Old 10-04-2018, 07:31 AM   #813
johl
johl's Avatar
Drives: toyota 86
I’ve been trying to research the difference between the jdm version (part number 12001-at012) and the US only v3 (part number 12001-kt003a)
They all seem to use the same super charger so I’m not sure what the difference is
johl is offline   Reply With Quote
Old 10-04-2018, 09:22 AM   #814
tomm.brz
Drives: brz 2017 hksv2
kt003a (with flash editor) and kt003 (withou flash editor) seem to use the supercharger part of v2 12001-at009 kit, the "old" grey one
12001-at012 also called GT2 supercharger, uses the new black gt2-7040L supercharger
apparently improved reliability, and better look, same price
The Following 3 Users Say Thank You to tomm.brz For This Useful Post:
FT86Z (08-26-2023), johl (10-04-2018), weederr33 (10-04-2018)
Old 10-04-2018, 04:14 PM   #815
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I really hope the updated version turns out more reliable in real world application. One reason I was hesitant about this kit was because of various reliability issues. So this news pleases me.
MS, CSCS, TSAC-F, CPT
Old 10-04-2018, 05:05 PM   #816
johl
johl's Avatar
Drives: toyota 86
Is the flash editor worth it or is it better to just use ecutek?
Old 10-05-2018, 02:02 PM   #817
tomm.brz
flash editor is only for JDM or USDM, dont know if you could use it in australia
anyway it s very expensive and you need HKS master tuner to do even small modification, like to let a MAP 3 bar work, even OFT is better than that then :P
The Following User Says Thank You to tomm.brz For This Useful Post:
johl (10-05-2018)
Old 10-10-2018, 12:50 PM   #818
killsafkat
killsafkat's Avatar
Drives: 2013 GT86
@Kylebrz any update with fixing the supercharger issue?
I was driving around city at night, pushing the car a bit, and after a while the HKS V2 supercharger just stopped boosting, ther was no weird noises, i check the vacuum line, and the traction fluid reservoir, everything seems fine. So i am guessing the issue is the same as the ones discussed before.
So has anyone came up with any solutions?
killsafkat is offline   Reply With Quote
Old 10-10-2018, 12:56 PM   #819
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
How is your SC mileage? Oil grade? Belt maintenance and tensioner are OK?
Inviato dal mio SM-G960F utilizzando Tapatalk
Trap63 is offline   Reply With Quote
Old 10-10-2018, 02:30 PM   #820
killsafkat
killsafkat's Avatar
Drives: 2013 GT86
Sc mileage around 10,000 km, belt tore on me 4 times, replaced with hks 6pk2110, but last one i used 6pk2100 as i couldnt get hks on time. It was a snug fit with a few degrees of play left in the tensioner. Running on 0w30, i always keep an eye on the oil temp and pressure.
The Following User Says Thank You to killsafkat For This Useful Post:
Trap63 (10-13-2018)
Old 10-20-2018, 07:14 PM   #821
ZEP
ZEP
Drives: Toyota GT86 black MT
My HKS SC died after 3 years, 33000Km and 10 track days. The same symptoms of the others on this thread
Still no reliable fix ?
ZEP is offline   Reply With Quote
Old 10-23-2018, 11:19 AM   #822
wbradley
Sarcastic SOB
wbradley's Avatar
I think HKS did reinforce the threaded part of the annulus which has been prone to failure in several cases. It would be helpful if someone at HKS did actually confirm this but I don't think they'd continue to sell failure-prone components.
My replacement supercharger has been fine this year and I suspect with a bit of care should remain that way.
You will need to purchase a replacement blower and traction fluid.
Old 10-29-2018, 03:12 PM   #823
killsafkat
killsafkat's Avatar
Drives: 2013 GT86
I opened the supercharger, and its the same issue, the threads gave out, someone is making the plate with a better material. Will keep everyone posted.
I need traction fluid, but when i search online, there are two types, low viscosity and high viscosity, which one is for the V2?
Old 10-30-2018, 04:06 PM   #824
wbradley
Sarcastic SOB
wbradley's Avatar
High viscosity for hot climates, low for cooler climates.
Old 10-30-2018, 09:04 PM   #825
weederr33
weederr33's Avatar
Hmmm I'm wonder when the GT2 kit will come to the US. I'm curious of the improvements it's supposed to have.
Old 11-22-2018, 12:52 PM   #826
xcuz31
Drives: white frs
How reliable is v3 with OTS tune and is it ok to run 91 tune with 93 octane gas
xcuz31 is offline   Reply With Quote
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 02:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 10:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 10:37 AM
