Old 01-03-2014, 01:59 PM   #785
foompla
Drives: hot lava frs
Originally Posted by WRXGuy1 View Post
Here are the scans of the TSB and my repair invoice:
Pictures are broken. This was the SB they were referring to
07-59-07R Technical Service Bulletin Moisture / Condensation (Water) Formation Inside Exterior Lamp Assemblies Nov 21, 2013
http://techinfo.subaru.com/static/whatsNew.html
foompla is offline   Reply With Quote
Old 01-03-2014, 04:11 PM   #786
RFB
RFB's Avatar
Drives: FRS
I knew it -
It was only a matter of time before they got tired of the cost of warranty replacement of the tails - I'm sure Toyota will back out of the warranty also.
Thanks to the gods for the 99 cent snowman snot fix !
CERBERUS
RFB is offline   Reply With Quote
Old 01-04-2014, 08:45 AM   #787
RJ_203
RJ_203's Avatar
Drives: FR-S...WHITEOOOUUUTTT!!!...hehehehe
mine was replaced for the 2nd time on thursday and my fuel pump also 2nd time
RJ_203 is offline   Reply With Quote
Old 01-04-2014, 01:14 PM   #788
WRXGuy1
WRXGuy1's Avatar
Drives: 2013 WRB BRZ Premium 6MT
Yeah I closed the photo hosting site and forgot those were hosted there, I don't have the scans anymore :/
2013 BRZ Premium WRB MT - Picked up 5/31/12
WRXGuy1 is offline   Reply With Quote
Old 01-04-2014, 05:11 PM   #789
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
If I buy the TOM'S tails would that fix the problem?
I saw condensation with my tails the morning after the day I got my car ROFL!
krayzie is offline   Reply With Quote
Old 01-04-2014, 07:55 PM   #790
Foobar
SLO NO MO
Foobar's Avatar
I have Toms and no condensation.
Old 01-05-2014, 02:57 AM   #791
wdninja
wdninja's Avatar
Drives: 2023 Toyota GR86 Premium
Tail Light Condensation
The aftermarket tail lights that come with a good enough gasket are more resistant to condensation, but could and probably will have the issue eventually if they aren't sealed to the housing with weatherstrip adhesive or the like.
My Colins didn't come with gaskets so I had to reuse my original shitty stock ones, and they leaked.
Once I started making my own replacement gaskets and sealing them to the housings, it didn't happen again on either the stock lights or the Colins.
My Valentis came with decent gaskets, but I still sealed them to the housings with 3M Weatherstrip Adhesive and they've been fine with zero condensation.
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
wdninja is offline   Reply With Quote
Old 01-05-2014, 09:38 AM   #792
RFB
RFB's Avatar
Drives: FRS
Same Same
My crystal eye gaskets were good and also sealed to the housings, but one eventually started to have condensation.
Flowing water is very erosive over time (i.e. the Grand canyon).
The constant surge of water flow eventually defeated the gasket goo.
I solved it with snow man snot over the top of the black plastic housing and body of the car to channel water away from getting under the housing and into the gaskets. Methinks the snot will also work on stock tails with no sealer as no water gets to the gaskets.
A permanent fix.
CERBERUS
Old 01-05-2014, 11:35 AM   #793
wdninja
wdninja's Avatar
A permanent fix.
Diverting the water flow is also a good idea. I can't comment on the quality of the Crystal tail lights gasket/seal as I haven't seen it. It's actually sealed on arrival? You didn't have to add any sealant yourself? The factory tails are also "sealed", but it's the equivalent of scotch tape and only on the top, so I inherently don't trust it.
Do you have a link for this "snot", as I've been unable to find it locally.
I think it's worth researching and testing - maybe even developing a more elegant version (small plastic piece that diverts the water instead of a wall of goo). I'd certainly be inclined to buy a set of plastic diverters if they existed, just as an extra precaution.
Old 01-05-2014, 12:05 PM   #794
RFB
RFB's Avatar
Drives: FRS
Crystal Eye seal
My Crystal Eyes were second hand properly sealed, (I believe the gaskets were properly sealed by the factory).
Snow man snot is available at any stationary store - (the stuff to stick notes on fridges etc.). Non toxic, waterproof, doesn't melt in the summer, easily pliable, removable etc.
And only 99 cents ! Kamset Power Tack (or equivalent) - 4 sticks in a pack - all you need.
CERBERUS
Old 01-06-2014, 06:05 PM   #795
RFB
RFB's Avatar
Drives: FRS
CERBERUS
pic of snot fix
Old 01-09-2014, 05:34 PM   #796
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
So it's back again and pretty bad.
I'm past the warranty (over 36K miles), is the taillight still a TSB and i can get it replaced for free? Or am i screwed now?
I picked up some silica packets, i'm going to give those a try. Also going to try and sealing the taillights.
Old 01-09-2014, 10:25 PM   #797
RFB
RFB's Avatar
Drives: FRS
Past-SCREWED
Depending on how much water - an alcohol wash or drier packs
Then silicone seal gaskets and snot
CERBERUS
Old 01-10-2014, 12:40 AM   #798
wdninja
wdninja's Avatar
If you're able to have the tail lights out of the car for a couple days, putting them in a box with a bunch of rice in it also does wonders to wick away moisture. That's what I used when my original stock tails first had condensation issues.
Red tail light photoshops OwenK FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 68 02-06-2013 03:48 PM
HKS head and tail lamps DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 5 05-19-2012 01:04 PM
Tail of the Dragon Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 32 02-10-2012 02:30 PM
headlight condensation MRZ415 Off-Topic Lounge [WARNING: NO POLITICS] 1 01-23-2012 02:24 AM
Optional coloured tail lights? m_life Scion FR-S / Toyota 86 GT86 General Forum 9 11-30-2011 06:20 PM
