#813 |
STX 188
Try using higher octane?
#814 |
So elite I'm 1338
Drives: WRB Subaru BRZ
#815 |
Drives: '13 BRZ Ltd
#816 | |
Drives: '13 BRZ Ltd
#817 |
AutoX Nut
Drives: 2020 Toyota Supra
Yep, for my last event, I ran my tank down empty and put in 2 gallons of 100 Octance gas (even though I'm tuned on 93 octane). Still knocked while on course. Never knocks going WOT in straight lines whether I use 93 octane or 100 octane.
#818 | |
AutoX Nut
The other thing is that there isn't a particular RPM range that is problematic. There's a little bit of knock everywhere between 3500 and 7500 (I raised the rev-limiter a little from stock). |
#819 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
Fuel starvation maybe?
#820 |
AutoX Nut
I haven't noticed any fuel starvation during my runs, but I did think about running a little more in the tank next time. I usually run near empty (just before the gas light is on), so thanks for that suggestion. It's certainly worth a shot.
#821 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
These cars have been noted as running really well when low on fuel so I'd be interested to see if that is the case.
I'm curious if it is to due with temperatures. Specifically oil temperature. Excuse my ignorance in tuning but doesn't the ECU have the ability to pull timing to create less power when oil temps are up? Outdoors on a hot day, on boiling pavement/concrete, I'd bet it's much hotter than dyno pulls. Coolant and EGR temps too but primarily oil focused as these cars get stupid warm oil temps without a cooler.
#822 | |
Drives: 2024 GR86/ 2015 FRS
These cars Do Not fuel starve....Last week we ran the car really low so we could switch to 100 octane. The needle was lower then I ever saw it before and no problems. Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts |
#823 |
Dodging cones
I was WOT on the highway one day, moments before I ran out of gas. Not my proudest moment but someone had to pass that b hogging the left lane.
Point is, it pulled well to the redline.
#824 |
So elite I'm 1338
Rule No. 1 in Dizzle's book: Performance Driving on a Budget:
1. Be faster than the needle |
#825 | |
AutoX Nut
With that said, even with the temperature compensation tables pulling timing, the engine may still be susceptible to knock at high temps, so I'll definitely compare my data logs more closely to see how the temps of my AutoX runs compare to the temps of my dyno pulls and road pulls. Thanks for pointing that out. |
#826 | |
Drives: '13 BRZ Ltd
Have you had a chance to log the stock tune to see if it behaves the same way during an autocross run? I know in my STI the normal road log (pull from 2000 to redline) rarely showed any knock events but during my autocross runs I'd get -1.4 and -2.8's popping up, FBKC and FLKC, and really nasty stuff bouncing the limiter (up to 8 degrees of correction). Never saw IAM drop though. |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
