Old 05-24-2017, 08:57 PM   #71
bhmax
Drives: 13 BRZ, 17 Focus RS
Has anyone had any luck ordering these recently? Sent a request a few days ago to MCA through their website but haven't heard back.
bhmax is offline   Reply With Quote
Old 05-24-2017, 09:00 PM   #72
Gforce
Drives: 2013 Subaru BRZ
They're a small outfit and often take a while to reply. Typical for Oz. Very laid back lifestyle. They will get back to you. Great guys to deal with.
They're probably out racing, that's what they do.
Also remember its always tomorrow there so avoid emailing them on our Friday or Saturday, they'll be closed.
Gforce is offline   Reply With Quote
The Following User Says Thank You to Gforce For This Useful Post:
bhmax (05-24-2017)
Old 06-05-2017, 09:44 PM   #73
bhmax
For those looking to get these, I still haven't heard back from MCA. I ended up ordering from MRT Performance.
Old 06-07-2017, 12:59 AM   #74
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
Unfortunate that they're $320 USD but if you convert the Australian pricr to dollars it's like $270.
ApexEight is offline   Reply With Quote
Old 06-09-2017, 03:41 PM   #75
cbryant514
Drives: 2016 Scion FR-S
I ordered my pair 5-24-17 and received them 6-8-17.
cbryant514 is offline   Reply With Quote
The Following User Says Thank You to cbryant514 For This Useful Post:
bhmax (06-09-2017)
Old 06-09-2017, 05:50 PM   #76
ApexEight
I took a left turn at an intersection pretty quickly the other day and was astonished at how much grip the car had; it felt like it was on rails. It felt like it hunched down and really grabbed the road. The thing is, I can't always replicate that feeling, even on the same turn. It's only happened once. The other times it just feels like all the weight and compression is on the front suspension and overworking the front tires while the rear doesn't hunch down and grip very much. I'm an ok driver with lots to learn. Will these help give me that "on rails" feeling? I crave it. I'm on stock suspension. 2014 FR-S 6 speed, relatively stock on all-season Toyos.
I've got a Strano front 22mm sway bar and camber bolts waiting to go in.
Old 06-09-2017, 07:38 PM   #77
Gforce
MCA brackets move roll stiffness forward a bit, that's how they get you extra traction.
The 22 mm front bar is pretty fierce for stock rear springs. Increasing front camber will help a bit.
Fitting Bilstein shocks will help a lot. The stock rear shocks are just not a good match for the stock rear springs. Had you not gone up to a 22 mm front bar (is the Strano solid or tubular?) I would recommend you consider fitting 2017 rear springs with the Bilsteins.
Softer rear springs get you even more traction but move the roll stiffness even further forwards. A stock 2017 rear bar (15 mm so about 30% stiffer) could help offset that if you went with the softer rear springs. Other aftermarket suppliers offer 16 mm rear bars, Whiteline's rear bar has three adjustment holes giving a lot of options in terms of total bar stiffness.
Also, be careful you don't confuse off camber road surface effects with roll stiffness effects. These cars are quite prone to drift a little on reverse or off camber turns.
chaoskaze (07-14-2017)
Old 08-24-2017, 02:06 PM   #78
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
Dumb question time: Would these have any benefit on a lowered car? Car already has adjustable trail, toe, and lower control arms. lowered maybe 2 inches or so on coilovers..
JeremyR is offline   Reply With Quote
Old 08-24-2017, 06:07 PM   #79
johan
Drives: '14 981CS, '99 NB1
The effect is diminished on a lowered car since lowering changes the angle of the rear trailing arms.
johan is offline   Reply With Quote
The Following 2 Users Say Thank You to johan For This Useful Post:
JeremyR (08-24-2017), kevaughan (04-26-2022)
Old 01-29-2021, 12:06 PM   #80
e30cabrio
e30cabrio's Avatar
Drives: 2017 86
Ordered this Wednesday, was quite the adventure as they don't have international shipping from the site. Process started Monday.
e30cabrio is offline   Reply With Quote
Old 01-29-2021, 04:04 PM   #81
gpvecchi
gpvecchi's Avatar
What are the defects of this mod?
gpvecchi is offline   Reply With Quote
Old 01-29-2021, 08:42 PM   #82
whataboutbob
AutoX-10/10ths every run
From my experience, it was cheaper to order this part from Fensport in the UK Vs. direct from MCA in Australia.
https://www.fensport.co.uk/collectio...ckets-gt86-brz
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Joon525 (01-29-2021)
Old 01-29-2021, 09:06 PM   #83
e30cabrio
e30cabrio's Avatar
Drives: 2017 86
I paid 360 USD shipped. That works out to 394.92.
That will allow immediate purchase as opposed I had to wait for them to generate an invoice, respond to questions and then pay via Paypal.
I might have preferred to pay the extra 35 bucks to not have to wait.
Old 01-30-2021, 09:54 AM   #84
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I believe it has a slight negative effect on roll center.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
gpvecchi (01-31-2021)
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 10:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Factory suspension "sticktion" andrew20195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 02:49 PM
"Official" Suspension/Brake Thread NYC BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 06-27-2012 09:14 PM
