Old 08-01-2013, 02:57 PM   #71
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Originally Posted by Shep View Post
700 miles and I just noticed this. It drives me a little nuts because it's so predictable. I find myself counting down the seconds until it will tweet again.
Welcome to the forum. I was like that for a while too. It's weird, but after a while, I got so used to it and don't even notice it unless I remembered to hear it.
Sigh-on-Rice is offline   Reply With Quote
Old 08-03-2013, 01:01 PM   #72
Plasma
Drives: White FR-S
Hello all,
A few weeks ago I went to a meeting with a Toyota Rep, Toyota Engineer, and the NCDS Arbitrator. My case was stated as this: the sound wasn't evident on the test run, and for under the first 3k miles for me, and that I wanted it fixed. After that the engineer showed a large amount of data supporting the fact that it was indeed the AC compressor kicking on. There was a small video of it, charts showing when the sound was occurring and when the AC compressor was kicking on. (Those matched up, just to be clear). It was proven whole sale to us all that the AC compressor was the culprit here. We went on a test drive and the sound was very evident.
After all this the NCDS refuses to recognize my claim, and supports Toyota's position that the "problem", tweet sound from the engine, is indeed not a problem, and the car is working within factory specs. In short, Toyota isn't doing anything about it.
Plasma is offline   Reply With Quote
Old 08-21-2013, 06:11 PM   #73
Terrapin77
Terrapin77's Avatar
Drives: 2013 Argento FR-S
I have this tweet. It's annoying as hell when the radio is off. I'm thinking about putting some high temp sound deadener around the AC compressor and the HPFP, since I also have the crickets.
Sent from my XT912 using Tapatalk 2
Terrapin77 is offline   Reply With Quote
Old 08-21-2013, 06:42 PM   #74
strat61caster
strat61caster's Avatar
I'm curious if anybody has tried tightening the belt, the noise seems to be from the belt slipping on the pulley as the clutch engages. I might do it but it doesn't bother me enough to take a look.
ineedyourdiddly
Old 08-22-2013, 08:58 AM   #75
Mikem53
Drives: FR-S 6MT
You can't tighten the belt.. The tensioner keeps a certain preload on it.
I don't understand why people think there is a problem with it.. It makes noise in its operation. This car has minimal to no sound deadining material to quell any noises.. It's the nature of the beast.. Buy a Camry or a Lexus if these operational noisies bother you.. All compressors kick in and the clutches makes noises.. If you want quiet.. Buy a 4000 lb car with lots of padding and comfy seats..
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
jeffchap (08-22-2013)
Old 08-22-2013, 12:42 PM   #76
strat61caster
huh, how do you get the belt off? Now I want to go take my car apart... According to the manual you just unbolt the tensioner pulley and it magically comes apart.
Agreed that it's a pretty minor complaint.
ineedyourdiddly
Old 08-22-2013, 03:32 PM   #77
Mikem53
Drives: FR-S 6MT
You release pressure on the tensioner to remove the belt.
The tensioner maintains the belts tension...
Old 08-22-2013, 03:44 PM   #78
strat61caster
That implies you can ADD pressure on the tensioner...
ineedyourdiddly
Old 08-22-2013, 05:32 PM   #79
Mikem53
Drives: FR-S 6MT
as I mentioned before.. its preloaded, not adjustable as it is from the factory.
strat61caster (08-22-2013)
Old 08-22-2013, 07:16 PM   #80
Ozzman
Drives: old
No it doesn't. Then Tensioner is spring loaded, to remove the belt you put a wrench on the tensioner and move it backwards against spring pressure, make sure your other hand is free while doing this as you now have to use the freehand to remove the belt from a pulley while still holding the wrench against the spring tension of the tensioner.
Ozzman is offline   Reply With Quote
The Following User Says Thank You to Ozzman For This Useful Post:
Old 08-23-2013, 04:48 PM   #81
Rabble
Drives: Asphalt FR-S
I'm getting the same tweet noise. I'll let my service advisor know, but it doesn't seem like a big deal.
Sideways is a normal operating condition.
Rabble is offline   Reply With Quote
Old 08-28-2013, 09:28 PM   #82
MarkS
Drives: White FR-S
I noticed it for the first time on the long trip I took over the weekend. The car now has about 2000 miles on it. Not sure if I just didn't notice it before because I usually have the radio on or because it just started doing it recently. I got the car in the Spring so I've been pretty much using the A/C all the time.
Good to know I wasn't imagining it and that it's apparently nothing serious. What was puzzling was that it sounds very much like an electronic sort of sound, not the usual buzz or rattle or whatever. I checked my GPS, my radar detector, my watch, my phone... . Thought I was going crazy.
MarkS is offline   Reply With Quote
Old 08-28-2013, 10:18 PM   #83
Ozzman
Drives: old
I'm wondering if washing the engine bay/AC compressor will alleviate the noise. Just rinse it down with a very light spray of soapy water then clean water I think it may just be some dust between the AC clutch plate/pulley making the noise.
However do NOT use harsh soap and strong spray of water as you do not want force any water into the electronics and pulley bearings.
Old 10-13-2014, 06:24 AM   #84
juliog
juliog's Avatar
Drives: 86
I hate this noise...
juliog is offline   Reply With Quote
