#71 | |
Drives: '23 BRZ
Acceleration: obviously to maximize acceleration potential and drive out of corners with a rear-drive car, you want more load on the rear tires under maximum acceleration. More rearward = better. For rear-drive, 45F/55R is *better* than 50/50. For reference, a radically rearward static weight distribution of 18F/72R would put 100% of the weight of the car on the rear wheels at 1g acceleration for a 100" wheelbase car with 18" c.g. height (a bit extreme and you wouldn't want that). Braking: with a "square" tire setup, you would maximize tire grip and minimize stopping distances if you had *even* load distribution between the tires under braking. At 1g braking, that would require a *very* rearward static weight distribution of about 32F/68R For mid-engine cars with front/rear tire stagger, an even more rearward static distribution would be ideal for braking. Cornering: Again assuming "square" tire setup, for maximum steady-state cornering grip (not accelerating or decelerating), you would want 50/50 F/R load distribution between the front/rear outside tires (for simplicity we'll leave front/rear roll stiffness out of it for now but it plays a big role). The FT86 has a decidedly front-biased 55/45 distribution, and this not only gives *ridic* front tire wear relative to rears at the track, it is also costing us lateral grip, cornering speed, and probably a couple/few *tenths* of a second in terms of lap time. For cars with front/rear tire stagger, the "ideal" weight distribution for cornering would be more rearward than 50/50. This includes higher-powered FR cars that need wider rear tires. Long/short, 50/50 isn't ideal for rear-drive performance. Even low-powered rear-drive cars would have better overall performance with weight distribution more rearward than 50/50. 55F/45R is a bit shite for an FR "sports" car IMO... Last edited by ZDan; 08-12-2021 at 10:07 AM. |
#72 | |
Drives: WR Blue Pearl 2022 Subaru BRZ
I would of thought with the front heavy car would allow you to apply small amounts of acceleration to balance your cornering speed a lot more efficiently than say a rear heavy car? Also, isn't the GR86/BRZ 53:47? |
#73 | |
That's not to say that if you couldn't throw money at the problem, like Porsche and their trick intake pressure wave timing on individual intakes and the probable exotic materials on cats and inside to make the pistons flow like butter. Or just delete the cats that would certainly help the air suck through.
#74 | |
Drives: '23 BRZ
They advertised 53/47, but the mags tested them and found them to be 55/45, which is exactly what I found weighing my initially stock car at the track with a full tank and me in it. Now, with a 5 lb. battery (-25 lb.), 2-piece brake rotors (-12 lb.), near-empty washer reservoir (~-6 lb.) and a catless header (-10 lb.?), ~53 lb. off the nose of the car, my car is at 53.5F/46.5R with me in it, full tank. It was never anywhere near 53/47 stock... |
#75 | |
Drives: JRSC BRZ SOLD
The USDM cars will feature 228bhp not 238. As mention in the Ken Gushi ride along iirc, the new cars dyno around 195whp+. This is good given the 228hp rating which I'm sure was done on 91oct. |
#76 |
Drives: '23 BRZ Limited
I'll be it was done on 93. I know my old Mustang (2013 GT) for example, was rated/advertised at 420hp. Then when you read the fine print in the manual it said 420 on 93, 410 on 91.
#77 |
Drives: Subaru BRZ
My bad, 228*.85 = 194 whp.
#78 |
Drives: 2018 Subaru BRZ Limited with PP
Not sure why we are comparing dyno's again... 206 whp on some dyno with a 100% chance of different conditions is not a good comparison to the ~195 whp that has been a number provided with no additional information whatsoever.
The most interesting information that could compare the two was CatDaddysBBQ's article which described his bolt-on and E85 tune on his first gen to feel "EXACTLY" the same as the new gen. |
#79 | |
#80 |
I was only referencing the only piece of information we have that is actually kind of useful. And it is absolutely superior to a couple dyno comparisons that we know absolutely nothing about further from peak whp numbers.
#81 |
Drives: 22 BRZ limited
What about trying to extrapolate a number from the 0-60 times published?
#82 |
#83 | |
How's your credit? I have a bridge for sale. |
#84 | |
Drives: GT86, 22 BRZ
I've owned the 86, 50:50 FR and rear biased MR cars. They are all good for different situations. But for the low power level of the 86, I've never felt I needed more rear weight bias. The front bias of the 86 provides a lot of predictability. It's very forgiving, allowing you to really overdrive the car and still be able to catch it in situations where you will have no chance in a rear biased car. The twins are designed to be 'fun' cars rather than 'performance number' cars. There are many cars that will beat it if you are just looking at objective performance. But not many cars can beat it for feel and fun. |
| BMW 135i or similar | 8RZ | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 11-22-2019 11:33 PM |
| Considering Lemon Law or similar | TheMedakaBox | Issues | Warranty | Recalls / TSB | 28 | 08-31-2016 09:25 PM |
| Similar Wheels | calidus | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 09-10-2014 01:46 PM |
| Who has a similar STI lip (PIC INSIDE) | 914_WHITE_FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 05-02-2014 11:53 PM |
| Similar to JPM CoachWorks in Aus? | Egyptn | AUSTRALIA | 6 | 11-05-2013 10:44 PM |
