Old 12-06-2018, 12:27 PM   #8233
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Originally Posted by sqd View Post
Thanks anyway!
But I don't think the NACA duct is a problem, it sits too far back to be an issue with the pulley on the charger.. Considering that people run the Sprintex with different types of strut bars, I'd imagine that without a strut bar, the NACA duct wouldn't hit the charger.
But I would like to make sure too, of course
My strut bar sits at the back of the supercharger... not near the front where the pulley is... and the pulley is rubbing lightly on the heat pad thing on the stock bonnet/hood.
So doubt a strut bar is a problem, it’s the part where the hood curves down towards the front bumper you’ll need to check.
Your varis hood is great!
I like driving!
86 South Africa is offline   Reply With Quote
The Following User Says Thank You to 86 South Africa For This Useful Post:
sqd (12-06-2018)
Old 12-06-2018, 02:27 PM   #8234
sqd
sqd's Avatar
Drives: '13 SWP GT86
Yup, that's what I was thinking!
And thanks!
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
Old 12-15-2018, 09:10 AM   #8235
86 South Africa
I have a question about heat.
I’m running the 210SPS, intercooled version of the Sprintex. Love it! But it does generate a fair bit of heat. Particularly when we have mid summer days around 35C/95f and sometimes hotter. I do try and run a bit of ethanol as it burns a bit cooler than normal petrol, but can’t always get it.
I have also done a 6 month oil change (instead of annual) with some great liquimoly oil.
1. Do vents in the hood really make a difference?
2. I’ve been offered a better coolant option for the intercooler which apparently helps keep average temps down a good 5-8C (tested and verified apparently, but it’s info from my local installer who hasn’t steered me wrong yet).
3. Other options to consider?
I’m not looking to spend huge cash on this.
I like driving!
Old 12-15-2018, 11:03 AM   #8236
86TOYO2k17
Drives: 2017 toyota 86
hood louvers are pretty effective at lowering overall engine bay temps.
Water meth kit especially pre throtte body will drastically help charge temps as well.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
86 South Africa (12-17-2018)
Old 01-15-2019, 04:40 PM   #8237
sqd
sqd's Avatar
Well, I'm now waiting on delivery for a 210 non-intercooled. It's used, but rebuilt/overhauled by Jon Bond Performance, which I hear do good work.
This year, my plan is stock fuel system and clutch (if it'll last) on straight E85, a mild tune for about 250-260 whp. Does that sound reasonable? My car has barely done 22k miles. It's a 2013, so I'm planning on having the valve spring recall done before installing the charger.
Already have the ACE Alpha 350 header and overpipe and a full exhaust. Will add an oil cooler too, but the car will be 100% street driven.
Any thoughts?
All input is appreciated!
IG @squareddesign
Old 01-15-2019, 07:14 PM   #8238
86TOYO2k17
Any thoughts?
Your goal isn’t unreasonable if your using E85, but the sprintex heat soaks pretty bad after few pulls with no intercooler. The cooler should add about 5% more hp (maybe 10-12whp) but also slows down heatsoak, and cools down heatsoak quicker. so you have more consistent pulls back to back, especially noticeable on a track or even canyon/autox
I just finalized my DT tune for intercooled 210 with stock 75mm pulley on 92octane. Also have ace 250 header and 4.56 FD swap in an auto. With out launching at all, leaving all nannies on, auto shifting, just filled gas tank 100% (Basically not even trying) I logged a 5.7sec 0-60 and 13.9sec 1/4 with draggy. Before the SC the best I got with launching at 2500rpm, all nannies off, manual shifting, 1/3rd tank gas (try hard) was 6.6sec 0-60 and 14.8sec 1/4. Definitely a lot faster and more fun. Just need to manage all that extra heat.
Old 01-16-2019, 04:45 AM   #8239
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Ouch, i have a manual 13 brz NA style and with half a tank, my fastest 1/4 is 14 flat.
Dr. BRZ is offline   Reply With Quote
Old 01-16-2019, 09:36 AM   #8240
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Any thoughts?
Yep -- You should be good to go with that setup. I run non-intercooled on flex fuel (mostly straight E85) with the 72.5mm pulley. Car runs great, and in mildly cold weather gets into the ~270hp range. I haven't touched injectors or fuel pump, and my stock clutch is still hanging in there (have been FI for 25k miles now).
Unlike others, I don't experience heat soak much -- I believe it is totally a factor in where you live and the environment. If you aren't driving around in 80+ degree weather all the time in the baking sun you won't heatsoak nearly as bad. In Indiana I seem to do OK -- but I also don't pound around for minutes on end because the roads here aren't twisty and fun in most places. For me, on E85 (which burns cooler anyway), I have no real need for the intercooled setup -- It would really just introduce another point of failure in the system.
ajcarson11 is offline   Reply With Quote
The Following User Says Thank You to ajcarson11 For This Useful Post:
sqd (01-16-2019)
Old 01-16-2019, 09:42 AM   #8241
sqd
sqd's Avatar
Nice, that's good to hear! Yeah I've read the same from other people, that E85 and non-intercooled works pretty well, even if an intercooler would definitely help.
IG @squareddesign
Old 01-16-2019, 09:53 AM   #8242
86TOYO2k17
Ouch, that seems really slow for a MT with a header/tune. most get into the 13s.
Remember MTs are a full second faster 0-60 purely because they can launch.
5-60 they are almost equal. stock 0-60 neither launching the MT does 7.8sec AT does 8.1sec. AT can launch at 2400rpm and get to 7.6sec, MT launch can get to 6.4sec. if an AT could launch the same they would be at 6.7sec.
like i mentioned TC was on, and i took off dead stop no launch. Also the second half of the 1/4 was a slight incline which probably dropped trap from 102mph to 100mph flat.
But who really cares about stop light racing or drag racing. Are you really going to launch off every stop light? lol. I am probably 3 full seconds faster 60-120 where launching doesn't matter. You would get walked all day long while I am driving with my knees, sipping on coffee, and typing up an essay.
Just for reference a 370z nismo with intake/exhaust/lwc pulley, recorded a 0-60mph in 4.5sec, also recorded 40-80mph in 5.8sec. His 0-60 is about a full second faster, but I recorded 40-80mph in 5.5sec, .3sec faster. In a Hwy pull I am walking away. Off the line he will be faster and ill be chasing him down pulling even just after the 1/4th. Then walking away after.
Old 01-17-2019, 01:00 AM   #8243
Setgo
Setgo's Avatar
Drives: '13 Subaru BRZ Crystal Black Silica
Does anyone have a 72.5mm pulley for sale?
Setgo is offline   Reply With Quote
Old 01-17-2019, 09:49 AM   #8244
86TOYO2k17
https://www.bahnbrenner.com/vw_audi/...y_4_Bolt_Style
Try hitting them up, looks like they actually make pulleys for the Sprintex in house. Not a bad price either.
Old 01-27-2019, 06:09 AM   #8245
jflogerzi
jflogerzi's Avatar
If you guys had to choose a tune which would shop/tuner would you use for a remote tune:
Moto-east
Delicious tunning
Drift office
Leaning towards Moto East as the current owner of the kit had Moto East and everything was good
but I would love to hear peoples thoughts. I know James from HRI is good but he does not do remote tunes anymore.
2013 Series 10 FRS #553
Old 01-27-2019, 08:16 AM   #8246
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Delicious tunes. Haven't done me bad yet. Although I hear moto east is outstanding as well.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
The Following 2 Users Say Thank You to riboyster For This Useful Post:
jflogerzi (01-27-2019), Xero-Limit (03-13-2019)
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
