Old 08-18-2019, 12:24 PM   #785
pedroFRS
Drives: 2016 SCION FRS
Originally Posted by Toyarzee View Post
Just threw in some spc camber bolts, TRD springs, 17x9 et35 rpf1's in gunmetal/dark silver with 235/40 NT01's. The bead came out right at 9" and the sidewall is not stretched at all. Pretty damn happy with the outcome. I also support the million and one +1s on this setup, it really is a good fit for the car.
And yes, I'm daily'ing this
I have trd springs too and thinking of getting this 17x9 +35 and wrap it with 245/40/17. Will there be issues with this setup? Thanks....
pedroFRS is offline   Reply With Quote
Old 08-18-2019, 03:47 PM   #786
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Might want to also get camber bolts to reduce the poke in the front, but otherwise this is one of the classic good combos in this budget.
timurrrr is offline   Reply With Quote
Old 08-18-2019, 04:20 PM   #787
pedroFRS
Thanks.... where do you get the camber bolts? Any link?
Old 08-18-2019, 04:44 PM   #788
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
https://www.amazon.com/dp/B00DJBPOE4
Old 08-18-2019, 05:06 PM   #789
pedroFRS
Thanks again... the rear should be fine I think... I will get those camber bolts...
Old 08-20-2019, 12:11 AM   #790
pedroFRS
By the way, did the OEM lug nuts work on the RPF1? And did you guys use the OEM toms sensor from the stock wheels?
Old 08-20-2019, 02:44 AM   #791
strat61caster
strat61caster's Avatar
Yes on the lugs
tpms is a personal choice on how much money you want to spend, could buy new ones, swap stock ones, could ignore them, up to you.
ineedyourdiddly
Old 08-20-2019, 12:17 PM   #792
pedroFRS
Yes on the lugs
Thanks
Old 08-24-2019, 11:52 PM   #793
pedroFRS
Got it installed yesterday.
TRD springs
245 40 17
17x9 +35
The Following 6 Users Say Thank You to pedroFRS For This Useful Post:
JesseG (09-18-2019), MCTeeJ (09-18-2019), Summerwolf (09-18-2019), SuperTom (12-03-2019), timurrrr (08-25-2019), Will BRZ (08-25-2019)
Old 08-25-2019, 12:20 AM   #794
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
TRD springs
245 40 17
17x9 +35
Super clean bro congratulations on the setup. How has the transition been from stock to this?
Will BRZ is offline   Reply With Quote
Old 08-25-2019, 02:15 AM   #795
pedroFRS
Started with TRD springs first last year. Waited for the OEM tires to run out. Wheels and tires yesterday and I like how it turned out. Simple!
Old 09-18-2019, 08:41 AM   #796
WC-BRZ
Drives: Black BRZ
Congrats! Looks beautiful. So just to confirm, these wheels actually do clear the stock spring perch? Are you able to take any pics by any chance? Just wanted to get an idea how far it actually is from the perch...
Any other rubbing issues lock to lock?
Also, how much is the drop on the TRD springs? How are you liking those springs paired with OEM shocks btw?
WC-BRZ is offline   Reply With Quote
Old 09-18-2019, 05:14 PM   #797
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
The TRD springs are a perfect drop, I bought my car with them so I don’t know the exact drop, but probably 1”?
Ride quality to me is controlled and slightly stiffer than stock springs. The rebound feels a little too strong on rough pavement.
JesseG is offline   Reply With Quote
The Following User Says Thank You to JesseG For This Useful Post:
WC-BRZ (09-20-2019)
Old 09-20-2019, 10:16 AM   #798
pedroFRS
No rubbing issues at all....
The Following 2 Users Say Thank You to pedroFRS For This Useful Post:
WC-BRZ (09-20-2019), Will BRZ (09-20-2019)
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 12:13 PM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 02:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 05:53 PM
