Old 04-20-2024, 04:25 AM   #785
Eaton PSI
Drives: 2013 86
Heat exchanger fitted under filter
Engine running! Oil change is about 5.5L with the sump spacer.
Pressure is good with the big pump. When cold its very high, bottoms out the 100psi gauge at about 1500rpm. I have fitted a heat exchanger (WRX, Forester? Not sure...) to help heat the 0w-30 oil quicker.
When hot its about 12-14psi at idle and tops out at about 85psi when spinning fast.
Even with the heat exchanger it takes more than 10mins of gentle driving to get the oil hot. Perhaps this is where bearing damage is occurring. Cold oil, very high pressure, very little flow. The tiny amount of oil in the bearings will get super heated if you push it hard before its properly up to temperature. Also the internal bypass in the filter may open and let sediment and unfiltered oil through your engine.
The water temp is not a good indicator as it heats up much faster than the oil does. The only way to be sure is to get a gauge and monitor the oil temp and/or pressure. Be nice to your engine when its cold and it will probably last much longer.
Eaton PSI is offline   Reply With Quote
The Following 3 Users Say Thank You to Eaton PSI For This Useful Post:
DocWalt (04-22-2024), NoHaveMSG (04-20-2024), Tatsu333 (04-21-2024)
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 02:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 05:19 AM
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. FRSport.com Engine, Exhaust, Bolt-Ons 0 01-10-2014 12:33 PM
FA20 Le Mans Race Engine SilverSkyline210 Engine, Exhaust, Transmission 11 11-17-2013 11:24 PM
