip needs bumper removal to mount? Enclosed Manual is poor and only in Japanese, difficult to understand directions!
Trap63 is offline   Reply With Quote
Old 06-03-2013, 03:51 AM   #81
DSOmegaX
DSOmegaX's Avatar
Thanks
The push start kit is standard on the BRZ Limited. The STI button was a simple replacement. You'll need to buy additional hardware and wiring to get it to work on an FR-S. I believe there are some threads detailing the work involved to get it to work. I've also seen people just install the panel with the button without wiring it...
Thanks! The front lip doesn't require the bumper to be removed. You just need to put it on jackstands/lift to raise up the front end so you can drill. Easiest way is to mount the lip to the front using tape, and use a sharpie to mark the locations of where to drill. Hope this helps!
@dsomegax.cars
Old 06-08-2013, 03:00 PM   #82
JPM Coachworks
JPM Coachworks's Avatar
Drives: Honda S2000, Subaru STI
Send a message via AIM to JPM Coachworks
@DSOmegaX Loving the look of your car Derek. Great build!
Cheers
Andrew
-JPMCoachworks.com
JPM Coachworks is offline   Reply With Quote
Old 06-13-2013, 07:57 PM   #83
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
All the JPM pieces look amazing! Plus I am a huge fan of OEM + items, so the entire car is perfection in my eyes. Keep up the amazing work
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 06-14-2013, 03:34 PM   #84
DSOmegaX
DSOmegaX's Avatar
All the little details matter =)
STi valve stem caps to go with the wheels. Just waiting on my lug but set now. I also added a little copilot:
@dsomegax.cars
Completed build JK21 Member's Car Journals 46 12-11-2014 09:48 AM
Completed!! FBM 700+HP Build Dyno graph & Vid inside FullBlown Forced Induction 214 03-31-2014 01:56 PM
Vinyl wrap completed!! laley81 Southern California 14 08-30-2013 11:10 PM
Nearly Completed my Firstorm Build - Lots of Pics msile Member's Car Journals 52 03-10-2013 10:25 AM
Turbo FRS completed! Philly CANADA 24 09-03-2012 09:18 AM
