#71 |
Drives: 2007 GT3 | 22' BRZ
BRZ tS upper arm rests and cluster visor just came in at work. Only a few things left to do the interior and I'll be done.
Was really bored at work so I also updated my build thread to have every single part number I could find to make it easier for people to source
#72 |
Picked up a Nardi sport rally deep corn 330mm with perforated leather, EVS Tuning carbon steering control adapter, some Rays plate frames, and my Bride interior boots came in.
Finished the installing the shifter boot and will probably install the e-brake boot sometime later this week. I really hate leather interior trims and try to avoid it as much as possible when it comes to cars so that's why I went with the Bride material for the interior. Pretty ricey but I'm Asian so it's ok. ![]() ![]()
#73 |
Another late night working on the car. I suck when it comes to working on my own car so the installs take me 3x longer than it should.
Bride shift boot has been applied, arm rests attached, cluster hood thing installed and frameless mirror put on. ![]() ![]() ![]()
#74 |
Drives: 2013 Brz
I always enjoy re going through this thread. If you don't mind answering, I seen you got the Subaru under panels. Did you order them locally in Canada or straight from Japan?
Curious if you still had the part numbers for the panels them selves and all the hard ware. I would appreciate any help, would save major on shipping if I can get them locally |
#75 | |
As for the parts here are the part numbers that you can use through Canadian Subaru dealers: Panels 56411CA000 56411CA010 42045CA020 42045CA030 Hardware 901000344 x8 909140065 x16 909140007 x4 023508000 x4 Always safe to buy some extra hardware just incase my number was wrong.
#76 | |
Drives: 2013 Brz
#77 |
TRD Edition dash panel finally came in. Need more suede pieces for the interior to finish everything.
#78 |
Drives: 2017 CWP BRZ Performance Package
Get better headlights, scrub!
#79 |
Woahhhhhh I'm getting there LOL
Once the weather gets above freezing I'll install the new ones!
#80 |
Installed some on the interior pieces and it looks ok so far but hard to tell without sunlight. Added an old HKS and Koyorad reservoir cozies because they are just laying around in my room.
#81 | |
Drives: 2013 SSM BRZ
btw, Great build so far! Can't wait to see the updated mods this season.
________________________________
instagram - @FL4TBXR |
#82 |
Thanks! I used a 921 if I recall correctly.
#83 |
I lied it wasn't that size. It's definitely a larger size. Once you get the Nsidius brake light I think I found the size on the bulb itself.
#84 |
A few parts arrived in the mail today. TRD rear aero stabilizer, key case for the Corolla, TRD bolts and TRD shoulder pads.
Also installed the door cards to complete the interior for now. Blacked out the speaker rings to match the rest of the interior. ![]() ![]() ![]() ![]() ![]() ![]()
| Tags |
| 14r, brz, frs, trd, voltex |
| My Asphalt FRS Build | ZaneRL9 | Member's Car Journals | 14 | 06-13-2015 03:38 PM |
| hattrickey's Asphalt Build | hattrickey | Member's Car Journals | 4 | 08-16-2014 12:00 PM |
| asphalt.frs.22's Evil fr-s build | asphalt.frs.22 | Member's Car Journals | 1 | 05-30-2014 07:21 PM |
| Opposed Asphalt build | Opposed | Member's Car Journals | 30 | 01-15-2014 11:03 PM |
| New FRS Asphalt build. | Erik-Frs | Member's Car Journals | 24 | 09-18-2013 08:18 PM |
