Old 04-22-2021, 01:22 PM   #8051
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Originally Posted by NEW FRS View Post
I tried but i cant post a new reply so
Oh yeah, I think new users are limited to what they can do for a while until they get enough posts and replies back in order to weed out the bots. Just keep this conversation with me up until you get about 10 posts under your belt and I think the restriction will be lifted.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 04-23-2021, 08:56 AM   #8052
NEW FRS
Helpless FR-S noob
Drives: none yet getting a white frs soon
Ok tbh im thinking of using spacers to have the wheels be flush and lined up correctly with the widebody fenders. is that bad or am i doing the right thing?
NEW FRS is offline   Reply With Quote
Old 04-23-2021, 09:00 AM   #8053
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
That'd be a huge spacer, if you're trying to flush up stock wheels with a widebody kit. Big enough that you'd need longer lugs... You'd be better served getting wider wheels with lower offset.
Cephas is offline   Reply With Quote
Old 04-23-2021, 09:05 AM   #8054
NEW FRS
Helpless FR-S noob
okay but i dont want tilted wheels,m i want them to be normal and just like flush ,mand also i was looking at a rallybacker 12 pice kit is that good enough? i dont want it to be to ahrd to install. sorry if i am annoying anyone
Old 04-23-2021, 09:24 AM   #8055
Cephas
Cephas's Avatar
No worries man.
The offset of the wheels won't affect the camber (tilt) of the wheels, it's just the difference between the mounting surface of the hub and the centerline of the rim. A lower offset effectively moves the outside edge of the rim further outward, and closer to flush with the line of the body or bodykit.
As far as "good enough," what are you looking to achieve?
Old 04-23-2021, 09:38 AM   #8056
NEW FRS
Helpless FR-S noob
No worries man.
Im looking for something that isnt too wide, i like the look of the rally backer, and by good enough i dont want it to look hodgepodge, like i feel like the ten piece kit isnt good enough like it wont look good ill include a link below. and where would i get all this work done? because i have been looking around and tbh i dont trust myself to put the kit on myself. im kind of nervous more about the wheels being flush then anything.
https://staticmotorsports.com/collec...z-widebody-kit
Old 04-23-2021, 09:45 AM   #8057
NEW FRS
Helpless FR-S noob
and im thinking of a 2 inch spacer on all four wheels or a 35 mil spacer idk yet
Old 04-23-2021, 09:55 AM   #8058
Cephas
Cephas's Avatar
Spacers alone aren't gonna get the job done on stock wheels. To get flush with a widebody kit you have to get a very wide rim with a very low offset, then maybe also spacers.
If flush wheels are your target, personally I'd skip the widebody kit and do wheels/tires/suspension instead.
Old 04-23-2021, 10:01 AM   #8059
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
You know installing a widebody involves cutting the fenders and quarter panels right? I wouldn't consider that an easy install regardless of how many pieces the kit has.
I don't think a widebody with stock wheels if any offset is going to be the look you are going for...
Old 04-23-2021, 10:06 AM   #8060
NEW FRS
Helpless FR-S noob
I have the flush wheels on the frs already, i just want to get the widebody kit on it, and then get 35 mil spacers and i feel like that will be good, cause thats what my friend did, and rn the wheels are 7 inch, so im thinking go to 8 or 9 inch rims? with a 35 mil spacer on each wheel. cause i want that wide body feel and look
Old 04-23-2021, 10:13 AM   #8061
NEW FRS
Helpless FR-S noob
Yes i know, but i am prob either have my friend do it or not risk bad things happening and just take it to a bodyshop/mod shop
Old 04-23-2021, 10:21 AM   #8062
Cephas
Cephas's Avatar
Probably a 9.5in rim with a ~20mm offset plus a 35mm spacer, change your lugs, add coilovers so you don't have a horrific fender gap, then the widebody kit plus install and paint costs... Got $7k to drop into this?
Old 04-23-2021, 10:25 AM   #8063
NEW FRS
Helpless FR-S noob
i have at most 4 or 5 k lol so ill figure it out i mean it will work it self out i hope and im not gonna paint it, the kit comes in black and my car is black so imma prob just keep it like that. i mean is that gonna be a bad look? if all else fails i can wrap it, but painting is too expensive.
Old 04-26-2021, 03:18 PM   #8064
McMCOO
Anti-Social Media
McMCOO's Avatar
Drives: 24 GR86 Premium MT is on the way!
Howdy, all. I'm Dave. New 86 owner. So new, I don't even have it yet. I think I found the very last 2020 86 in manual transmission in all of Washington and Oregon. Drove 5 hours each way to buy it last weekend. They are delivering it this week.
I've been scouring these forums, and it certainly is a wealth of info. I've already decided the first things I will do is add struts to the hood, a Fumoto oil drain valve, and move the 12VDC plug cap from the glove box to the sound tube hole. You monsters are already costing me money.
Well, back to lurking.
McMCOO is offline   Reply With Quote
6mt, bot. report?, frs, notreally, turbo
