#799 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
#800 | |
Drives: Scion FRS
![]() I did not know you were running CATless and headers in your car. The OEMs cams will no longer be valid then. Reg tip in knock: I have worked to some extent on it (not on FA20) and have found that some level of transient knock does not harm the engine nor does it learn itself into the long term knock retard since in normal circumstances the knock should be consistent and engine should be in pseudo steady state for the ECU to update a cell for knock activity to pull out spark in LT. When engineers try to completely eliminate tip in knock they end up causing slight hesitation and lack of torque response to pedal input. Ultimately when I calibrate an engine if SS knock is non existent and knock only shows up at transients we don't worry about it so much and just the knock sensor take care of it. This is for overall drivability and FE. Cant really comment on the OTS cal because multiple parameters have been changed (cams, spark, fueling, transient fueling etc) If their cal takes away all sorts of knock, improves power, improves drive feel and at the same time FE then kudos to them because they know something that Toyota and Subaru doesnt I am closely following all the threads and enjoying the enthusiasm of the community. I am trying to contribute to the best of my abilities since I have performed calibration for a few years. Some of my methods can be different because I worked for an OEM and I think like an OEM. Which means I also know where OEMs will not cut corners to get more power due to emissions and durability restrictions. |
#801 | |
Drives: Scion FRS
http://www.cambustion.com/sites/defa...%20through.pdf http://www.researchgate.net/publicat...t_the_Test_Bed |
#802 | |
Another thing is that the OE cals were dialed for high quality premium fuel, it seems. So, if you run fuel that is not up to par (91 octane instead of 93), a lot of knock will show up. I've heard that this is a common problem with cars made by Subaru, as this problem is not only present in the FA20 in this car, but also in imprezas, WRXs, forresters, etc. This is where the adjustment I've made come into play. Let me see if I can find an old log using the unmodified stock cal to show you want I'm talking about. Anyhow, we're glad to have you on board contributing your insights and perspectives on this forum. Edit: @thambu19 Here's a log of the stock A01C rom in 69*f ambient temps: http://datazap.me/u/solidone/stock-a...0&data=1-10-14 While there is no knock going wide open because of the more conservative ignition timing at the upper load ranges, there is a bit of knock in medium load and maybe some tip in knock even in such cool temperatures. The IAM start to drop back a little toward the end of the log. Here's a log in similar 67*f ambient temps using a OTS Stg 1 rom modified for better knock resistance in part throttle and tip in (not sure what all the modifications I did were exactly on this one): http://datazap.me/u/solidone/stg1-20...=0&data=1-9-12 You will notice that the IAM stays solid at 1 all the way through, only seeing some knock while going wide open due to the more aggressive ignition timing for max power with the factory exhaust system. In part throttle and tip in there is little to no knock correction.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 11-11-2015 at 07:54 PM. |
#803 |
Drives: Scion FRS
@solidONE
Have you had a chance to compare the MY12 cals vs MY14 cals to see what changed between those that eliminated the issues that were initially observed? Mine is MY13 and my idle quality is piss poor. There have been numerous instances at work where I tried restarting a the car that was already sweetly humming at idle thinking it was off. That is the level of perfection we try to get. Granted it has more cylinders. The idle in the FRS is appalling. Not sure if it is to do with the 100% DI operation combined with quest for fuel economy at all cost or because the engine is kept at severe torque reserve since it is a measly unit. OEMs generally pull out a ton of spark to keep enough reserve. For the manual it makes things worse because the transmission load is non existent (unlike the ATs) and so the airflow is lower at idle for MX vs AT. Lower airflow at same engine idle speed means bad combustion stability |
#804 |
Drives: '22 BRZ
I have better idle quality on my HUGE cammed GTI with Megasquirt tuned by myself having no prior knowledge of tuning... Which says a lot about Subaru's idle control. or my patience... I'm not sure which
#805 | |
Intent > Content
#806 |
Drives: '22 BRZ
I can confirm that they added transient retardation at higher RPMs (I forget where it started) vs the early cars that had only transient retardation at low RPMs. Track use would eventually blow out the DI seals due to knocking... There were some idle changes IIRC, but I don't remember what exactly.
#807 | ||
700x,900x A00x roms were carrections for rough idle and cam compensation issues A01x was transient ignition retard (di seal fix). in usa they had another go at idle fixs in B00x and B01x and some cars still idle badly especially on 91 fuel. if your running oft roms your earlier rom calid is automaticly updated to latest compatable ie anyone on below B01x is updated to B01x, even though the rom name may be 700x or the others. change the di\pi tables to run full di at idle ie loads 0.2 and 0.3 and bump you idle to 700 or 750, oft roms bump idle to 750 but dont do the full di. At idle running both injection systems means its injecting very small amounts of fuel via both, also as the di is straight into cylinder it can react faster to air con load changes ect seems to work well on my car anyway |
#808 |
Drives: 2015 BRZ
I'm using the Stage 2 E85 UEL tune with Wayno's maps copied over.
I'm seeing a bit of FKLC: http://datazap.me/u/lord09/log-1447436457?log=0&data=2 Anyone mind chiming in and providing their thoughts, anything I should be concerned with? Even though it's not in the this log, I have seen the IAM drop to ~.9 on occasion, but quickly climb back to 1.0 Only mods are OFT/OFH + a TRD drop in filter. E85 is 85-90%. |
#809 |
Drives: JAWS
@Lord09 I wouldn't be too concerned with that knock, that's a very knock prone rpm/load range. (I'm on 91 but I had consistent knock around that same exact area that was a bit worse even after pulling some timing.) If IAM is pretty much always at 1, I'd just let the ECU do its thing.
#810 |
Drives: '22 BRZ
It's slightly odd that it's knocking that often, but it's not dropping the IAM so it's probably not a big concern unless you're tracking the car a lot.
#811 | |
Intent > Content
#812 |
Drives: Red
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
