#71 |
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
what about EGR flow? or will that be accomplished with valve timing and overlap and such?
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs 1990 240SX Coupe - sold 2008 Civic Si Sedan |
#72 |
Drives: Scion FRS
I stumbled across this article from when Lexus first started using D4-S, it's a good concise explanation.
http://www.autos.ca/auto-tech/automo...fuel-injection |
#73 |
Drives: Honda Fit
^^ Thanks, mark'.
Where exactly are the direct injectors placed? |
#74 |
Drives: Scion FRS
Typically they are placed in the head right at the edge of the cylinder, angled to spray at or just below the spark plug, and to intersect with the incoming air.
This lets the fuel get picked up by the incoming air, and gives the swirl effect while injecting during the intake stroke; and it allows the fuel to be directed to the spark plug for the burst right before ignition. |
#75 |
Drives: Honda Fit
mark', the reason I asked was that I couldn't image placing an injector in the combustion chamber . . . but I guess it's possible.
#76 | |
Drives: 2006 WRX STi, 1994 Mazda 323
Kind of off topic.......but Mazdas 16x wankel rotary (to me) is more like a two stroke motor than a fourstroke in the sense that it uses ports instead of valves. The efficiency increase seen on that motor if it ever gets released in a vehicle will have vast improvements over the current renesis rotary. Another good example is BRP's two stroke snowmobiles. They can get up to 26+ mpg (pretty impressive) on the trail and the tuning potential is greatly increased when compared to carbs or efi. It also allows them to run a really lean oil mixture since no oil is injected into the combustion chamber, it is injected into the crankcase. Just some food for thought. |
#77 |
Kuruma Otaku
Aurex: In racing it is considered such. They use 2X a rotary's displacement when figuring out equivalency as they get 2X as many power strokes than a piston engine. Or something... Stupid triangle motors...
Because titanium. |
#78 |
Interesting to know.
back on topic though..... What I want to see is what kind of fuel efficiency the direct injection will bring to the ft86/brz and its new motor. My STi is a PIG on fuel. I CAN get decent fuel economy out of it, short shift, stay a little under the speed limit on the highway etc. But I would think that this thing should be in around the high 20's on the highway if not breaking into the low 30's with the direct injection. Is that too unrealistic to expect? |
#79 |
Drives: '06 AM V8V Coupe
Direct injection doesn't provide as large of an efficiency increase the way Toyota is using it with non-stratified charge. I think that article isn't exactly correct, a paper that someone linked explaining D4-S in detail explained the purpose of having both port and direct is to get a more homogeneous mix in the cylinder. D4-S does NOT use stratified charge.
With VW style stratified charge it's theoretically possible to increase part load efficiency a bit since they remove the throttle, but this creates a lot of NOx emissions and efficiency still drops at part load since at very high AFR the pressure ratio is crap. The direct contribution of direct injection would be increased compression ratio/better spark timing, and in the case of D4-S, better combustion efficiency since the fuel is more evenly distributed. Not to say this is a small improvement, but it's not very big either, as increasing compression ratio a huge amount like from 10:1 (typical cars running on 87, with port injection) to 15:1 brings less than 10% theoretical improvement in efficiency. As far as combustion efficiency goes, I don't know how much improvement they can get over run of the mill port injected engines... As for the rotary being like a 2 stroke, this is not a good analogy because a rotary is like 3 4 stroke engines sharing one set of ports. There is no overlap between intake and exhaust stroke, and there are 4 distinct strokes. Direct injection on a rotary wouldn't bring much improvement because the main issue with the rotary is that the combustion chamber shape is very VERY bad, and a slightly smaller but still annoying problem is that compression ratio can't be very high since the shape of the engine won't permit it. In all other ways, the rotary is actually better for efficiency. Lower friction, less losses to vibration, no losses at the valves. I'll just remind everyone again, the KEY step to improving fuel efficiency, particularly for turbocharged motors, is variable intake duration. At idle, using late intake valve closure instead of a throttle on some motorbike engine (with the "Williams Helical Camshaft") reduced fuel consumption by 80%. Toyota, BMW, and Nissan claim over 10% overall efficiency improvement with Valvematic, Valvetronic, and VVEL. When you consider that just adding (in Toyota's case at least) an adjustable rocker to the head improves efficiency on an already pretty efficient Toyota ZR motor by more than 10%, while Subaru completely reworked their thirsty EJ motor, reducing friction by a massive 28% and reworking the combustion chamber for 10%, you see why pumping loss through the throttle is the biggest problem for efficiency (aside from gearing, which can completely kill fuel efficiency when it's retardedly short). In the case of your STi, you have very short gears, a thirsty engine in the first place, and a pretty big turbo sapping extra power at part load by creating backpressure, so it's no surprise it's not fuel efficient. Direct injection can only slightly remedy the problem. This car can probably get into the 30s for mpgs since it's coming out in 2012, so they'll be careful not to kill the fuel economy by not having a tall cruising gear, and it's a high compression ratio N/A engine. If the Civic Si can do over 30 on the highway with its short gearing and relatively primitive engine tech, this should be able to do at least as well. Last edited by serialk11r; 10-20-2011 at 07:03 PM. |
#80 | |
Drives: '09 335, '85 535, '95 Yota Pickup..
#81 |
The throttle isn't used at all actually, it's only used if the valvetronic system fails. It's a fail safe to prevent the engine from going out of control.
In theory, throttle response should be better, because there's no volume between the throttle and cylinders. But I suspect they programmed the ECU to ignore quick throttle inputs so people don't crash themselves or something. |
#82 | |
Drives: 2010 Chevy Cobalt SS, 59 Ford F100
Now as far as tuning goes I would like to add another topic for discussion... I'll start with my "hypothesis" as it were... the D-4S system is going to be epic for Ethanol and forced induction here is why... In my engine, direct injection only, it is very difficult to control fuel delivery under boost at WOT through the mid range. Take a look at the attachments I have include, they deal with Ethanol fueling. Due to ethanol's properties it is difficult for the HPFP of my motor to keep up. The D-S4 engine should be able to take care of any fuel issues because it has secondary port injectors. If the ECU can be unlocked, and a turbo added... the possibilities are quite extraordinary. On the log pick titled e85logpic2 you see the desired fuel pressure vs. actual in the second row of figures blue (FP Des psi)and orange (FP Rail psi) graph lines. Notice the RPM, 4400, just after at initial tip in on a 3rd gear pull 60-100mph. With the port injection You could run alot more fuel and use Ethanol more effectively. Oh by the way due to the efficiency of airflow, I have to mix my E85 with 91 octane at a ratio of 50/50. I would not be able to feed the motor with even close to enough fuel with straight E85. That is the downfall of direct injection, bigger injectors are big bux and hard to come by. With the port system on here, the extra fuel will just get thrown in, no problem. On e85logpic1 you can see how, on the same pull, the fuel easily catches up in the upper ranges. This is due in large part to the cam driven HPFP that is used in my car. Other DI systems may or may not run into this problem, just something to think about I guess.
2010 Chevy Cobalt SS Treadstone Performance Stage 3 kit: CAI, Charge Pipes, TR8 intercooler, Maf Relocate, 52MM Turbosmart BOV, 3 inch catless downpipe, 3 inch catback, borla XR1 muffler, Exedy Hypersingle, TWM short throw shifter, 24PSI HPtuned by Terminator2 on E85/91 |
#83 | |
Drives: Bugatti Veyron
#84 |
Drives: Honda Fit
| Photographer's thread | Giccin | Off-Topic Lounge [WARNING: NO POLITICS] | 1169 | 04-01-2026 09:55 AM |
| Intoxicated thread | #87 | Off-Topic Lounge [WARNING: NO POLITICS] | 46 | 04-27-2012 07:17 PM |
| Joke Thread | VenomRush | Off-Topic Lounge [WARNING: NO POLITICS] | 27 | 07-09-2011 12:44 AM |
| The Diet Thread | Maxim | Scion FR-S / Toyota 86 GT86 General Forum | 126 | 06-14-2011 05:47 AM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 10:59 PM |
