Old 06-14-2011, 06:42 PM   #71
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Nice progression! I remember the initial Nurburgring videos showed the FT having a lot of body roll. Now it seems a bit more planted! Not sure which route they went with, Bilsteins or Sachs, either way they are tuning this bad boy!
Old 06-14-2011, 07:04 PM   #72
bigbcraig
Drives: 2013 BRZ / 2015 WRX
Motons. It'll be a good deal as a $5,000 option
Body movement is very composed, so its probably a pretty nice chassis...
too bad we'll probably have to get some high-quality coilovers and replacle all the bushings to get it
bigbcraig is offline   Reply With Quote
Old 06-14-2011, 08:07 PM   #73
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
I matched up one of the turns with spy video of the 1er 5-door from a few days ago.
http://youtubedoubler.com/SbQ
You can really see how flat the ft86 is in comparison. I timed them both and they are pretty much identical but the ft86 definitely carries more momentum through the turn. It also sounds like the tires are making pretty much the same noise to my earlier cries of understeer are probably unfounded.
The BMW was practically on 2 wheels on turn in while the ft86 seemed to stay planted.
Here's the turn where I am seeing understeer.
http://youtubedoubler.com/Sg0
Looks like the BMW is able to get itself sorted out and set up for the next turn a lot faster than the Suby
edit... looks like it was just a bad line. The beginning of the video is the same turn and the Suby looks a lot more sorted
http://youtubedoubler.com/Sgi
Spaceywilly is offline   Reply With Quote
Old 06-14-2011, 09:16 PM   #74
RRnold
2 wheel member
RRnold's Avatar
Usually the aftermarket suspension that is offered as an option tends to be a step lower grade then what you can find at a performance shop (I'm assuming).
Motons is $$$! There was a guy selling his suspension on nasioc! Bought it for 12K but ended up selling it for $4,500.
I've been a fan of the 'original gold' so that might be my suspension of choice. Hopefully they'll have it available.
Old 06-14-2011, 09:34 PM   #75
bofa
Drives: Ms. Daisy
That BMW is all over the place in the third video.
BRZ before hoes
bofa is offline   Reply With Quote
Old 06-14-2011, 10:01 PM   #76
bigbcraig
original gold? sorry
Otherwise, I agree, things like upgraded suspension and audio are best done by the aftermarket... But if there was a way to get a high quality shock that was actually an aftermarket model and not a "made-by" then I'd jump on it. In the aftermarket, I'd be looking at something like KW at the very least, in terms of quality. Even if it means I can only afford to do KWs, tires on the stick rims, and basic brake upgrades with homemade ducting, and stripped interior.
At Atlanta Region SCCA Solo, theres a guy with an E36 (don't remember if its an M or not) that's really fast. His Motons are supposedly about 2/3 the money put into the car.
Old 06-14-2011, 10:27 PM   #77
AaronCompNetSys
AaronCompNetSys's Avatar
Drives: 01' S2000; 05' WRX
Originally Posted by MatadorRacing_F1 View Post
Lift off the throttle hard through a corner in an understeery FWD car, the ass will come round faster than a stripper who you throw $100 bills at.
Full of win.
AaronCompNetSys is offline   Reply With Quote
Old 06-14-2011, 11:25 PM   #78
Dimman
Kuruma Otaku
Dimman's Avatar
bigbcraig:
When you are talking about the Subarus losing camber in corners, is that because of the big squishy rubber top mounts of the struts? Would proper bearings fix this?
(My Legacy's only a daily, but I'm accumulating some WRX/STI bits that may or may not fit. So far I've got some GD WRX struts and springs, and some STi front aluminum LCAs with the 'good' mounts/ALK part, whatever that meant...)
Because titanium.
Old 06-14-2011, 11:26 PM   #79
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by AaronCompNetSys View Post
Full of win.
At the strip club I frequent, I only need 5's for the same effect. (Drink 'til they're hot...)
Because titanium.
Old 06-14-2011, 11:38 PM   #80
PAImportTuner
Turbo Mafia Presidente
PAImportTuner's Avatar
Drives: U Mad?
bigbcraig:
For the BD chassis you want to stay with GC8 parts, it's the same chassis. Though GD struts/springs and coilovers do fit. I had a BD and swapped/built it, besides the 04 wrx drivetrain all suspension bits were from a jdm gc8 impreza sti all the way down to the Cusco undercarriage braces.
Subaru have a funky cambr/caster curve but it is nowhere near a Mustangs wild curves when lowering it 1" throws the whole front geometry off.
"the FR-S is going to have to give me a blowjob every time I touch the steering wheel if all it can make me smile with is the handling." - Maxim
PAImportTuner is offline   Reply With Quote
Old 06-15-2011, 12:08 AM   #81
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
Iv encountered that same thing too with Subaru suspensions. I suppose it has to do working with AWD.
On a side note, I wonder if Subaru, being somewhat new to RWD will adopt a form of active rear steering.
WingsofWar is offline   Reply With Quote
Old 06-15-2011, 12:26 AM   #82
Dimman
Kuruma Otaku
Dimman's Avatar
NO! Don't even make jokes about crap like that!
Because titanium.
Old 06-15-2011, 03:42 AM   #83
Clode
Drives: Toyota / Lexus
Toyota says they have taken the cayman as a reference point
Clode is offline   Reply With Quote
Old 06-15-2011, 03:52 AM   #84
ryun84
ryun84's Avatar
Drives: 04 PSM WRX Wagon
That would explain why all the spyshots and videos seem to have Cayman cameos (too many for it to be coincidence?).
ryun84 is offline   Reply With Quote
First Video of Scion FR-S / Toyota FT-86 / Subaru BRZ Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 35 11-15-2011 09:21 PM
FR-S/FT-86/Subaru Coupe Video of interior close up + in depth sound DIG1992 BRZ Photos, Videos, Wallpapers, Gallery Forum 36 06-21-2011 02:33 AM
Subaru/Toyota Coupe spotted in Socal with Subaru Plates owsiu Scion FR-S / Toyota 86 GT86 General Forum 150 05-25-2011 10:27 PM
Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show C-Bone BRZ First-Gen (2012+) — General Topics 39 03-24-2011 09:22 AM
First video of Subaru 086a test vehicle from the Nurburgring + interior spy pic Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 22 11-21-2009 03:20 AM
