Old 06-29-2019, 08:38 PM   #71
Viper8
Drives: Scion FRS
Sounds good. That's a great lap time by the way!
Viper8 is offline   Reply With Quote
Old 07-29-2019, 10:39 PM   #72
Viper8
Drives: Scion FRS
Since several lug nuts had froze up, I bought a round of ARP wheel studs and some 949 racing lugnuts. Removal and installation of the studs on the front wheels was pretty easy. Simply used a hammer to tap them out and then used some washers/nuts and an impact wrench to set the new studs.
Old 07-29-2019, 10:47 PM   #73
Viper8
Drives: Scion FRS
The rear wheels were a different story. There's not enough room behind the hub to install the longer studs I was using, so you actually have to remove the hub. The left rear actually removed pretty simply and only took marginally longer than the front. However the right rear ended up being a nightmare. The hub had rusted to the knuckle, and it took me over half a day of beating on it directly with a sledge hammer, a hardened steel chisel, and a bottle of PB blaster to finally get the thing out. A hub puller just couldn't hack it, and I started getting worried about damaging the cv axle and differential from the compression.
Once I finally got it out, I figured I had likely destroyed the inside of the hub I'd been smashing, so I ordered a new one. Meanwhile, I used a dremel to clean out the inside of the knuckle, applied some anti-seize to the new surface, replaced the studs when the new hub arrived, and reinstalled it. That one wheel turned what should've been a pretty uneventful job into an uber pain.
Old 07-30-2019, 10:36 AM   #74
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
I'm so glad my car came with studs already by the sound of it.
I think I'll be back out at Hallett on the 21st of September, you going?
captain awesome is offline   Reply With Quote
Old 08-02-2019, 01:13 PM   #75
Viper8
Drives: Scion FRS
I planning on being out either the 20th or 21st, unsure of my schedule right now.
Old 08-02-2019, 01:23 PM   #76
Viper8
Drives: Scion FRS
In an attempt to remedy my brake issues, I rebled the fluid, and replaced the DBA XP650 pads with Ferodo DS2500s (since I knew those worked well in the past). The front DBA pads were over half used up from a few months of DD and one track day (which was surprising to me too), whereas the Ferodos I had previously run lasted a years worth.
At the next Hallett track day, the brakes worked much better after bed-in and restored the confidence I was looking for. Managed a new best time going CCW of 1:38.7.
Old 08-02-2019, 01:40 PM   #77
captain awesome
Wears Pants
Hope to see you out on the 21st, but if you figure out early enough what day works best, I don't mind switching to the 20th.
What group are they putting you in?
Old 08-04-2019, 11:06 PM   #78
Viper8
Drives: Scion FRS
I should have a better idea in a week or so, but I'd say 90% chance I'll have to go on Friday. They typically put me in the A group (when there's A and B groups).
Old 10-03-2019, 11:31 PM   #79
Viper8
Drives: Scion FRS
I got this idea from a friend at the track, and it looks like a number of people have done this... Basically a poor man's cheap front brake cooling system courtesy of Porsche.
They are Porsche GT3 Brake Duct Spoilers and were only $30 for a pair. I think they just clip on the front of the control arms of the Porsche (require a little bit of finaggling to fit on the FRS) but seem to work well enough.
(Photo from https://www.suncoastparts.com/produc...GT3_ExteriorWW)
Old 10-03-2019, 11:50 PM   #80
Viper8
Drives: Scion FRS
It required some modification of the ducts via snipping off some edges and corners to make fit, plus some duct tape to block off holes, then a few zipties and presto. I also cut away some of the inside rotor shielding to allow more of the airflow to the rotor.
Old 10-04-2019, 09:27 AM   #81
captain awesome
Wears Pants
I've been considering these as well. Couldn't make it to Hallett on Friday, but managed to get out there Saturday. I got a 1:34.84, and I think there's a 1:33 or better in the car.
Did you end up getting out there Friday?
Old 10-04-2019, 10:42 PM   #82
Viper8
Drives: Scion FRS
Nice work! I was out there Friday - just missed ya again. What sort of tires are you running?
Old 10-05-2019, 05:28 PM   #83
captain awesome
Wears Pants
245/40/18 Falken rt615k+ on 18x9.5 Enkei NT03+m rims. KW v3 coils, Eibach sway kit, some Whiteline stuff, e85 OFT tune with catless header and midpipe. Stock exhaust from the resonator back to muffler. Stainless brake lines, EBC Yellowstuff pads, DBA T3 rotors, Motul RBF600 fluid Grimmspeed MC brace. Grimmspeed strut bar, Raceng cascam plates, Whiteline toe arms, SPC LCAs.
The Following User Says Thank You to captain awesome For This Useful Post:
Viper8 (10-06-2019)
daily driver, frs, naturally aspirated, oklahoma, track build
Mr. Frs Trd track build Mr.Frs Member's Car Journals 24 06-20-2018 07:20 PM
dp1 track build (NY) dp1 NY / NJ / CT / PA 114 07-19-2017 02:47 PM
Chronolgy101's DD and Track Build Chronology Member's Car Journals 1 04-21-2017 01:21 PM
What's your Track Build? neroman98 BRZ First-Gen (2012+) — General Topics 4 08-06-2015 05:16 PM
FRS Track Build smoltz Tracking / Autocross / HPDE / Drifting 27 07-08-2015 10:17 AM
