#71 |
Trident Motorsports Owner
Drives: DGM. DD for my EvoX
![]() I'm rocking this one for a while to. Plan on hooking up a wideband ASAP to see how close it is to where it should be. I may or may not change paths down the road but for right not the butt dyno feels more power. I smell slight burning smell but from past experience it is the(excess) oils burning off the cone and tube. The is a very different sound coming from the engine and I removed the sound tube and plugged it with a thick bolt in the fire wall. I am happy till there are intakes out that arent 400$ for the same things plus a box
previous cars:1998 chevy s10 2001 Prelude SH 1992 (JDM)RX7 FD Current Cars:2010 Mitsubushi Evo X GSR 2013 Subaru BRZ Sponsors:Mishimoto/Flossy/Tomei
Craig.tridentms@gmail.com |
#72 | |
Drives: 2013 BRZ Limited
![]() Like the sound? |
#73 |
TBBandit's FR-S MYBRZ V2 CAI System installed today (as well as Pulley):
| The Following User Says Thank You to xcelir8brz For This Useful Post: | Style (08-12-2012) |
#74 |
Drives: FRS
does the pipe step up to a larger size from the throttle body? or is the inlet of the throttle body the same size as the inlet pipe (3")?
#75 |
LXXXVI
Drives: Dahlia (Raven FR-S)
Whats the length of the long pipe?
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2 |
#76 |
#77 |
#78 |
MYBRZ CAI V2 is:
...to only a handful of people out there in the US.
#79 |
LXXXVI
#80 |
Nevarrrr!
#81 |
With this higher flowing than stock intake you can tell by the sound, from 6-7200rpm, that this car wants an exhaust to get rid of all the extra air. So looks like I will be getting a header back exhaust a lot sooner than planned :-)
#82 |
Oh and why take off the smaller piece of the stock box? I would think that helps guide the air more and more evenly. Is there a reason you took off the entire box?
#83 |
Re-member
Drives: Toyota camry
Can you guys show that the above intakes dont significantly alter the air fuel ratios? Also, a lot of the pics look like the intakes are able to pull a lot of hot air from the engine bay. The filters that are fully shielded will probably end up being restrictive due to the closeness of the filter to its housing. Cold air, to me, means at least as cold as stock. This is no bueno.
Nothing decays like progress, and nothing preserves like neglect.
#84 |
My original thought was the same. I modified it as the heat shield perfectly fit the stock CAI top and bottom and noticed increased air flow. We capped the heat shield as well.
| cold air intake? | carbonBLUE | Engine, Exhaust, Transmission | 72 | 09-30-2013 01:56 PM |
| FRS AEM Cold Air Intake | KenAEM | Engine, Exhaust, Transmission | 28 | 10-24-2012 01:48 PM |
| AIRAID FR-S / BRZ Cold Air Intake system Sneak Peak / Development Information | AIRAID | Engine, Exhaust, Transmission | 396 | 10-04-2012 08:27 AM |
| Takeda Cold Air Intake for the FR-S/BRZ at Redline360! | Redline360 | Engine, Exhaust, Bolt-Ons | 3 | 07-24-2012 02:34 AM |
| 2013 Scion FRS AEM Cold Air Intake | KenAEM | Engine, Exhaust, Bolt-Ons | 2 | 07-12-2012 08:30 PM |
