Old 11-09-2021, 07:29 AM   #81537
Setting the clocks back cost me $536. I bumped the black chicken while hanging the big round clock back up. The chicken fell and pecked the screen on my 55" TV causing it to have giant rainbow bars down the middle. So a quick trip to Costco and now I have a 65" downstairs.
That shelf is placed high enough you could have gotten at least a 77" or maybe even an 85" in there. Opportunity missed, but there is always the Spring time change....
Dadhawk is online now
Old 11-09-2021, 10:44 AM   #81538
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
More like his big, hard, black pecker caused rainbows to appear.
Sounds dirty, but accurate.
Sapphireho is offline
Old 11-09-2021, 10:49 AM   #81539
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I have an 82" with surround sound upstairs.
Chicken comes down first this spring.
Old 11-09-2021, 10:50 AM   #81540
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Posting here since is unrelated to the twins. I'm trying to improve the light bulbs on my dad's Crosstrek. OEM it uses the shitty Silvana 12V 60 Watt PN 84920PA000. If I wanted to upgrade to LEDs, what should I do. I usally just get brighter bulbs but is better to just get something similar to what the BRZ has. So I'm not sure where to start. Do I just switch to LED bulbs or do I have to change some sort of assembly?
spcmafia is offline
Old 11-09-2021, 11:04 AM   #81541
The Philips bulbs you listed are 9005s I believe. There are lots of direct replacement LED bulbs for 9005s nothing else required although you may want to adjust the headlight angle afterwards.
The only issue you may have, as with the 2013 FRS, is if it uses the bulb as a DRL. I had to turn off DRLs when I switched to LEDs because they were too bright since the car couldn't run them at half power.
Others will tell you that it's not a good idea to swap out the bulbs directly without making other changes if you have projectors. I was OK with just a straight swap taking into consideration the DRLs.
Old 11-09-2021, 11:09 AM   #81542
Yep. Next time change make sure your cock is out of the way before moving your hands forward.
Tcoat is offline
Old 11-09-2021, 11:14 AM   #81543
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Good thing it is detachable.
Old 11-09-2021, 11:29 AM   #81544
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I'm taking a drive to the Asian market today to stock up on thanksgiving supplies. Broccoli beef is becoming our thanksgiving tradition here. Fine with me. Much easier than making a giant turkey dinner for 3.
Old 11-09-2021, 12:18 PM   #81545
Ultramaroon
not playing cards
Ultramaroon's Avatar
Phew! TV saved the cabinet. Close call.
Ultramaroon is offline
Old 11-09-2021, 12:19 PM   #81546
Ultramaroon
not playing cards
haha... spring chicken
Old 11-09-2021, 12:38 PM   #81547
humfrz
- resetting your clocks was dumb, you're retired, what makes the difference what time it is?
humfrz is offline
Old 11-09-2021, 07:13 PM   #81548
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Damn this looks good!
Kiske is offline
Old 11-09-2021, 11:04 PM   #81549
Sapphireho
Famous Potatoes
Sapphireho's Avatar
So true.
Reminds me of once when we went to the lake years ago. We were there for a week before we realized the clocks were an hour off.
Old 11-09-2021, 11:06 PM   #81550
Sapphireho
Famous Potatoes
Sapphireho's Avatar
They are all spring chickens.
