Old 04-11-2019, 05:16 AM   #8303
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Exciting!
Sent from my HTC6525LVW using Tapatalk
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 04-11-2019, 11:14 AM   #8304
sqd
sqd's Avatar
Drives: '13 SWP GT86
Originally Posted by riboyster View Post
That's gnarly. How does that even happen?
Shipping, most likely. I certainly didn't damage it, noticed it during install.
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
Old 04-11-2019, 03:38 PM   #8305
jflogerzi
jflogerzi's Avatar
I am guessing they are gonna start selling smaller pulleys since you can't find them new anymore. But I am not sure what else they can do... As the blower is pretty well maxed with the old 69mm pulley.
2013 Series 10 FRS #553
Old 04-11-2019, 04:13 PM   #8306
sqd
sqd's Avatar
Are you on a built bottom end with the 69mm? I have a Raceseng 72.5mm and will be running on straight E85.. I want to make some power, but safety/reliability is number one.
I'm confident @Xero-Limit that will be tuning it will do a fine, fine job anyway
IG @squareddesign
Old 04-11-2019, 04:29 PM   #8307
jflogerzi
jflogerzi's Avatar
No I have the 70mm and 72.5mm. most ppl say the 72.5 is going to best option as keep power band as close to stock. Yes Mike will be doing my tuning just debating which pulley to use as I bought this kit used from a member here and he has both plus the stock.
Old 04-11-2019, 08:34 PM   #8308
riboyster
riboyster's Avatar
Agreed, 72.5 is my favorite. Keeps the max power up high but still starts to pick up around 3k.
Didn't have nearly as much fun with the 69 because the power band seems to promptly plateau at 5k.
Old 04-11-2019, 10:09 PM   #8309
86TOYO2k17
Drives: 2017 toyota 86
What gas will you be running?
Old 04-11-2019, 11:11 PM   #8310
jflogerzi
jflogerzi's Avatar
E85 most of the time or some blend. At track not sure but some lower blend snice I will have flex fuel
Old 04-12-2019, 01:13 AM   #8311
86TOYO2k17
With E85 you should be able to use the 70mm pulling no problem. If pump you may find the 72.5mm to be a better fit
Old 04-12-2019, 01:23 AM   #8312
jflogerzi
jflogerzi's Avatar
I think I will go with the 72.5 as there will be times where I will want to run 91. There is what 10-20whp difference between pulley? But I will talk with Mike and kinda see what he thinks.
Old 04-12-2019, 01:27 AM   #8313
86TOYO2k17
Good idea follow his suggestion. He tuned mine with 72.5mm + wmi.
Old 04-12-2019, 11:59 PM   #8314
brybot
Drives: 13 DGM BRZ 6MT
Hey everyone, wanted to see if anyone here had torn down one of the SC units, or better yet, had replaced the bearing seals inside. My unit is leaking a decent amount of oil into the manifold, fouling up my spark plugs and causing a misfire. Took it upon myself to tear it down, and have paused at one of the big impeller bolts because it didn't come out with an impact driver. https://imgur.com/a/4g7SiWk is the image. Wondering if its reverse threaded? Not sure why it would be tighter than the other. Next attempt is going to be big breaker bar with a pin wrench for those two holes.
Any help is welcome!
brybot is offline   Reply With Quote
Old 04-13-2019, 12:23 AM   #8315
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Jon Bond Performance can service these units stateside. These types of leaks we haven't seen much of, but I'd give them a call and take care of it before there's any major issue.
Xero-Limit is offline   Reply With Quote
Old 04-13-2019, 07:14 PM   #8316
brybot
Appreciate that, but JBP rebuilt mine when I purchased it used two years ago. The catch can and sight glass they installed leaked, and the copper tubing it was fixed to actually sheared off when I touched it, so I'm not terribly impressed with their work. He also wouldn't answer my questions about these issues. I understand they're busy, but I'm not motivated to go back to them.
Not that I won't send to them before I dumpster the whole thing, but it seems worthwhile to attempt myself before I resort to it.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
