Old 02-07-2017, 11:09 AM   #71
Kris86
Kris86's Avatar
Drives: RHD Gt86
Originally Posted by 86Tony View Post
How did you kno to buy which bearing clearance and piston size??
We went with the standard size for both
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 02-17-2017, 04:36 PM   #72
BADAZZBRZ
Drives: 13' Turbocharged BRZ Limited
Nice build! almost my exact build except I went small at start with a gtx 2867. Same jdl kit and im built too check out my build on my ig @BADAZZBRZ ... I could definitely go up a turbo size and push 500-600s on my engine but still up in the air what I will do for transmission?... also with that much power you should go ahead and do the rear axels too.
BADAZZBRZ is offline   Reply With Quote
The Following User Says Thank You to BADAZZBRZ For This Useful Post:
Kris86 (02-18-2017)
Old 02-18-2017, 10:27 AM   #73
Kris86
Kris86's Avatar
Drives: RHD Gt86
Cool! I'll check out ur build on ig for sure!
Yeah I'm definitely gonna change the axles and driveshaft. Just wanna get her back up and running then I'll continue ordering goodies..
As for the transmission, into am kinda worried but, what the heck
Old 02-18-2017, 04:24 PM   #74
Kris86
Kris86's Avatar
Drives: RHD Gt86
Today's mission
Koyorad Radiator With @JDLAutoDesign slim shroud and Slap Fans
JDL crash bar
Pic of the HKS headgaskets before we put on the heads
Old 02-18-2017, 04:30 PM   #75
Kris86
Kris86's Avatar
Drives: RHD Gt86
We got the rest of the shims yesterday, so we are finishing up everything with the heads hopefully today
Old 02-20-2017, 07:54 AM   #76
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I have so many questions....
1) What compression did you end up going with? And why are you targeting that?
2) Did you crack open the block or are you leaving the bottom end alone?
3) Over the years and miles, how off was the valve lash?
4) 2017 aluminum plenum planning on going on before you finish up?
Btw very sexy radiator, I was just talking to the wife yesterday about getting 1 while i do the motor aswell.
This threads going to hurt my wallet!
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following User Says Thank You to GsxrMe For This Useful Post:
Kris86 (02-20-2017)
Old 02-20-2017, 09:54 AM   #77
Kris86
Kris86's Avatar
Drives: RHD Gt86
I went with CP 9.0 cr, decided to go that low because we don't have a set gas octane here, so just playing it safe in that aspect.
the block is built with Pauter Rods, CP Pistons, Kings Bearings, ARP case bolts (and ARP head bolts).
well, because we changed the valves, the clearance was off on 13 of them ,so had to order some shims to rectify.
no, plenum will be going on when I decide to go e85 after the car is up and running properly again. prefer to have Bill flown in to do the race fuel, so just gonna settle with the F&G for the time being until then
Old 02-21-2017, 08:58 AM   #78
BADAZZBRZ
Knock on wood... im still on my first transmission but im not out launching it often or pulling off hard in first and second.. if you don't beat it you should be good. you can get a used one fo 600-800$ so its not that costly to fix but just a pain in the ass.. especially if your like one guy I know making 500 on his 3rd transmission lol
Kris86 (02-21-2017)
Old 02-21-2017, 11:03 AM   #79
GsxrMe
GsxrMe's Avatar
For alot of us street guys aiming for 500hp and not seeing the track should help. Im personally going to allow tire spin to help from tomuch force on the drive train. The guys with awesome grip seem to be eating transmissions and what not.
2014 Subaru BRZ
Kris86 (02-21-2017)
Old 02-21-2017, 11:29 AM   #80
BADAZZBRZ
on e85 I should be 450 range at 18psi (haven't been dynod yet) made just short of 400 a few tunes back on 93 at 13-15psi. I haven't tracked mine yet either but wheel spin would definitely help. im running hankook ventus v12 285s in the rear and I break those pretty easy. back when I had fresh pss I wad hooking barely chirping first and second
Kris86 (02-21-2017)
Old 02-21-2017, 12:36 PM   #81
Kris86
Kris86's Avatar
Drives: RHD Gt86
this is very true, but I doubt to much traction will cause the forth gear issue gl
Old 02-21-2017, 12:37 PM   #82
Kris86
Kris86's Avatar
Drives: RHD Gt86
what turbo u running?
Old 02-21-2017, 12:56 PM   #83
Bfranklyn86
Drives: GT86 Harrop S/C
It's a good point this. I think leaving the grip quite low is a good safety feature for parts (if not for the driver!). For those of us on stock internals, the force that the tyres can hold surely translates pretty closely to the force put through the rods. I know other things are important, like propensity to knock, but still.....
No one ever really mentions this.
Bfranklyn86 is offline   Reply With Quote
Old 02-21-2017, 09:37 PM   #84
GsxrMe
GsxrMe's Avatar
Ya I like to follow the members that eat transmissions. Some are street and some are track. But having big fatty sticky tires seem to hold so much the stress is transferred to the axels and transmission, the two very weak points.
Seeing we dont have a vendor that can provide a bell housing, driveshaft for I dont know a T56 tranmission. I think ill just wait.
The sad part is members have a t56 and it holds up very, very well. But no one wants to reproduce this. The v160 option is not a good option for anyone wanting to keep the fa20 engine. Its just way tomuch money. Why the vendors clearly ignore this fact sickens me. One vendor almost had it but put a t5 transmission kit together instead. So close but half the torque rating and a 5 speed.
Call me crazy, I wish i had the tools to make it myself and sign up to be a vendor on the forums.
2014 Subaru BRZ
Kris86 (02-22-2017)
Who's tired of the "Pedal Dance" and wants to be in real control of their car? FT-86 SpeedFactory Tracking / Autocross / HPDE / Drifting 61 10-01-2015 07:44 PM
I drive fast because the car feel "slow" fang_gt86 Scion FR-S / Toyota 86 GT86 General Forum 65 05-04-2015 01:06 PM
Most effective ways to make a "fast" NA car Kronos Engine, Exhaust, Transmission 68 02-16-2014 01:59 PM
XSXV: Nissan R34 Skyline from "Fast and Furious" goat_cheese Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 29 10-25-2012 04:15 PM
come and hoon they say.... it will be "like Fast and the Furious", they say... davey90 AUSTRALIA 5 10-23-2012 12:11 AM
