Old 05-01-2019, 02:12 PM   #8331
sroby
Drives: 2015 Firestorm 08/05/15
Jflogerzi, I could nev r get the catch can from blowing oil everywhere on full boost runs. I got frustrated and pulled mine off, have you had any oil leaking on yours?
sroby is offline   Reply With Quote
Old 05-01-2019, 02:13 PM   #8332
jflogerzi
jflogerzi's Avatar
My buddy will be doing more tests this AM. Let you know over the next week
2013 Series 10 FRS #553
Old 05-01-2019, 02:21 PM   #8333
sroby
Pls do. I’m afraid it will. What you should do is take some good absorbent rags and stuff them along the side at the bottom of the blower housing intake. If it blows out. It will follow the passenger side fuel rail. Drip down on top of the over pipe, it can be a safety hazard. Not to mention a pain in the ass to clean all up. Just be advised and pay special attention in this area. ��
Old 05-01-2019, 02:59 PM   #8334
BRZ Guy
Drives: 2018 BRZ
That looks Awesome!!!
By FAR the best looking of all FI kits for these cars.
You tune it yet?
BRZ Guy is offline   Reply With Quote
Old 05-01-2019, 03:04 PM   #8335
jflogerzi
jflogerzi's Avatar
Working on it with Mike from xero-limit aka Moto east
Old 05-01-2019, 03:08 PM   #8336
BRZ Guy
Drives: 2018 BRZ
Makes me wanna sell my gold teeth and order that Sprintex.
Old 05-01-2019, 03:26 PM   #8337
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by jflogerzi View Post
officially add me to the list. better late than never
What is that coming off the side of the blower in the 1st and 3rd but not 2nd pic?
Old 05-01-2019, 03:28 PM   #8338
jflogerzi
jflogerzi's Avatar
Breather to prevent oil consumption in the super charger. Made by Jon bond
Old 05-01-2019, 08:22 PM   #8339
jflogerzi
jflogerzi's Avatar
What the recommend belt for this kit. I bought it used and the belt included is sweaking pretty bad.
Is the Gates belt K061015RB blue color belt the recommended one to get? I have the 72.5mm pulley and might try the 70mm that was included down the line.
Old 05-01-2019, 08:40 PM   #8340
SpeedWi
SpeedWi's Avatar
Drives: 2014 BRZ (SOLD)
Gates belt K061015RB blue color belt. I have the 72.5mm pulley and might try the 70mm that was included in the use kit down the line.
Check the idle pulley. The one you install. May be squeaking and need some lube.
Sent from my SM-G960U using Tapatalk
Supercharged 2014 DGM Limited
SpeedWi is offline   Reply With Quote
Old 05-01-2019, 08:41 PM   #8341
jflogerzi
jflogerzi's Avatar
If not I just want to be prepared with a new belt and the correct one
Old 05-03-2019, 02:51 PM   #8342
jflogerzi
jflogerzi's Avatar
So far no leaking atm. I have done some WOT's but waiting to get tune finalized to really push it for sustained time.
Old 05-04-2019, 10:39 AM   #8343
jflogerzi
jflogerzi's Avatar
I ran into something similar. Does it happen if you wiggle the wire harness that connects to the sensor on the intake manifold?
Hey what did you do to fix this? I am seeing this exact problem and was wondering how did you fix?
Old 05-04-2019, 11:09 AM   #8344
SpeedWi
SpeedWi's Avatar
I zipped ties the wiring harness to the strut brace. Kept it off the engine and prevented it from moving around
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
