#800 |
Conedancer
Drives: 2013 Subaru BRZ SWP
no idea.. thats something you would have to talk to Matt on.. I know the lockup rate and the decel rate.. and that I can definitely feel the difference ...
![]() Car is ready to go for the 2014 season with some new goodies and also refining the old stuff. New: Guard Transmission Rear LSD ![]() As well as new Adj rear Lower Control Arms : ![]() ![]() Tweeked the alignment settings a bit.. and....oh yeah.. installed the 'Claw'... Latest Revision Ceramic coated goodness from Nameless Performance and tune. ![]() thats pretty much the update... not much left to do as-per the STX Ruleset. now its just a matter of tweaking.. and getting comfortable with the new setup. Put in my Race Seat.. 5pt next.... Ok.. I ended up with a Corbeau FX1.. I used the stock sliders with Custom side rails. and stock seat belt mount. Very happy.. Here are the pics. I have some tinkering to do. but for the most part, Done ![]() ![]() ![]() ![]() ![]() my motto for the whole build has been to : "Completely take away the car from the equation and concentrate on driving".. Now that the car is pretty much to the letter of the rules.. I can completely concentrate on driving and learning the new setup ![]() ![]() Thanks for the interest Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
The Following 2 Users Say Thank You to Scooby South For This Useful Post: | chanomatik (04-17-2014), forwallblakmail (04-20-2014) |
#801 |
Drives: MT WRB BRZ Limited, 2007 911s
So jealous of this awesome build. One day when this thing isn't my DD I'll be using this thread as a guide. Good luck this season. Can't wait to hear some of your impressions on the new setup.
The Following User Says Thank You to was385 For This Useful Post: | Scooby South (04-01-2014) |
#802 | |
Conedancer
![]() Enjoy. Season for the car starts Next weekend at Wilmington Match tour in Wilmington Ohio where a number of Twins is pre-registered...Look forward to to ![]() Bill
The Following 2 Users Say Thank You to Scooby South For This Useful Post: | chanomatik (04-17-2014), fstlane (04-03-2014) |
#803 |
Drives: 2013 Scion FR-S Firestorm
So, I'm imagining that the lockup under acceleration in the new diff is intended to be more progressive than stock (to keep power oversteer in check), and with little to no lockup on deceleration for better turn-in?
Also that you intend to take out some of the excess negative camber out of the rear? |
#804 | |
Conedancer
![]() ![]() Bill
The Following 2 Users Say Thank You to Scooby South For This Useful Post: | chanomatik (04-17-2014), neurokinetik (04-08-2014) |
#805 |
Conedancer
Fastest Run At Wilmington 66.1. Good enough for 3 bonus rounds. on Sunday. Car felt awesome.. Federal RSR 595 Tires. Made some adjustments on the front ride height..and soem rebound/compression adjustments on the back. still has a bit of push on exit.. more adjustment to do.. This was good enough for 7th place a 1/10th out of the trophies.. It felt good to drive my own car and for it to be competitive..
![]() [ame]http://youtu.be/4eaTfluuIWQ[/ame] [ame="http://youtu.be/hP0o5_Ws3AI"][/ame]
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD Last edited by Scooby South; 04-17-2014 at 08:16 PM. |
The Following 3 Users Say Thank You to Scooby South For This Useful Post: |
#806 |
Drives: 2022 BRZ
Why are you staying with the Federals?
I don't think they would be my 1st choice. Simmons
2022 BRZ 71 STR
Sponsors Xero-Limit//Karcepts |
#807 | |
Conedancer
![]() ![]() Bill
#808 |
Conedancer
oh.. it was also the first time the car had been out this season and I think it did pretty well with all the new changes I did over the winter make the car faster.. so now its up to me, the driver...taking the car out of the equation.
![]() Bill
The Following 2 Users Say Thank You to Scooby South For This Useful Post: | chanomatik (04-18-2014), FastWhite (04-18-2014) |
#809 |
Conedancer
Car is getting closer and closer to being completely dialed in.. Car Took 1st and 3rd on index at our first local event in Milwaukee..
[ame="http://www.youtube.com/watch?v=qJ5W7qLQ-9s&feature=share&list=UUJ91sP-zsNPiHXLa4E8rklg&index=1"]Milwaukee SCCA opener 042013 Fast run 48.7 - YouTube[/ame]
The Following 4 Users Say Thank You to Scooby South For This Useful Post: |
#810 |
Conedancer
Figured I would update my Mod lost
Full National STX Build 2013 Subaru BRZ limited , Satin White Pearl, 6 spd manual Engine: -DIY intake with K&N filter, Sound Generator Delete, Gold Wrapped intake tube and Gold stock Air box -Kartboy Oilcap -Kartboy LW Engine Pully -Nameless Ecutek Tune , 8k redline, Flat Foot Shift, Launch control -Mobil 1 0-20 oil -Ballistic 3.5lb lithium ion Battery 500CCA. Exhaust: -Nameless Lastest Generation Long tube ceramic coated Header -Nameless 2.5 in stainless with Overpipe with Cat and hemholtz Resinator. -Nameless 5in stainless Muffler axleback Suspension: -KW Var 3 coilovers with 7k front and rear springs -Front Camber plates -Truhart rear adj lower control arms -Whiteline Steering Rack Bushings -Whiteline Rear Diff Bushings -Whiteline Cradle Bushings -Whiteline Front 20-22 adj front Sway bar -Whiteline front adj swaybar endlinks -Whiteline Front control arm offset bushings -Subaru OEM STi rear sway bar -Kartboy Rear swaybar endlinks. Drivetrain: -Kartboy Short Shifter -Kartboy Trannymount insert -Cusco Engine Mounts -Guard Transmission LSD -Stoptech front BBK with aluminum hatted rotors -OEM Subaru rear 2 pot brakes -Stoptech Stainless Brake lines -Motul RBF 5.1 brakefluid Interior: -JPM Coachworks double thick Alcantera Steering wheel -Corbeau FX1 Drivers fixed back seat with custom mounts Misc: -Generic hood Struts -11lb hidden rear trailer hitch -Center console armrest -Valentine 1 -Garmin with traffic control -30% tint Rims/tires: -Rota 17x9*42 Titan with 255/40/17 Dunlop Z2 -Rota 17x9*42 DPT with 255/40/17 Federal 595 RSR ![]()
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD Last edited by Scooby South; 05-06-2014 at 07:07 PM. |
#811 |
Conedancer
Welcome Aboard... #FT-86 SpeedFactory... Look forward to 2014
![]() Bill
The Following User Says Thank You to Scooby South For This Useful Post: | chanomatik (05-02-2014) |
#812 |
Conedancer
Wheew...what a great day. Car ended up 2nd and 7th overall .. Fun Fun course
![]() [ame]http://youtu.be/cG4SuAfYqs8[/ame] Bill
Subaru/Scion warranty and autocross | Ribface | Tracking / Autocross / HPDE / Drifting | 55 | 06-17-2015 08:30 PM |
Will you Autocross your 86? | Ribface | Tracking / Autocross / HPDE / Drifting | 131 | 06-22-2012 05:48 PM |
Which autocross class? | jpdarty7 | Tracking / Autocross / HPDE / Drifting | 66 | 06-21-2012 05:53 PM |
FR-S at a CA Autocross | oneday | Scion FR-S / Toyota 86 GT86 General Forum | 57 | 03-26-2012 03:38 PM |
