Old 08-03-2017, 07:01 PM   #71
StraightOuttaCanadaEh
Wes
Originally Posted by Shinigami301 View Post
Isn't that a legal requirement in some provinces?
No idea. Definitely not ontario
Old 08-06-2017, 10:55 PM   #72
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
I have run the 225 models and they were divine when compared to the Prius screamers. God I had a tire that screams that much when it breaks loose, pitiful. The Pilots are simply awesome in comparison. The 225 adds about 3/4" to the collective width. About 3/8" wider each.
Mine lasted me about 1 year and I drive hard. No track time here, just a 21 mile commute through the country 4 days a week with some decent corners. And of course lots of twisties.
Costco had the best prices, bar none.
As for reading deeper in this thread, awful snow tires. They work, but shopping cart wheels is spot on for characterizing them in snow.
jeepmor is offline   Reply With Quote
The Following User Says Thank You to jeepmor For This Useful Post:
dinfern22 (08-07-2017)
Old 08-06-2017, 11:46 PM   #73
MrsJames
So. Many. High-heels.
Drives: 2016 Halo FR-S
Originally Posted by kch View Post
I had 225 PSS for a while. Turn-in will feel slightly less responsive, but grip will be increased. Due to the increased diameter, your speedo will read about 1mph high at 70mph. Not a huge change. Don't expect any difference in acceleration, aside from the increased grip from a stop.
Edit: If you ever take these to the track, make sure you have at least -2.5* front camber. The outside edge of the PSS is made of a softer compound--if you don't have enough camber, you'll wear them bald on the edges.
And Costco will fight you AND American Express on the replacement...
MrsJames is offline   Reply With Quote
Old 08-07-2017, 12:13 AM   #74
icybrzzz
Drives: 2015 Scion frz
Not to thread jack....
But has anyone tried 205/45/17 on stock wheels? I'm assuming turn in would be better with a sticky 200TW tire.
icybrzzz is offline   Reply With Quote
Old 08-07-2017, 01:08 AM   #75
dinfern22
dinfern22's Avatar
Drives: 2016 Scion FR-S(Halo)
Wish my commute to work was this fun!
dinfern22 is offline   Reply With Quote
Old 08-07-2017, 01:12 AM   #76
dinfern22
dinfern22's Avatar
So I ended up cancelling my order of PSS in 225's and went with the 215/45R17.
Do you guys recommend I get an alignment done after the tire installation on my OEM wheels? Since owning my car I have never done one. My car has 15k miles on it.
If I do, i'm guessing they would have the cars specific factory specs on a computer, or do I have to give them specific numbers?
Old 08-07-2017, 04:55 AM   #77
churchx
churchx's Avatar
Drives: 2014 GT86
dinfern22: No need to change alignment on wheel or tire swap. With different wheels/tires alignment/geometry stays same.
(with exception when for some different alignment is needed to enhance wheel clearance due too wide wheels fitted for them to not rub).
You need one, when: 1) advised after initial car purchase, as stock can be rather not precise/out of whack, while still within ranges of 'passing', 2) if you install suspension parts of different properties then stock ones or installing which involves unbolting/retorqueing suspension, changing alignment in process (coilovers/springs/bushings/camberplates/control arms/etc), 3) if you had big hits to suspension and feel that handling started to acting up after that, 4) if you want different alignment then before (eg. more camber for more even tire wear at track, or different camber front-rear settings, to dial out understeer vs stock, or more stability under throttle with toe-in, or sharper turn-in with front toe-out, and so on ..)
Don't mistake though -car-alignment- with -tire-balancing-. Later should be done on any proper tire remount on wheel. Of course not when swapping to different wheels with premounted tires (balanced before), unless that balancing been long ago and something makes you think that they may benefit from that (eg. due uneven wear or bend somewhere you feel excessive vibration when driving with those wheels/tires).
The Following User Says Thank You to churchx For This Useful Post:
Summer Tire Options Splicer006 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 03-27-2016 09:46 PM
Bridgestone tire options Ludacrits Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 11-10-2014 01:03 AM
FR-S Front Lip, Options/ Suggestions? _j_anthony Cosmetic Modification (Interior/Exterior/Lighting) 5 07-11-2014 07:12 PM
Tire Shop Suggestions - Auburn, WA Akari Northwest 2 01-29-2014 05:35 PM
Tire Suggestions L3P47 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 04-13-2013 01:21 AM
