#71 | ||
Drives: 2022 GR86
![]() Quote:
| The Following User Says Thank You to timurrrr For This Useful Post: | NoHaveMSG (04-19-2021) |
#72 |
Drives: 2022 GR86
These car manufacturers clearly don't know how to make digital speedometers. You should never buy cars from them!
#73 |
Drives: Crapcan
I didn't think about that but would make sense. Must be broadcasting on different PIDs for speedo, TCS, and power steering control module.
#74 |
Drives: Crapcan
That is what I personally don't care for. It is scrolling so quick you can't really read it practically. It is enjoyable visually on an acceleration run, but that would be about it to me.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Dadhawk (04-19-2021) |
#75 | ||
Actually, at least on the Ferrari, it is skipping numbers or its changing so fast there are numbers missed by frames of the video (which actually would be possible depending on the frame rate). I didn't take the time to look at the others. Pause the video and use the comma and period to go through it one frame at a time. It is skipping numbers quite a bit and you can see one fade into the next. There are also frames with no change. If the 86 accelerated at the same speed as these cars it would look like that as well I suspect.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | NoHaveMSG (04-20-2021) |
#76 | |
Drives: 2022 GR86
Again, I never specifically said it should show every single number; I complained that the current refresh rate is too low. Now that you mentioned it, I decided to do some "scientific" counting! ![]() (30 fps) Between the first frame that shows 0:03 to the first frame that shows 0:04, the number on the display changes 10 times. So ~10 Hz, as I was suggesting as a good compromise for a while ![]() --- For comparison, here's a GT86 video: (it's 60 fps, so double the button pressing to view one second) Between 0:41 and 0:43 (two seconds), the number changes 7 times. So ~3.5 Hz. Ok, my "~2 Hz" estimation was a little wrong. Looks like instead of ~5x'ing the refresh rate we only need to ~3x the refresh rate. |
#77 |
ProCrastinationConsultant
don't forget, they could also be doing some software smoothing, where the dash really only gets an update every 2hz, but displays incremental numbers between updates...
#78 |
But, aren't you assuming the two cars are accelerating at the same pace? In any given second the Ferrari is going to go through more MPH changes then the FRS during hard acceleration.
#79 |
Drives: '14 BRZ 6MT
Honestly, only used the digital speedo on my gen 1 and it was completely fine. The examples shown with each digit displayed are not preferable for me - too fast and not helpful.
#80 | |
Drives: 2022 GR86
At the same refresh rate the Ferrari would just be accelerating +5...+6 km/h per update. |
| The Following User Says Thank You to timurrrr For This Useful Post: | Dadhawk (04-20-2021) |
#81 | |
Sent from my SM-G975U using Tapatalk |
| The Following 4 Users Say Thank You to p1l0t For This Useful Post: |
#82 | |
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
I can't wait until we can actually see this car in person and test drive it so we can stop talking about the speedometer and move on to important subjects like whether or not you can see the brake pads, or possibly whether or not we should buy the automatic or manual transmission.
How I long for the carefree early days, giving advise on the senior prom...
| The Following 6 Users Say Thank You to nextcar For This Useful Post: | Dake (04-21-2021), NoHaveMSG (04-20-2021), p1l0t (04-20-2021), soundman98 (04-20-2021), Tcoat (04-29-2021), Transport3r (04-20-2021) |
#83 | |
Drives: 2016 Scion FR-S
It was the LFA, that V10 ![]() ![]() My favorite engine everSent from my iPhone using Tapatalk |
#84 |
Drives: 2013 Scion FR-S Series 10
In a fast car, you want to see the numbers going fast because it highlights how quickly the car is building speed. If you were to do it both ways and market research it, I assume the fast numbers would be better received.
Additionally, on a track, you would want numbers to updated quickly so you can glance down at any time to know your precise speed. For normal drivers, they probably want less numbers flashing at them, especially after a work day. For me, on the street, I feel like with 16 years of driving experience, I can accurately guess within ~5 mph of how fast I am going on a given street. So I only need to glance down to confirm the speed. I'm not watching the speedo or really even the tach; I rely on noise to tell me when to shift. Also also also... The speedos we are watching have been recorded on camera running at a FPS @ 24/ 30/ 60 with who knows what shutter speeds and so>edited and rendered out that can affect how it looks>uploaded and converted to YouTube media file that further changes thing>then displayed on computer monitor. |
| In-dash digital speedometer | vaer | Electronics | Audio | NAV | Infotainment | 4 | 04-14-2020 11:19 AM |
| Does the BRZ get same refresh? | snezze21 | BRZ First-Gen (2012+) — General Topics | 74 | 03-24-2016 02:51 PM |
| Convert the digital speedometer from Kmh to MPH? | Jastation | Electronics | Audio | NAV | Infotainment | 10 | 09-28-2015 06:46 AM |
| Digital speedometer in base GT86? | rhysmcinerney | Electronics | Audio | NAV | Infotainment | 25 | 01-22-2014 07:18 PM |
| Fast car Fast driver vinyl decal I need help | francosolracer | Cosmetic Modification (Interior/Exterior/Lighting) | 18 | 10-20-2012 04:43 AM |
