07-24-2021, 10:47 PM | #71 |
Drives: Q5 + BRZ + M796
Not going to happen. I’m not using CAD or machinery or anything special. Just basic tools, so there isn’t much to sell or intellectual property to license, but thanks for looking out.
07-25-2021, 07:58 PM | #72 |
Persona Non Grata
Drives: '15 BRZ (WRB)
Rats. I was going to call dibs.
Slow is smooth, and smooth is fast
07-26-2021, 12:10 AM | #73 |
Here is the finished placement. Yes, I plan to use the stock airbox with a K&N drop in filter. I like an OEM look. That may sound contrary to this entire thread, but I like minor, tasteful modifications/alterations. The stock airbox was good for enough power to break my previous motor, so it should be fine for what I am planning. I think these large cone filters exposed in the engine bay aren’t ideal or necessary. I also don’t think a giant airbox like what is on the Edelbrock kit is necessary. Maybe it is, but the turbo inlet is only 3”, so there is only so much size that could be utilized.
There may be clearance issues with the motor, so I may need to modify things. The IC pipes should clear/route fine.
The Following 3 Users Say Thank You to Irace86.2.0 For This Useful Post: |
07-26-2021, 07:55 PM | #74 |
I sent another courteous and concerned email to my fabricator at Black Market Fab. I was concerned something happened, and if so then I was going to have to contact my bank. Fortunately that spurred a quick reply, but sadly there was some family issues. I should be getting a tracking number by the end of the week. It is just two weeks later than I thought and going on over two months since my order. Ugh.
Still no word on the crash bar. Double ugh.
07-31-2021, 12:44 PM | #75 |
Drives: RX-7 / BRZ
How's the durability on the wrinkle red? Will it take a falling screwdriver or a hose/wrench swiping across it?
I always wanted to disassemble one of my superchargers and do it in red, in the style of the OEM 17+ intake manifolds. Couldn't find anyone locally who would do a low-bake powdercoat for it and was recommended VHT.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
07-31-2021, 02:35 PM | #76 | |
It isn’t a crumble type of finish like on Ferraris or textured like on the OEM manifold or like on my old Harrop supercharger. It is wrinkle like there was excess paint that pulled in on itself. Wrinkles like wrinkles. It won’t look show finish sharp, but from a distance it looks nice. The consistency of the finish will depend on technique and conditions. Overall, for my first attempt, I’m happy with the results.
08-02-2021, 07:39 PM | #77 |
I just Drive.
Drives: in the womb still
Realtime racing uses an older NSX OEM airbox for there J-series race cars I think. So you should be just fine with a drop in air filter.
This thread makes me tingle all over.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project |
The Following User Says Thank You to Swift For This Useful Post: | Irace86.2.0 (08-02-2021) |
08-05-2021, 01:50 PM | #78 |
Drives: 2013 FRS
From a fueling standpoint, what are your thoughts so far?
I'm also working on putting together this swap right now, and I'm thinking that a setup with the stock fuel container/hanger with an upgraded pump, a Hybrid Racing "Universal" fuel pressure regulator, and a K-Tuned fuel rail set up to be returnless. Seems to be the most straight-forward way to do it IMO. Cheers! |
The Following User Says Thank You to Atlas_86 For This Useful Post: | Irace86.2.0 (08-05-2021) |
08-05-2021, 02:38 PM | #79 | |
The stock FPR is in the fuel tank. I don't know that an aftermarket one is necessary. People have made over 500whp using the stock system with just injectors and a fuel pump, meaning they didn't change the FPR or switch to a return system. Seems like people start moving to surge tanks and dual pumps and larger lines or whatever on much more powerful and extensive builds than I am planning. Keeping it simple: I think I will have the larger injectors, Kpower fuel rail, -6AN line and DW300C.
08-10-2021, 03:33 PM | #80 |
I purchased a Drift Armor crash bar on 5/28 direct from Drift Armor. At the time of purchase, there was no indication the item was backordered or delayed, so I assumed the regular build time was accurate. I reached out over a month later passed the build timeline, and I was told there was delays, and the bar would most likely ship at the end of July. I said ok. Three weeks later I followed up to see if we were on track, but I didn't get a reply. Then early in August I reached out with no reply on the first and fifth. I decided I should put in a dispute before putting in a claim. I finally got a reply that my emails went to a junk folder and that the batch would be 1-2 weeks out plus shipping. I was asked to cancel the dispute, but I said I couldn't because I have 20 days to file a claim, and if I cancel the dispute or the dispute expires then I can't file a claim. I said the 20 days is within the window of 1-2 weeks, so no worries, and I would cancel after I received a tracking number, or they could refund me, so they decided to refund me, fearing the timeline would possibly get pushed back further. Probably for the best.
Long story short, I need a crash bar after waiting two and a half months for a crash bar. Silver lining. I am suppose to get my turbo manifold today. I'm just hoping it is the quality I expect because I was dealing with a similar situation of poor communication and progressive, "we will ship in a week" type of promises that didn't follow through.
08-10-2021, 05:17 PM | #81 |
I got the manifold and downpipe in, and it looks very nice. Fitment on the recirculation pipe and downpipe was as good as someone could expect like 98%. I mocked everything up, but I need to pull it off to clean it and everything before a final install, and I need to clock everything perfectly, so I can then order the AN lines. Overall, worth the wait and some headaches along the way.
The Following 5 Users Say Thank You to Irace86.2.0 For This Useful Post: | BrahmaBull1990 (08-12-2021), Dzmitry (08-11-2021), norcalpb (08-11-2021), pgranberg11 (08-16-2021), villainous_frx (08-20-2021) |
08-10-2021, 10:42 PM | #82 |
I just Drive.
damn the wrinkle red looks fiiiiine
The Following User Says Thank You to Swift For This Useful Post: | Irace86.2.0 (08-11-2021) |
08-11-2021, 12:30 PM | #83 |
Damn wish I drove up to get the overpipe to check this beast out!!
The Following User Says Thank You to norcalpb For This Useful Post: | Irace86.2.0 (08-11-2021) |
08-12-2021, 11:23 AM | #84 |
I ordered a front crash bar from True Focus Fabrication. They said they will get it out by 8/20. I should have started with them.
Tags |
worst.build.ever. |
Similar Threads | ||||
KPower Industries K24 swap | PulsarBeeerz | Engine Swaps | 1759 | 05-13-2024 02:32 PM |
Irace86.2.0 Build | Irace86.2.0 | Member's Car Journals | 195 | 03-25-2024 12:29 AM |
Turbo or swap | Fastend | Forced Induction | 35 | 06-11-2020 07:12 PM |
Built Turbo K24 Swap? | Calmwhiteguy | Engine Swaps | 31 | 02-13-2018 05:07 PM |
IRACE86's Build | Irace86 | Member's Car Journals | 25 | 01-10-2017 04:35 PM |
