#71 |
Drives: GT86
Don't want to do adjustable coilovers. But since my summer touring tires grip all too well (tested similar to PS3), I'm might as well change to stiffer sidewalled sportsrubber, Bridgestone RE002 will be fitted once springtime arrives.
#72 |
Drives: GT86
Bridgestones were ok, very progressive once grip was lost, but a tad heavy so quite low on feedback and for my liking, a bit too much grip, low grip is just more fun.
Now I have these and save almost 6kg a corner compare to the stock wheel (18,3kg)... ![]() This change helps in improving feedback a lot and the car is much more consistent in how it loses grip, but once sliding plenty they are less progressive then the RE002. Still, the OP goals have been achieved. |
#73 | |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
#74 |
Drives: GT86
Tyre also plays a big role, as does geometry. And tyre pressures. Experimenting with the latter now. While higher pressures give a more direct and lightfooted feeling, I find it reduces grip feedback I get through the wheel.
#75 |
Drives: 13' Scion FRS Track car
any news on that electronic switch to control the power steering ?
#76 | |
Drives: BRZ Pearl White
Mostly though you are feeling the difference between electric servo and hydraulic servo. They are different but, truly the electric servo gives you more accurate steering feel than hydraulic it just takes getting used to the difference. In a few years no hydraulic servo will be offered on any vehicle. |
| The Following User Says Thank You to Ubersuber For This Useful Post: | Trettiosjuan (08-13-2014) |
#77 |
Drives: GT86
Not seen anything, but have since come to appreciate the weighting of the stock item. Some slight toe out up front has also added some welcome "weight" as it slightly loads up the sidewalls and makes them more communicative this way. How much depends on tire, don't want to introduce scrubbing/wear either...
#78 | |
Because compromise ®
Drives: Red Herring
"We have yet to drive a car that's been improved by electric steering, and driven plenty that have been ruined by it." http://www.edmunds.com/car-reviews/f...rsche-911.html "But as the 997's front wheels track the cambers and surface changes of the A413 on the way home and the wheel gently writhes, wriggles and tugs at my hands it just feels more alive and natural." (997s have hydraulic assist. My brackets.) http://www.pistonheads.com/doc.asp?c=52&i=26213 "During my eight-mile, speed-capped drive, it felt anesthetised. As if all the old 911 sensations had been numbed." http://www.richardaucock.com/steerin...v-ford-mondeo/
#79 |
Drives: GT86
The 991 GT3 also with EPS has been well received though...
#80 |
Drives: Red Herring
Sure, agreed. I was refuting Ubersuber's generalization that electric is better than hydraulic.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | Trettiosjuan (08-13-2014) |
#81 |
Drives: 2014 BRZ
Good luck finding tactility in any car this millenium. I found I lost steering feel when I canned the stock tires for Michelin Super Sports. taller 16s like you have a certainly a step in the right direction. But I think you are going in the wrong direction with AD08s. They have a square shoulder. Pirellis have a great over the road feel. Check out the Nero.
#82 |
Drives: GT86
I've got Goodyear balloon tyres now, very rounded. Very thin sidewall. Not very direct but there is a lot of grip information coming through the wheel, very confidence inspiring.
#83 | |
#84 |
Drives: Red Herring
Maybe if you install them yourself but if you have paid someone to install them and do an alignment then the GrimmSpeed bar is cheaper and made a bigger difference for me. Nice double post btw.
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 04:41 PM |
| Feel sorry for guys in LA | Pscylo | Southern California | 16 | 08-21-2012 11:26 AM |
| does rwd LSD feel the same as fwd lsd? | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 07-13-2012 09:04 PM |
| Steering Wheel Feel | ap5512 | BRZ First-Gen (2012+) — General Topics | 8 | 12-08-2011 12:16 PM |
| Stock suspension adjustability? | #87 | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 01-02-2010 05:36 PM |
