Old 06-16-2017, 05:13 AM   #785
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I mean this in the nicest way possible, but why the fuck haven't you ordered this yet?
http://www.ft86speedfactory.com/trd-...over-1915.html
Originally Posted by humfrz
I'm old and lazy
zeal86 (06-16-2017)
Old 06-16-2017, 03:52 PM   #786
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
When you finish the engine cover are you going to do anything with the alternator lead? They are seriously ugly.
Scrappydoo is offline   Reply With Quote
The Following User Says Thank You to Scrappydoo For This Useful Post:
new2subaru (06-16-2017)
Old 06-16-2017, 04:16 PM   #787
zeal86
zeal86's Avatar
Drives:
I'm still considering covering it as part of the cover... we'll see...
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is offline   Reply With Quote
Old 06-16-2017, 05:35 PM   #788
zeal86
zeal86's Avatar
Drives:
This prepped door cup is a better example than my first one... more hand filing... less dremeling... lol
If I have to make any adjustments to my first door strap pull (adjustment = partial disassembly) ... I'll go ahead and file the first door cup to get cleaner edges and more even surfaces... That's the OCD in me...
The Following User Says Thank You to zeal86 For This Useful Post:
Michael (06-20-2017)
Old 06-16-2017, 06:28 PM   #789
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Or some form of wrap or braiding. Just getting rid of the grey would help.
zeal86 (06-16-2017)
Old 06-16-2017, 06:36 PM   #790
zeal86
zeal86's Avatar
Drives:
So I gave my first version of my door strap pull a test drive... it was a no go... not enough swing to pull the cable... however...I removed the spring and it seems as it was the limiting factor...
I'll give it another shot later... It appears that removing the spring will do the trick... If it does...hopefully there is enough recoil from the cable to reset the door strap pull.
btw, I did go back to hand file the first door cup for cleaner edges and flatter surfaces... I couldn't help myself :p
Old 06-16-2017, 09:43 PM   #791
zeal86
zeal86's Avatar
Drives:
I may need to remake the lever at a slightly more acute angle...I need a tad bit more swing. I'll bring in the long arm about 3° then cut and shape it by hand... once it is right, I'll have it cut out on a gravo cutter.
Scrappydoo (06-22-2017)
Old 06-17-2017, 01:44 AM   #792
zeal86
zeal86's Avatar
Drives:
I'll be trying this version of my lever soon. I will make this next version manually out of a thicker aluminum.
4°swing inward on the long arm... also beefed up the center... (red=orig)
MJones_RB (06-21-2017)
Old 06-18-2017, 01:14 AM   #793
zeal86
zeal86's Avatar
Drives:
I haven't made my new lever yet but I decided to bring in the angle of the long arm another 3° for a total of 7°. I hope to have the new levers completed on Monday.
I'm also going to try a 1/16" stainless steel rod in place of the wire rope... we'll see how that works out. I haven't given up on the OEM spring...I'm going to give it another go with the steel rod. Also, trying to find some brake cable clamp bolts and nuts... so far I've been unlucky... I might have to go to a bike shop for those.
Old 06-20-2017, 02:39 AM   #794
zeal86
zeal86's Avatar
Drives:
My coworker found me some really cool hardware today that is perfect for this application. l'll post a pic of the hardware in my future write-up because I don't know the exact name.
I'm in the middle of tinkering with a stainless steel rod instead of wire rope. I'm sure the end product will include a steel rod because it pulls and pushes stronger and smoother than the wire rope.
I'm going to make another adjustment to my lever design and I'm still trying to incorporate the spring. More to come soon...
Old 06-21-2017, 02:21 AM   #795
zeal86
zeal86's Avatar
Drives:
I made some changes to my design... I had to remove the spring again as it still limits the rotation of the lever mechanism. I have one more idea to test out to see if I can keep the spring in my design. I'll test my newest changes out on Thursday...
Riveted the two pieces together so I could shape them together... turned out decent. These levers are made from a thicker aluminum than my previous one.
Sourced a cool little swivel cable stop for this project...
I installed a cotter key to let the pull strap to move more freely...
stay tuned... more to come...
Old 06-21-2017, 11:23 AM   #796
zeal86
zeal86's Avatar
Drives:
Well...trial and error has gotten me to this point. Stumbled across some hardware that is perfect for this application... Its called a throttle swivel. I drilled a maintenance hole so I can tighten the set screw on the throttle swivel.
At this point I don't think I'll try to make the OEM spring work... I think that the cable will have enough retraction to reset the handle to neutral. I'll test this out soon... I have a good feeling it will work though. Detailed write-up coming soon.
The Following 3 Users Say Thank You to zeal86 For This Useful Post:
Andrew025 (06-21-2017), DustinS (06-21-2017), MJones_RB (06-21-2017)
Old 06-21-2017, 03:06 PM   #797
shadow_772
Drives: 2014 BRZ Limited
Progress is looking good!
shadow_772 is offline   Reply With Quote
The Following User Says Thank You to shadow_772 For This Useful Post:
zeal86 (06-21-2017)
Old 06-22-2017, 07:12 PM   #798
zeal86
zeal86's Avatar
Drives:
Door cup covers made... will be upholstered soon with the same suede I covered my rear seat delete with...
The Following 2 Users Say Thank You to zeal86 For This Useful Post:
Clipdat (06-23-2017), Scrappydoo (06-22-2017)
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
Kylefrs Build Thread kylefrs Member's Car Journals 14 01-28-2015 09:27 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 08:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 08:34 PM
