Old 01-31-2017, 10:27 PM   #71
CHMBRZ
Drives: 2016 Subaru BRZ Limited
Ok cool thanks.
CHMBRZ is offline   Reply With Quote
The Following User Says Thank You to CHMBRZ For This Useful Post:
VerusEric (01-31-2017)
Old 02-01-2017, 01:15 AM   #72
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Originally Posted by Bramick View Post
Adding some more pics because I was getting questions.
This is the VOS with a JRSC setup.
First one shows you entire view. Hose 2 (from left to right in this pic) is the one vented to atmosphere. It goes under the car by the transmission. Hose 3 connects to the intake after the air filter and before supercharger. Hose 4 is down by the yellow oil fill cap. The rest of the pics focus on hose 4.
https://goo.gl/photos/5TpkXkBpk4nt9CCG7
My pointer finger is touching hose 4
https://goo.gl/photos/SpSCtdVDaM8x3nvJ8
Hose 4 is the one that is rerouted from the passenger side of the car per the JRSC install instructions. Its the one farthest away to the right of the yellow can and below the hose in the foreground. It has a 90 connector on it, so it can ran back behind the AC.
https://goo.gl/photos/X8cZR5ZMciQQkVWN8
In this pic you'll see a hose almost in the middle with a metal hose clamp. The hose 4 is right below it. It connects to the motor and does a 90 and runs straight down (this is towards the outside of the car on the passenger side. It then L's around and has a 4" or so before the 90 I was referring to the previous pic.
https://goo.gl/photos/dg4JGwEQx7pen5Lo6
can you show how you ran the hose that vents to atm? thanks !
Old 02-01-2017, 05:33 AM   #73
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
I just ran it out and down to the rear. It ends and zip ties close to the sway bar. Nothing special. The main thing was I didn't want it to hit my over pipe but be past the air inlet for the cabin.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
The Following 2 Users Say Thank You to Bramick For This Useful Post:
CHMBRZ (02-01-2017), Wes (02-02-2017)
Old 02-14-2017, 10:45 PM   #74
ka-t_240
How does this unit drain if you do not use the drain back feature?
Is their the option to purchase the full kit, drain, and cam cover together at any sort of a discount?
ka-t_240 is offline   Reply With Quote
Old 02-15-2017, 12:01 AM   #75
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
It comes with a -6AN female plug, which can be unscrewed to drain. The bottom of the AOS can itself is threaded for a Fumoto drain valve as well (not included) but can be purchased as an easier way to drain the AOS.
We do not at this time but we can try to work out something.
Thanks,
Eric
VerusEric is offline   Reply With Quote
Old 02-15-2017, 12:04 AM   #76
Ashikabi
Ashikabi's Avatar
Thanks,
Eric
When do you sleep?
The Following User Says Thank You to Ashikabi For This Useful Post:
johan (02-15-2017)
Old 02-15-2017, 12:40 AM   #77
VerusEric
VerusEric's Avatar
When do you sleep?
What is sleep?
I used to be a lot worse than I am now. I get at least 6-7 hours a night these days which is pretty good I think.
Going through college I went a full year on 4 hours a night on average. I do not know how I did it, nor would I recommend it to anyone.
Thanks,
Eric
The Following 2 Users Say Thank You to VerusEric For This Useful Post:
mrderp (03-08-2019), renfield90 (02-15-2017)
Old 02-15-2017, 01:07 AM   #78
Ashikabi
Ashikabi's Avatar
What is sleep?
Thanks,
Eric
I used to do that. It was awful. Never again
VerusEric (02-15-2017)
Old 02-15-2017, 06:41 AM   #79
canon_spec
Drives: FT86 GTS
Sorry if this has already being covered but any news re: compatibility for us RHD owners?
canon_spec is offline   Reply With Quote
Old 02-15-2017, 10:05 AM   #80
VerusEric
VerusEric's Avatar
It does not fit, the brake booster is in the way . It would require a different bracket and we haven't had the chance to look into that yet.
Thanks,
Eric
Old 02-15-2017, 10:14 AM   #81
BRZ FTW
Drives: 2017 Subaru BRZ
Thanks,
Eric
Also VERY interested in a full kit with drain back. I'm just a hair from hitting that checkout button.
BRZ FTW is offline   Reply With Quote
Old 02-15-2017, 10:50 AM   #82
VerusEric
VerusEric's Avatar
We can do 5% off on an AOS, Drain Kit, and Rear Cam Cover purchase. We cannot do this automatically through our website right now, so you'll need to e-mail us to make this happen. Sales(at)Velox-Motorsports.com
Thanks,
Eric
Old 02-15-2017, 07:18 PM   #83
canon_spec
Drives: FT86 GTS
Thanks,
Eric
If you need someone to take measurements and stuff to assist more than happy to do that. Us guys down under need this in our lives.
Old 02-17-2017, 02:09 PM   #84
VerusEric
VerusEric's Avatar
Could you send some pictures of this area to sales@velox-motorsports.com? I'm interested in figuring it out but without a RHD car anywhere near me to my knowledge, it's going to be a bit difficult.
Thanks,
Eric
Verus Engineering High Performance Radiator - Gauging Interest VerusEric Engine, Exhaust, Transmission 90 07-08-2023 07:43 AM
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 09:15 AM
Verus Engineering Billet Transmission Beta Tester Run VerusEric Engine, Exhaust, Transmission 62 04-26-2020 01:44 PM
Verus Engineering Carbon Thermoplastic Splitter Components VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 35 11-26-2017 05:23 AM
Raceseng | Revo Pulleys Information and Release Raceseng Engine, Exhaust, Transmission 3 10-09-2016 11:01 AM
