Old 09-24-2014, 04:53 PM   #771
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Originally Posted by DeliciousTuning View Post
What version of the Flash and Go map are you on? We are working on a pretty extensive revision right now which we hope to have out in the coming weeks.
Fixes a lot of the smaller issues, drivability, startup, between shifts, etc...
Cheers,
William Knose
I don't know how to find this information. The tune file ends with V12.48 if that helps?
post_break is offline   Reply With Quote
Old 09-24-2014, 04:58 PM   #772
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Then you are on version 12.48.
We are around 14 right now and will be releasing updates soon.
Old 09-24-2014, 05:58 PM   #773
maxjedi
The Cloudmaker
maxjedi's Avatar
Drives: GT86, G37S
I hope it will also include better top end for more power! Current version showed 266whp (dynojet) on 12 psi and aftermarket exhaust. I'm sure you can improve that.
... my build thread: maxjedi's turbo "daily drifter" GT86 ...
maxjedi is offline   Reply With Quote
Old 09-24-2014, 08:14 PM   #774
DeliciousTuning
Yes it does. I think you are on version 12.XX which had the power lowered a bit on the top end due to a couple kits having some issues on the top end. Though that has been resolved and now the new tune will add the power back in.
I would expect to see an increase of about 20+ horsepower on this new setup. As an FYI this tune is also being tested on my personal car now daily. Though I have an Innovate Supercharger setup it offers a wide range of testing and runs about 11 PSI of boost near redline.
The FlexFuel is also built in, along with refined boost control, and upgraded traction control based on ethanol content. As the power increases from the ethanol (power) we have pulled power out a bit to regain control.
So more features coming, including the main points, drivability, top end power, startup (euro customers), dyanmic traction control based on ethanol content, boost control (working on some new cool features for this also) and a few more things.
Thank you all very much for your patience. We have not forgotten, just been very busy catching up on projects and making headway for the future.
Cheers,
William Knose
The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post:
8686 (09-25-2014), GremlinGSP (09-25-2014), maxjedi (09-24-2014)
Old 09-25-2014, 10:27 AM   #775
post_break
post_break's Avatar
I threw a P0138 code this morning which just blew my mind since I have been running this tune for ages. I guess add that to the list of disabled codes who don't use a rear O2 sensor.
Old 09-25-2014, 07:11 PM   #776
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
Ive been throwing both a P0137 and a P2096. Have been waiting on Will/Zach to get back to me with this disabled since August 9th.
Shneegle is offline   Reply With Quote
Old 09-25-2014, 07:39 PM   #777
DeliciousTuning
I am sure you sent an email, but please email me again, name, dongle ID, and tune you purchased. I will get that update out to you.
Though those codes are usually from a spacer in the rear O2, an anti-fouler. Just remove that and it should resolve the problem.
Old 09-25-2014, 08:00 PM   #778
Shneegle
Shneegle's Avatar
Email sent, and Ill get the spacer out asap. Was not aware I should have left that out.
The Following User Says Thank You to Shneegle For This Useful Post:
Old 09-26-2014, 12:40 AM   #779
DeliciousTuning
13.79 at 99.45 mph with NO forced induction.
Delicious Stage 2 Tune, E85, Full Interior, headers back, panel filter and good tires. Video to follow.
Cheers,
William Knose
Old 09-26-2014, 08:01 PM   #780
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Just had the exedy stage 1 clutch installed now there is a noticeable idle drop and engine sounds like it's knocking. Does the ecu have to re learn? If so how long does that take? Thanks!
texasbound972 is offline   Reply With Quote
Old 09-26-2014, 08:07 PM   #781
protpibe
protpibe's Avatar
The more prominent idle dip is probably because of the lightened flywheel. The rattle you're hearing is gear clash (sometimes called clutch chatter as well) . Both are somewhat normal and won't cause any issues. The idle will sort itself out a bit but will probably always dip a bit if you're Revving it with the clutch in.
Do you have a lightened crank pulley?
The Following User Says Thank You to protpibe For This Useful Post:
Old 09-26-2014, 08:19 PM   #782
texasbound972
USMC
Yes.
Old 09-26-2014, 08:20 PM   #783
texasbound972
USMC
I hear the rattle from the engine not the transmission
Old 09-26-2014, 08:37 PM   #784
protpibe
protpibe's Avatar
Does the rattle go away when you press the clutch in?
Also, I also had idle issues with the LWCP combined with a lightened flywheel. When I went back to the OEM pulley, it went away for the most part, however, it still dips a bit if I rev it at a stand still. I'm pretty sure it's due to the lack of inertia on the crank and the ECU not expecting such a quick drop.
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 04:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 06:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 02:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 03:33 PM
