#71 | |
Drives: Crapcan
It's overkill if you are being careful but there ain't no kill like overkill.
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#72 |
not playing cards
Agreed.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (12-31-2022) |
#73 | |||
Drives: 84 CJ7, 08 Duramax, 2014 FRS
It adds up quick, but short story. It's the square root of all the respective squared values of each tolerance in the system of parts. The real tolerances provided by the equipment (add poor tech operations), not the pie in sky charts they created off a few runs produced by the best techs in the factory. The stack with all the slackers running the show and slipping the material out of spec material through. I was also the metrology engineer, I had the actual data. All of it. But that's different story. |
#74 |
This clutch didn't last long, not sure if its the puck style or southbend, which was all Exedy stamped. I got 46k out of it, bit disappointed, but learned from it and moving back to an organic style clutch. I hope it takes care of the judder/chatter, because I never really got that sorted properly even though I did put in some stiffer bushings here and there. The rear diff bushings just couldn't handle it properly, it caused them to move to much and cause quite a racket. It's discussed early on in the thread. I thought you just needed a stiffer setup, the Cusco bar helped, but still didn't fix it entirely. Due to that, I'm moving back to an organic type clutch.
I have STI rear diff bushings to go in there, had the appointment, then the clutch started going so I'm moving to an ACT with a lighter flywheel (comes with it) shop recommended model, and back to an organic clutch instead of these ceramic/metal style. Repair bill went up, but that's life sometimes. Thought these puck clutches would last longer. Lesson learned. About half or less than I get from a usual clutch personally, was a bit surprised and disappointed to lose it so soon. |
#75 |
Drives: 2013 frs base
Is this a track car? Light weight flywheel is probably ok. For street, you won't like it.
| Bucking on throttle application? | Mr_Eyo | Software Tuning | 57 | 11-21-2018 03:45 AM |
| E85 OFT tune Bucking/surging | Vmax911 | Software Tuning | 5 | 07-30-2017 04:27 AM |
| Horrible bucking and shutter after clutch install | Scikotic | Engine, Exhaust, Transmission | 32 | 07-12-2016 09:10 PM |
| 2-3K RPM hesitation/bucking - logged | 86fun | Software Tuning | 5 | 01-29-2016 09:58 AM |
| loss of power/ bucking in rain | fasteddy | Issues | Warranty | Recalls / TSB | 30 | 10-20-2015 03:08 AM |
