Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
View Poll Results: How would you rate the design of the 2nd gen? 1 lowest & 5 highest
1 19 7.20%
2 25 9.47%
3 62 23.48%
4 104 39.39%
5 54 20.45%
Voters: 264. You may not vote on this poll
Old 11-24-2020, 09:14 AM   #799
And maybe some brave soul will disconnect the oil cooler and plug the vents to see what the actual temperatures are without them. Willing to bet it ain't pretty.
Yea, doubt they included it for any other reason than it really is required for the longevity of the engine.
Tcoat (11-24-2020)
Old 11-24-2020, 09:47 AM   #800
ZDan
ZDan's Avatar
Drives: '23 BRZ
There should be some small benefit from the oil coming up to temperature more quickly, particularly in colder ambient temps. If oil temps are still >260F at the track, which seems likely, some people will still be freaked out...
Dadhawk (11-24-2020)
Old 11-24-2020, 10:10 AM   #801
jvincent
jvincent's Avatar
I retro-fitted that same oil cooler onto my FRS. It's connected into the throttle body coolant line. I'm curious where it's connected on the 2022.
It definitely helps with oil warmup, I'm in Canada, as well as helping bring temps down a bit on the track.
The Following User Says Thank You to jvincent For This Useful Post:
ZDan (11-24-2020)
Old 11-24-2020, 10:11 AM   #802
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
All-New 2022 Subaru BRZ Makes Global Debut
Comparing the FR-S to the 86 to the new BRZ as far as wheel torque at given vehicle speeds. I assumed that the car was in the ideal gear at each speed.
Quentin is offline   Reply With Quote
The Following User Says Thank You to Quentin For This Useful Post:
Irace86.2.0 (11-24-2020)
Old 11-24-2020, 10:12 AM   #803
wbradley
Sarcastic SOB
wbradley's Avatar
From my understanding, the Forester type oil/water heat exchanger functions more to warm the oil quicker, than as an actual oil cooler. Perhaps in extreme temperatures it also helps keep oil temp from overrun.
The Following User Says Thank You to wbradley For This Useful Post:
ZDan (11-24-2020)
Old 11-24-2020, 10:14 AM   #804
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah I am not overly concerned with temps, just pressure. A lot of the high end synthetics don't break down till well above those temps and people seem to get really concerned when they see high temps but don't know their pressures.
To answer your other post, I peak out at around mid 270's during a long session during the summer. I have read through both those threads on temps/pressure. Though like I said I haven't ruled out my sending unit or position of the unit being the issue. It is just something I have observed on my own car and went back to 0-20 because of it. I am personally not happy with Killer B. After getting one of their pickup tubes and it was built wrong. I sent it back after talking with them about it, I offered to modify it but they insisted they replace it. After 3 months of waiting I told them forget about it because they already had a couple times.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
ZDan (11-24-2020)
Old 11-24-2020, 10:16 AM   #805
dodj
Drives: Rallye Blue BRZ
I will never understand this whole "techs don't know different engines" thought process.
Are the techs in the US bred specifically for one make and have some inherent gene that prevents them from understanding any engine but that? Is there a law that says a tech from one make must only work on that one and never switch to a different brand?
Maybe that's why they are called techs now instead of mechanics. They technically only know one engine.
dodj is offline   Reply With Quote
The Following 2 Users Say Thank You to dodj For This Useful Post:
jcw99 (11-24-2020), Tcoat (11-24-2020)
Old 11-24-2020, 10:22 AM   #806
2,000 to 2,800 foot pounds? Headed into electric car territory there.
Old 11-24-2020, 10:26 AM   #807
Opie
Opie's Avatar
Drives: 2000 Subaru Legacy B4 RSK (JDM)
Prob, never... & prob best not to know
I know....
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
Tcoat (11-24-2020)
Old 11-24-2020, 10:27 AM   #808
Originally Posted by Opie View Post
I know....
Well around 50% or so.
Opie (11-24-2020)
Old 11-24-2020, 10:28 AM   #809
Opie
Opie's Avatar
Ah, but it has more low-end torque *and* more top end! I'm very encouraged that peak power is still at 7000rpm, and that redline is still 7400, maybe 7500.
From the SoA press release: "The 2.4-liter naturally aspirated engine redlines at 7,000 RPM and delivers a 15-percent increase in torque."
Tcoat (11-24-2020)
Old 11-24-2020, 10:38 AM   #810
But nobody believes that! There are at least 10 people that have said it is impossible and a misprint.
Old 11-24-2020, 10:39 AM   #811
Opie
Opie's Avatar
Also...for @Tcoat: "Using design elements from the Subaru Global Platform, the chassis has gained rigidity through a reinforced chassis mounting system, sub-frame architecture and other connection points. Front lateral bending rigidity has been increased by 60-percent for the 2022 model to improve turn-in and response."
Tcoat (11-24-2020)
Old 11-24-2020, 10:41 AM   #812
Quentin
The wonders of gear multiplication. 4.44 final drive and 3.63 1st gear is 16x. I’m assuming the gear ratios carry over to the new gen.
EVs usually have reduction gears, too. A model S has 9.73:1.
The Following 2 Users Say Thank You to Quentin For This Useful Post:
Tokay444 (11-24-2020), ZDan (11-24-2020)
2022 Subaru WRX Spy Shots via Car and Driver R_E_L Other Vehicles & General Automotive Discussions 232 01-03-2023 02:23 PM
2017 BRZ Hig Res - Courtesy Subaru Global Media Trap63 BRZ First-Gen (2012+) — General Topics 10 07-11-2016 10:53 AM
Subaru global brz web page Gaen BRZ First-Gen (2012+) — General Topics 4 06-15-2012 02:32 AM
Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show C-Bone BRZ First-Gen (2012+) — General Topics 39 03-24-2011 10:22 AM
FT-86 makes UK debut at Goodwood Moving Motor Show Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 28 07-09-2010 03:57 PM
