Old 10-24-2020, 10:30 PM   #785
DIY
DIY's Avatar
Drives: BRZ, WRX
Very cool, DCT will be fun!
Follow me on Instagram: @brzdiy
My Build Thread
DIY is offline   Reply With Quote
Old 10-25-2020, 12:43 PM   #786
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
2021 outta be fun!
Old 11-30-2020, 03:37 PM   #787
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Black Friday was a bit of a mess for me. Spent way too much money, but most parts should be on their way for the car.
Emtron KV8 w/ FRS canbus
Emtron Flying lead harness
Haltech IC-7 Dash Display
Billet VVTI Valve Covers
R35 Coil Mounts for 2jz
Hall Effect sensor kit
Ebay-ish FFIM
FBM 485 pump kit
HTG Ecu (Trans Controller)
Wiring plug for Trans
Driveshaft adapter to go from BMW to Spicer
Wiring Supplies for Trans modifications and Harness building
Engine Sensors (Who knew these would be so expensive )
KLM "800-1000hp" Intercooler. I was more interested in the sizing, 32x10x4. Which should fill the grille nicely.
I will need to pick up little things here and there. Oil cooler, trans cooler, -8 fuel line stuff, intercooler piping kit.
Also still trying to decide on turbo manifold. It's come down to Treadstone Log manifold $415
or the XS Power Tubular Manifold: $400
(finding picture).
Hoping I can get work done during winter so the car runs sooner than later, not holding my breath though.
Edit: Bought the treadstone, was able to get a cyber monday deal on one.
I also have a TSSFab tubular front subframe on the way. They only go on sale once a year and I couldn't pass it up
DustinS is offline   Reply With Quote
The Following User Says Thank You to DustinS For This Useful Post:
DIY (12-01-2020)
Old 12-02-2020, 02:13 PM   #788
DustinS
DustinS's Avatar
Got the IC-7 in super quick. So I got to work fitting it into my old cluster.
Plan is to put a sheet of carbon back here to cover everything but the plugs
Just need to work out a spacer for this. Shouldn't be an issue
Irace86.2.0 (01-05-2021)
Old 12-14-2020, 07:28 PM   #789
DustinS
DustinS's Avatar
Exhaust Manifold came in, going to clean up and polish the insides. Going to need to port the wastegate hole and get an adapter to v-band.
Adapter came in mail as well. 3 day shipping from Sweden
ECU w/ Wiring showed up
GCU
Nice 4" thick intercooler. Might look at V-Mounting it?
I also (hopefully) canceled my order for the Full Blown 485 kit and ordered a surge tank. This tank was only a tiny bit more than the Full Blown kit and includes two pumps. Should eliminate any fueling issues.
also bought a fuel filter with integrated check valve. Wondering if it would be work checking/removing factory filter. It's really not replaceable though. So it would be replacing the fuel basket top.
With the fuel system change, I plan on upgrading to -8an feed. Looking into hard lining the feed lines. It ends up being a decent amount cheaper, although more time consuming. I also have started looking into possibly running hard line for some of the trans cooler lines. Again, mostly because it's a large cost saving with no real downside other than time consumption.
Dropped off the shimless bucket lifters off at the Machine shop today along with the cams. He said I should have the head back by the end of the week. I am hoping to get a garage spot here soon so I can start tearing the car down for everything.
VS Racing had a christmas sale and I was able to snag a Billet Wheel dual ballbearing 67/66 for a good price. 4 week wait for that, but shouldn't hold me back any haha. Especially with the fact I haven't heard anything about quite a few of the parts I ordered for black friday. Mostly intake manifold, engine sensors, and valve covers/coil mount kit.
Old 12-19-2020, 01:29 AM   #790
jflogerzi
jflogerzi's Avatar
This thing is gonna be a frankenstein of a car
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
DustinS (01-04-2021)
Old 01-04-2021, 07:00 PM   #791
DustinS
DustinS's Avatar
Rods/pistons installed, and head picked up from the machine shop
Toyota Shimless buckets (drops almost a pound out of valvetrain) on GSC Valve Spring kit, GSC Bronze Guides, Stainless intake valves, Inconel Exhaust valves, and a nice valve job (multi-angle different on intake and exhaust per machine shop recommendations)
Turbo also came in. VS Racing Dual Ball Bearing Billet wheel 6766.
Old 01-08-2021, 12:40 AM   #792
DustinS
DustinS's Avatar
Plan was the get the head installed, but I found I was missing a head dowel. So I just installed all but one of the studs and set the head down temporarily. I ordered a new dowel along with a ton of other hardware and new timing belt covers. Excited to see all those new parts. Anyway, on to the pictures
Fancy CA625 studs:
Most of my new sensors came in. Bosche Temp/Pressure sensors (with threading adapter), Bosche Motorsport Air temp sensor, Bosche Wideband Knock sensors, and R35 coil connectors. Just waiting on USPS to deliver the 4 bar map sensor
Knock sensors come with mounting stud and even a wiring boot:
I also made a very spontaneous purchase and something I definitely shouldn't have spent money on, but it happens.
New Body Kit:
The Following 3 Users Say Thank You to DustinS For This Useful Post:
DIY (01-08-2021), KMA KiCKz (02-07-2021), Satanasso (02-06-2021)
Old 01-08-2021, 04:47 AM   #793
DIY
DIY's Avatar
Drives: BRZ, WRX
That's a nice looking kit!
My Build Thread
The Following User Says Thank You to DIY For This Useful Post:
DustinS (01-08-2021)
Old 01-19-2021, 02:42 PM   #794
DustinS
DustinS's Avatar
Putting in work when I can. Just playing waiting games mostly.
I also made the mistake of adding up my invoices from work on OEM hardware... Just about $500 in just OEM nuts/bolts/covers (and that is at employee cost). New OEM hardware for everything engine related. Wasn't sure what I was missing, and didn't really want dingy hardware on a new looking engine.
Anyway. On to the few pictures
Tensioner bolt isn't tight because I didn't have the washer behind it, which is 100% required and a specific size.
New VVTI filter
PHR Timing Belt Tensioner w/new shoulder bolt
New Crank bolt and timing belt "guide"
PHR oil filter relocation adapter
PHR GE Upper water outlet to -20an adapter. Need to order new hardware for this as I have contacted them a couple times now and haven't received them.
New OEM water pump accessories. Still waiting on the elbow to come in.
Couldn't resist. Still in the middle of rebuilding the VVTI gear and waiting on Timing belt to come in before I can finish it this far.
Cleaning up the VVTI gear. Getting the cover powdercoated hopefully tonight. Still not sure what color, four to choose from. Also waiting on the O-Ring to come in.
Colors I am deciding between
Blue Flake over Black
Chameleon Violet
Wetstone Midnight Texture
Midnight Metallic (Which is pretty much black unless you have direct sunlight)
Thoughts on color choice?
Old 01-22-2021, 08:14 AM   #795
DIY
DIY's Avatar
Drives: BRZ, WRX
of those I think Wetstone Midnight Texture looks best.
My Build Thread
The Following 2 Users Say Thank You to DIY For This Useful Post:
DustinS (01-29-2021), tintumz22 (01-27-2021)
Old 02-06-2021, 12:59 AM   #796
DustinS
DustinS's Avatar
Got the turbo and manifold mocked up. Sticks out really far, and I'm really hopeful it fits in the chassis without modification. Definitely going to need to move the coolant tank.
I also started mocking up the LS alternator to see if I could make it work. I think it just needs a small bracket from the oil pan and should be good to go. I will also make a spacer to fit the top instead of the stack of washers. Should allow coolant hose to go between as well.
I also just received my Intake. Looks pretty decent for the price. Either going black or same blue as cam gear.
Uses an O-Ring to seal to the head
Fuel rail will be coated as well.
DIY (02-06-2021), jflogerzi (02-06-2021), mrg666 (02-07-2021)
Old 02-06-2021, 04:41 PM   #797
Lantanafrs2
Drives: 2013 frs red
Check that valve cover for any grit when it comes back from powder coating. Give it a thorough cleaning just to be sure. From experience
Old 02-07-2021, 03:03 PM   #798
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
That kit is frickin sweet!
I'd also go with the Wetstone Midnight Texture
- My 2015 Scion FR-S OEM+ Build Thread -
TRD | Brembo | RAYS
KMA KiCKz is offline   Reply With Quote
The Following User Says Thank You to KMA KiCKz For This Useful Post:
DustinS (02-10-2021)
The reason I'm always broke - Dustin's Supercharged 86 Dustin Member's Car Journals 211 11-08-2015 11:57 AM
Help! New Car Engine Blew Up. What are my rights? Obsidiank Scion FR-S / Toyota 86 GT86 General Forum 53 12-11-2014 12:43 PM
Midwest Modified - Auto Photography by Dustin Faulkner (aka Fancy) Kuzuri Great Lakes 20 02-16-2014 06:23 PM
Engine Warm-up Time Chad86 Scion FR-S / Toyota 86 GT86 General Forum 44 01-10-2014 01:03 AM
So my engine blew up.... alliedcam1 Engine, Exhaust, Transmission 57 12-28-2013 03:50 PM
