Old 05-13-2018, 07:38 PM   #71
Rasputin1969
Drives: Subaru
I have joined this forum. Not because I own an 86. But to gain more info or to share my experiences with Ecutek.
I currently own an Australian spec Subaru Levorg with the 2.0 litre DIT which is the same as in the current gen WRX.
I went the Ecutek route due to wanting an etune and it was one of the easiest way of achieving that with off the shelf items and software. Albeit a bit expensive.
After finding a tuner who was willing to take on the task after trying one who failed miserably. Things are beginning to progress nicely with my tune.
Due to the time difference of being in different countries we have refined our workflow quite well.
The Bluetooth dongle works brilliantly for this.
What we do.
1. Log using dongle.
2. Upload using phone to shared OneDrive folders
3. When a revised rom is available. I download from OneDrive to a laptop and flash the ecu.
4. Rinse and repeat.
No requirement for emails as we chat through messenger.
Rasputin1969 is offline   Reply With Quote
Old 07-19-2018, 08:23 PM   #72
B T
My program failed due to faulty connection just after starting. I now have it reading consistently, but it tells me my license is consumed and cannot write the full tune into the car. Is there a way to salvage the license from a partially written ECM?
B T is offline   Reply With Quote
Old 07-19-2018, 08:58 PM   #73
Tor
Tor's Avatar
Drives: Toyota GT86
Call Ecutek, they can do it remotely.
Tor is offline   Reply With Quote
Old 07-20-2018, 07:57 AM   #74
Kodename47
Kodename47's Avatar
Drives: UK GT86
On 1st write or subsequent flash? If the latter you can usually get around this by manually selecting the vehicle and flashing that way.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-20-2018, 01:31 PM   #75
B T
manually selecting did work after bending pins in the ECUTek adapter. Then it has problems with a missing license. ECUTek gave me a quick turnaround in getting a replacement license. It's working again, Thanks
The Following User Says Thank You to B T For This Useful Post:
steve99 (07-20-2018)
Old 07-21-2018, 02:34 PM   #76
djezlee
Drives: 2017 BRZ Limited
I was thinking about buying the ECU connect bluetooth interface, USB dongle and a license. Does the Bluetooth interface eliminate the need for both the OBDII cable and the software programing package?
djezlee is offline   Reply With Quote
Old 07-21-2018, 02:52 PM   #77
Tor
Tor's Avatar
Drives: Toyota GT86
Yes. You need RaceRom too if you want to do any editing yourself. If you get someone else to make the tune for you, you are set with that stuff you mentioned.
The Following User Says Thank You to Tor For This Useful Post:
djezlee (07-21-2018)
Old 07-24-2018, 03:59 AM   #78
cool7
Drives: BRZ WRB
If tunes are keyd to the dongle, what stops user from sharing the tune with another car if they buy another ecu license?
cool7 is offline   Reply With Quote
Old 07-24-2018, 06:49 AM   #79
tomm.brz
Drives: brz 2017 hksv2
Locked tunes don t open if you try to open them with a dongle that has a diffferent 6digit ID to the one they are keyd with
Open tunes open everywhere with every kit
Old 07-24-2018, 06:57 PM   #80
steve99
Thats possible but you have to ise dongle tune is keyed to, the tune is also not editable if its keyed so you cannpt open or change it jist flash it.
The second car would have to be same or compatable ecu calibration id and car have same mods
Old 01-27-2019, 05:49 AM   #81
Seba
Drives: BRZ Cosworth SC MY16
Hello,
I have got some questions about ecutek BT programming kit before I get the point of it.
I already have a SC and a tune flashed with ecutek proecu kit by a guy who had installed my kit. My ecu has been flashed, so the ecutek licence is already in it.
I want to do a data logging , send it to my SC vendor to check if everything is ok. If a tuner sends me a new updated map, I would like to flash my ecu myself.
As far as I know I need a BT ecu connect with programming, that should also include a deskey/dongle and a mini - usb cable. The dongle has it's own ID, that I will send to a master tuner.
Am I correct?
Seb
Seba is offline   Reply With Quote
Old 01-27-2019, 08:14 AM   #82
steve99
Originally Posted by Seba View Post
Hello,
Am I correct?
Seb
I have a blutooh kit amd yes it can flash via its mini usb portThe blutooth connection is for logging and interacting with tune via the blutooth ecutek app.
Ecutek now sell the blutooth kit with a dongle, you still need dongle and blutooth adapeter to flash a tune.
Ues you need to send the deskey dongle id to your tuner so they can key the tune to your dongle
h
Seba (01-27-2019)
Old 01-27-2019, 08:23 AM   #83
Seba
Thanks,
so, all I need to flash the ecu is: a BT device , mini usb cable, a dongle.
A BT device alone and Iphone/Ipad app is only for data loging, viewing and canceling errors.
If I want to flash the ecu, I will use a dongle, a cable plugged in to the BT device and a laptop.
My licence is assigned to my ecu, not to the previous dongle that had been used primary. My new map will be assigned to my new dongle ID.
Correct?
h
Old 01-27-2019, 05:28 PM   #84
steve99
Thanks,
Correct?
Yes correct
Ecu licience is universal can be flashed by any ecutel kit with dongle any id.
Tune files are usually keyed to a single dongle id. So if you change dongle id, you can no longer flash your old tunes untill tiner re keys them to your new dongle id, unless they were unlocked\unkeyed tunes but this is rare
Licience in ecu allws flash of thet ecu unlimted times
Seba (01-27-2019)
PTUNING Plug and Play WMI (Water/Methanol Injection) System and ECUTek Tuning ptuning Forced Induction 71 02-27-2019 08:55 AM
Works Axle Back Muffler Review (Works ABM) ButeraFRS Engine, Exhaust, Transmission 16 03-15-2018 07:23 PM
WORKS Exhaust System - Development 86_ZN6 Engine, Exhaust, Transmission 305 02-24-2014 05:57 AM
Borla UEL Header, works automotive parts and ecutek tune clayrush Engine, Exhaust, Transmission 14 06-27-2013 04:37 PM
subaru brz navigation system wire diagram? watching movies usb works !! SgtBolt Audio/Visual, Electronics, Infotainment, NAV 3 06-22-2012 12:31 AM
