#71 | |
Drives: 2013 satin white brz limited
So I guess we will just wait for the inevitable my ebay this doesn't work or my kit from company x does not line up with my kit from company z what do I do now. |
| The Following User Says Thank You to jasonojordan For This Useful Post: | Tcoat (01-02-2018) |
#72 | |
Drives: 2014 BRZ
What I mean by that, is that MAP manifold may have the compressor outlet sitting X amount of distance closer or further away from where the FBM manifold would have it positioned. Or maybe the merge collector portion of the MAP manifold is shorter/taller than FBM's is, you never know. The FBM intercooler and charge piping was designed to fit the FBM manifold...that's not to say that the MAP manifold won't work but just because the components were made to be BRZ/FRS specific does not mean that different individual components are universally interchangeable. Folk cut the crash beam, or replace it because a large portion of the beam's real estate is in the way of the piping that goes to the inlet/outlet of the IC end tanks. FBM's kit does not require crash beam modification as the IC piping is located on the side of the IC, not a top fed type of deal like JDL/SBD/Greddy/Full-Race/MAP. Usually the shorter the IC piping is, the better the transient response will be....however I've heard from several with experience that the difference is negligible at most. I cut my beam, if I could go back in time I would have went for a longer/no-cut/through the headlight hole route.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
| The Following User Says Thank You to Amputechture For This Useful Post: | nickdd6237 (12-29-2017) |
#73 |
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
Piecing together a mismatched kit probably costs more than buying one thats already made.
| The Following User Says Thank You to mjanmohammad For This Useful Post: | FRS Justin (01-03-2018) |
#74 | |
Drives: 2013 Asphalt FRS
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#75 |
Drives: 2014 BRZ
If you ever in your life should listen to a random group of guys on the internet, let this be the time. Whatever amount of money you believe yourself to be saving will be completely negated once you mock up the piping and see that you are going to have big gaps.
Just because there are few hundred dollars less in your cart at checkout does not mean you are doing your budget a favor.
| The Following 8 Users Say Thank You to Amputechture For This Useful Post: | Alltezza (01-03-2018), FRS Justin (01-03-2018), Hades (01-05-2018), JazzleSAURUS (01-12-2018), Logikal Reazon (01-14-2018), mjanmohammad (01-04-2018), Tcoat (01-03-2018), ThatAsianBradah (01-10-2018) |
#76 | |
LISTEN TO IT The people that KNOW what they are talking about are advising against it. The ones that don't have a clue are saying go for it. There are reasons why particular parts are used in kits.
#77 |
Driver
Drives: 2013 Whiteout FRS
If I actually want to drive my car as soon as the turbo kit goes on and tuned. I would just buy a kit from a reputable brand, along with a good forum/online support. and save money, time and headache in the long.
those company did the research and development. the older you get the more you realized you always get what you pay for. piecing together a turbo kit with mismatch parts from different company, you'd probably have to cut/weld/modifying shit to make stuff fit, and that comes with a headache and your car probably be on jack stand for a while before you actually driving it. and that considered you know welding and fabrication, if not then you'd have to pay for shop time/labour. I'm not talking down on your decision, its your car. but you did ask for ideas and being realistic with money and time. its a no brainer to go with a kit like many other recommendation.
#78 |
Best help I can give you is, as I mentioned before I will sell you a complete JDL turbo kit with upgraded GTX3076gen2 and intercooler, that's ceramic coated for 5k only had 1200 miles on it
#79 |
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
Turbo Kit and Turbo buying spark notes:
- Make sure the turbos rotating assembly (everything that spins from wheel to wheel) is made from Garrett or Mistubishi components. As a newbie you should only concern yourself with turbos make with these parts only. Asking why to the wrong person will only lead a series of annoying and irrelevant side tangents. - Compressor housings don't matter as much and will most likely be an original, copied, modified or modified copy of a Garrett or Mitsubishi housing. - Exhaust wheel housing doesn't matter as much and will most likely be an original, copied, modified or modified copy of a Garrett or Mitsubishi housing. - Intake/Intercooler/Intercooler piping doesn't need to be worried about for a newb - Exhaust piping at its most basic level should be judged on the materials used for the piping and the quality of the welding done to mate those materials together. - Know what pressure the wastegate spring is set to open. - Learn how to read/translate whee sizes. What are the size differences (in millimeters) between a GTX2871, GTX2971 and a GTX3071? What are the sizes and size differences from a TD06SL2-18G and a TD06SL2-20G? What about from a TD06SL2-20G and a TD06HR-16G to a TD06SH-25G? This will give you a feel determining a turbos basic performance profile based on the intake and exhaust wheel dimensions. Knowing the above about a turbo or turbo kit will make you a better entry level turbo purchaser. Knowing the above would have also saved 5 pages of this dumb thread from being created. |
| The Following 2 Users Say Thank You to TachyonBomb For This Useful Post: | CSG Mike (01-05-2018), mjanmohammad (01-04-2018) |
#80 |
Lowly Cartuber
Drives: 2016 BRZ, 2005 Honda S2000
I think the OP forgot the most important thing that was said on the first page by CSG Mike. Take everything you know about turbo civics and throw it out the window. Peicing together a turbo kit in the 90's was how you did it. I had a custom turbo setup in my 95 GST. A lot of the parts were purchased separately and then pieced together.
That doesnt work on this platform. There is less space in our engine bays and so where you mount the turbo is key. How you route your piping, where you want to avoid heat soaks and so on. Every company does things differently and decides to sacrifice in places others may not choose to based on cost. Again, take everything you knew and throw it out the window. You are in different territory here. When reliable mechanics themselves are using turbo kits, there is a reason for that. I can guarantee that CSGMike or many of the other mechanics on here know how to fab a turbo kit together for themselves, theres a reason they chose not to do that. Listen to them.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
| The Following 4 Users Say Thank You to Xxyion For This Useful Post: |
#81 |
Drives: 09 vw gti
Ok so .57 or .72 a/r on a gtx2860?
#82 |
Not a troll
I don't think you're ready for a turbo.
| The Following 5 Users Say Thank You to Cole For This Useful Post: | arkanist (01-15-2018), CSG Mike (01-05-2018), scottman (01-09-2018), TachyonBomb (01-08-2018), ThatAsianBradah (01-10-2018) |
#84 |
Drives: 09 vw gti
| Mod ideas? | _anthonygd | BRZ First-Gen (2012+) — General Topics | 42 | 09-08-2015 07:28 PM |
| New Here Need Ideas | FRStrent | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 07-10-2014 11:22 PM |
| In Need Of Ideas!! | bh7990 | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 05-19-2014 01:14 PM |
| Turbo, white smoke out the exhaust, ideas? | Synack | Forced Induction | 44 | 09-09-2013 10:57 AM |
| Need ideas for possible (new-to-me) used car | suprachica79 | Other Vehicles & General Automotive Discussions | 66 | 02-20-2012 07:42 PM |
