Old 08-09-2014, 12:02 AM   #8023
Rio
Rio's Avatar
Drives: 2014 Scion FR-S ハチ
Wheels + Tires
Today I mounted the Enkei RPF1s (17x7.5) and Yokohama Neova AD08Rs (235/40/17) for SCCA SOLO this weekend! They are definitely sticky! :-0
Rio is offline   Reply With Quote
Old 08-09-2014, 12:09 AM   #8024
mizzta21
mizzta21's Avatar
Drives: 2014 whiteout, scion fr-s
I like your setup, it's what I want to do with mine
mizzta21 is offline   Reply With Quote
Old 08-09-2014, 06:25 AM   #8025
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I finished my carbon fiber fender vents and installed them today. I ended up going with a smaller mesh screen and painted it gold to match my wheels.
Lunatic is offline   Reply With Quote
Old 08-09-2014, 10:06 AM   #8026
torranosaurus
Drives: 2014 FR-S
Originally Posted by Lunatic View Post
Painted my tail lights.
Looks good.
I am trying to get rid of the cheap plastic looking fake chrome. How did you do it?
torranosaurus is offline   Reply With Quote
Old 08-09-2014, 10:29 AM   #8027
DeadStar7
Retired formula car racer
DeadStar7's Avatar
Drives: 2013 Scion FR-S Manual
Originally Posted by illicitstylz View Post
I'm tempted to just tap it into the same cigarette outlet that you plugged into
You should use the one in the glove box.
"If one day the speed kills me, do not cry, because I was smiling." - Paul Walker
DeadStar7 is offline   Reply With Quote
Old 08-09-2014, 12:20 PM   #8028
MikoV
MikoV's Avatar
Drives: 2014 Scion FR-S Firestorm
Wheels going on =) finally..
MikoV is offline   Reply With Quote
Old 08-09-2014, 12:35 PM   #8029
FRS Dad
Drives: 2015 FRS
Attachment 87599
There is nothing better than wheel day.
FRS Dad is offline   Reply With Quote
Old 08-09-2014, 12:36 PM   #8030
MikoV
MikoV's Avatar
Yeah haha. I'm more excited than when I bought the car. It's weird..
Old 08-09-2014, 01:16 PM   #8031
FRS Dad
Drives: 2015 FRS
The day you buy it it's a new car. After wheel day it's your car.
Old 08-09-2014, 03:46 PM   #8032
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Fogs!
Finally the way that the front end should have come from the factory.
Demandred7 is offline   Reply With Quote
Old 08-09-2014, 04:41 PM   #8033
frsvr4
Drives: '13 FRS
Added an outboard EQ and a digital-to-analog converter...
Mind sharing some more details? Car audio really isn't my thing, but I'm intrigued.
'13 Asphalt FR-S // 6 spd, 3M bra, BeSpoke, Sportsguy83 arm rest, YoSpeed sills & plaque, P3Cars Vent Gauge +oil P sensor; on shelf: SRP pedals
'93 Pearl White 3000GT VR-4 // 5 spd, stock block & 30+ psi: 10.5@135
frsvr4 is offline   Reply With Quote
Old 08-09-2014, 05:14 PM   #8034
FRS Dad
Drives: 2015 FRS
Sure. This is a mod I came up with to solve a major equalization problem in the previous generation Mercedes S Class (I have a 2010 S550 as my DD).
The car's standard audio system is a 600 watt 13 channel harman/kardon that, on paper. should sound terrific but in reality it's a disaster. Honestly, the stock FRS system is better sounding. Do a Google search for "S550 Sound" and you'll see what I mean.
Because the MB's audio is completely integrated into the car, the only practical way to do any sound processing is to use the aux-in jack. The EQ mod cost under $100 (for the equalizer and related cables etc) and around $300 if you add the outboard DAC). It's become a very popular mod on the MB forums.
I ran this system for several months while researching a more comprehensive fix. I ended up replacing the Mercedes' factory speakers with high end Focals and as a result the hardware for the mod was sitting in the garage when we brought the FRS home. Since it had a glove box 12v and an aux-in, I popped it in there.
The EQ gives you seven bands of frequency adjustment. In the FRS, it lets you more closely tailor the bass to the point where it's full but doesn't bottom out the front door woofers. I pushed the mids down quite a bit to create a "notch" that gives the impression of a larger soundstage, and then brought some extra ultra highs in for detail. The sound is quite a bit more smooth, detailed and refined than stock. (I just ordered the OEM Audio Plus upgrade for the FRS. Once that's in I can tell how much bang for the buck that $1400 upgrade is versus just the EQ mod. I think you could probably get away with a small powered sub in the trunk and the EQ mod and be pretty happy)
This is a toolless install that takes about ten minutes. You can assemble it on your kitchen table and pop it in the car. The schematic below includes a small headphone amp that was necessary in the Mercedes but not in the FRS. It also includes the outboard DAC which I highly recommend if you have your music on an I Device that can be omitted as well.
You'd replace it with a standard Y cable, stereo 3.5mm male to stereo RCA to the Main In on the EQ. On the output side, from the Front Out of the EQ you'd use the same cable and run the output to the car's Aux In jack.
Here's a parts source list: [ame]http://www.amazon.com/gp/registry/wishlist/ref=gno_listpop_wi?ie=UTF8&requiresSignIn=1&tag=vi glink20394-20[/ame]
Old 08-09-2014, 05:47 PM   #8035
bigred18
MJLONIR Program Member
bigred18's Avatar
Put my Spec D Boomerang light on my FRS
ドラゴンに乗る
Instagram: Komodo_Actual
My car build: http://www.ft86club.com/forums/showthread.php?t=81094
bigred18 is offline   Reply With Quote
Old 08-09-2014, 06:40 PM   #8036
nyfries
Drives: 14 FRS Whiteout
Washed her today. Discover more rock chips..... Fact of life when u dd the car I guess.... Book a detailing session next week though hopefully it will be worth it!
nyfries is offline   Reply With Quote
