Old 08-14-2012, 10:52 PM   #71
pinoyplaya
Drives: WRB MT-BRZ LMTD
Is it me or is the oil filter located on the top slightly above the engine (level wise)?
I can sense a huge mess
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM
Traded for Black 2013 Camaro 2SS RS
pinoyplaya is offline   Reply With Quote
Old 08-14-2012, 11:14 PM   #72
NRGBalanced
NRGBalanced's Avatar
Drives: '13 Subaru BRZ Limited WRB
Did my first oil change last weekend. My ramps just cleared the front air dam with no scraping. I took the time to install a Fumoto valve as well. Could be just my car, but I wasn't particularly pleased with where the lever ended up. The valve is almost upside down, to the point where the oil coming out will just clear the release lever mechanism. I tried rethreading it a couple times, and decided it was good enough. Just wish it was right side up
Anyway, thanks to Draco for the tips. The drip pan suggestion in particular was a big help. I've changed my oil before in other cars, but this went even smoother!
NRGBalanced is offline   Reply With Quote
Old 08-14-2012, 11:38 PM   #73
Jayde
Jayde's Avatar
There's a cup/lip around the oil filter that helps prevent messes. Just make sure you drain the oil first.
Jayde is offline   Reply With Quote
Old 08-14-2012, 11:53 PM   #74
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Use a washer to space it on your next oil change.
Old 08-16-2012, 12:04 AM   #75
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Thanks Draco for the advice. I did my first oil change today. Thoughts and observations here
http://www.ft86club.com/forums/showp...6&postcount=38
Here are some pictures of the drain valve installed since it was discussed previously in this thread
20120815-FirstOilChange-3 by VictorN07, on Flickr
20120815-FirstOilChange-1 by VictorN07, on Flickr
Tip of the spring clip barely sticks out. I could probably rotate it so it doesn't do that.
20120815-FirstOilChange-6 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
Old 09-13-2012, 08:47 PM   #76
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
Awesome thread!
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 09-18-2012, 08:12 PM   #77
zoomzoomers
Just ordered the Fumoto valve (F-108S) and 12 qts of Royal Purple 0w20 motor oil. I'm probably going to just take her into the dealership and have the oil & filter changed, but ask them to use my oil and install the Fumoto valve. I just hope it will all go as planned. From what I've read on Subaru dealerships I don't have much confidence in their work or character, but will give it a try. Wish me luck!
Old 09-23-2012, 02:26 PM   #78
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
For those ordering the Fumoto valve, you can get 10% off using coupon code YM4. Its only ~$2 off, but every little bit helps
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 09-23-2012, 03:03 PM   #79
zoomzoomers
Already ordered mine, but good to know for those who haven't yet.
Old 09-23-2012, 05:59 PM   #80
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Originally Posted by Draco-REX View Post
Advance Autoparts (.com) should have everything you need. I know the stores out here stock everything. 0W-20 is harder to get. Mobil1 (not recommended for Subaru engines) and Castrol Edge Titanium. You can also use 5w-20, especially in the summer, the operating weight will be the same. I put 5w-20 Pennzoil Platinum in mine at my last oil change.
Why is Mobil 1 not recommended for Subaru engines?
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 09-23-2012, 06:01 PM   #81
zoomzoomers
Do a search on this. There is some detailed info on the reason. From what I've read, previous Subaru owners have had issues with other Subaru boxer 4's eating Mobil 1 at excessive levels. Then again, there are others who have said that they've never had an issue with Mobil 1 too.
Old 09-23-2012, 06:15 PM   #82
Bristecom
Bristecom's Avatar
That may have been a problem for some in the past but I mean, this is a pretty different engine that is naturally aspirated and is designed for 0w-20 oil. I have a hard time believing it's as simple as Mobil 1 isn't good with Subaru engines regardless of the variables. But if a bunch of people start posting on here that they're losing their Mobil 1 oil at alarming rates and don't have that problem with any other brand of 0w-20, then I'll believe it.
Toyota + Subaru =
Old 09-23-2012, 06:25 PM   #83
zoomzoomers
I'm actually with you on this. That's why I'm planning to try Mobil 1 when it's time to replace the RP I'm going with for my 1st change. I'll have to see for myself if it holds water. I've never had a single issue with Mobil 1 and don't see why I would with this car.
Old 09-23-2012, 06:58 PM   #84
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
You mean you want evidence before you start forming beliefs?!? That's crazy talk.
Phaedrus29 is offline   Reply With Quote
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 02:27 PM
Toyota Holds "FT-86 Fastest Painted Website" Event to Help Launch FR-S / FT-86 Snoopyalien24 Scion FR-S / Toyota 86 GT86 General Forum 35 11-26-2011 07:56 AM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
