Old 08-19-2011, 07:39 PM   #71
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by fatoni View Post
i dont think there is any reason why anybody would want a flexible chassis unless you are talking about safety issues and junk like that
Can't have all the chassis been stiff. Need to have flexible area to release/damper the shocks.
Old 08-19-2011, 09:25 PM   #72
Marrk
Drives: Honda Fit
Yes, gotta be strong & certain point flexible. Subaru is in 300GT & Super GT, so I'm not too worry about their chassis been weak. Only weak chassis they made is first gen Impreza (GC sereis). They're called "watermelon" due to lack of chassis stiffness... but from GB and so on, chassis is hella strong
Good to know. Thanks.
Marrk is offline   Reply With Quote
Old 08-19-2011, 09:38 PM   #73
fatoni
care to elaborate?
Old 08-19-2011, 09:49 PM   #74
Dimman
Kuruma Otaku
Dimman's Avatar
I disagree. Chassis needs to be as stiff as possible so it doesn't interfere with the chosen spring rates (by being a random spring itself) and so the control arm mounting points don't move, interfering with the motion that the engineers try to design.
Because titanium.
Old 08-19-2011, 10:42 PM   #75
Exage
GL 86!
Exage's Avatar
Drives: Maybe FR-S... maybe not
care to elaborate?
It's most likely the same reason why crankshafts are flexible. It will absorb accelerations better. The same strength crank that is stiff would actually be brittle and problem prone. Engine manufactures can run a flexible crank then a more expensive high strength stiff crank given the design tolerances.
I will say that the crankshafts doesn't have the same flexibility as a wet spaghetti noodle, but it is present and purposely designed into mass produced engines.
Exage is offline   Reply With Quote
Old 08-19-2011, 10:46 PM   #76
82mm 4g63
4G63 & Rotary
82mm 4g63's Avatar
Drives: 92TalonAWD, 93RX7, 11F150EcoBoost
Send a message via AIM to 82mm 4g63
Stiff and flexible cranks, so many jokes so little time.
82mm 4g63 is offline   Reply With Quote
Old 08-19-2011, 11:37 PM   #77
Allch Chcar
Drives: N/A
Now don't throw a rod into this convo. It's just getting good.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 08-19-2011, 11:54 PM   #78
tree fingers
Drives: '93 FD3S
Originally Posted by tranzformer View Post
I have rarely heard bad things about Subaru. Except for the small issues with WRX/STI engine. But I wouldn't worry about that with this car.
I wouldn't call ringland failure a small issue.
tree fingers is offline   Reply With Quote
Old 08-20-2011, 12:04 AM   #79
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
I would since every car was not affected and many forums blow things out of proportion as those affected tend to be the vocal minority and make the loudest stink and those with no issues hardly speak up or have anything to complain about.
tranzformer is offline   Reply With Quote
Old 08-20-2011, 12:24 AM   #80
Marrk
Drives: Honda Fit
Well, how serious was the issue and did Subaru make good on it, i.e., warranty it?
Old 08-20-2011, 12:26 AM   #81
tranzformer
Drives: Zoom Zoom
Not sure since I never owned a WRX/STI. NASIOC would give a general idea.
Old 08-20-2011, 12:47 AM   #82
fatoni
they are flexible because of the nature of the steel. they dont want them flexible. they just dont want them brittle either. you cant have both as far as the materials are concerned. thats why they go through the trouble of forging things and designing structurally sound components. flex in a crankshaft is just robbing power from the motor just like flex in a chassis is adding a vague feeling to the suspension.
Old 08-20-2011, 12:55 AM   #83
Dimman
Kuruma Otaku
Dimman's Avatar
There is this:
http://forums.nasioc.com/forums/show....php?t=1695936
Because titanium.
Old 08-20-2011, 12:59 AM   #84
Marrk
Drives: Honda Fit
That doesn't look good.
Toyota Celica name possible for European/Asian market madaadda Scion FR-S / Toyota 86 GT86 General Forum 109 11-02-2011 01:46 PM
after market parts serchmarc Scion FR-S / Toyota 86 GT86 General Forum 90 05-31-2011 08:18 PM
What do you look for when buying a sports car? Diar Other Vehicles & General Automotive Discussions 43 09-28-2010 08:50 AM
President/COO Toyota Motor Sales USA confirms FT-86 coming to North America market! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2010 08:15 PM
