Old 04-22-2014, 01:24 PM   #771
Model Citizen
Lacking brains
Drives: frz
You are spot on brother. I pretend that I'm a target everyday. Training classes were super helpful and should really be required for bikers. Hell, even for cagers.
After too many people not seeing me i painted my helmet safety yellow.
Tennisball head helped a ton.
Model Citizen is offline   Reply With Quote
Old 04-22-2014, 02:41 PM   #772
Originally Posted by solidONE View Post
Wow that's harsh, Mike. I've been working on and with cars for a bit. While not very proficient with one on track yet. I think I have a decent idea how a car works.
What would you consider as prepped for stock class with your rules?
My setup:
Added camber from bolts all 4 corners maximum adjustment except for RR.
w/o driver in seat:
FL: -1.8 FR:-2.0
RL: -0.8 RR:-1.3
Front toe:0 Rear toe: 1/16"~1/32" in
Pads, Brake/Trans/Diff Fluids.
RS-3 225 on stock wheels.
Drop in filter. Track pipe.
Air/Oil Separator.
3-pt 4130 Strut bar
Want to add:
Oil cooler. for the upcomming 100+ track temps.
19-20mm front sway to decrease roll.
To me , fast or quick (not necessarily 500+ HPS 200MPH monster machines a miata or FR-S will do) and control is the goal, setting up cars is what we do to help get there. And it's all fun when things are progressing in a positive manner.
So you are recommending VSC on, it sounds like. Some say off other say on. If leaving VSC on will help me be smoother, that is exactly what I'll do.
Chuckwalla was the first time I did not see any progress in terms driving or riding ability or lap times. Actually regressed. So I guess you can say it was the least fun I had on a racetrack. lol Still fun, but depressing at the same time. I hope to change that with some pointers and instruction. My friend with the Cayman S OTOH he was hitting all his goals for that day getting faster each session out. Ended with a 2:08 flat on KW V3, some beat up used mismatching RS-3's, sway bar, and some alignment tweeks he did in his garage himself. Now, he had a lot of fun at Chuck's.
Edit: I want to add that my second track day with this car you drove my car a few laps with me in it. You did not say much, but you did suggest that I turn the TC completely off (as did the previous coach did at buttonwillow)IIRC. I was not able to learn much from the experience due to lack of communication verbally and the huge difference in our pace (super fast vs super slow). You seem to be pushing the car pretty hard as evidenced by the constant corrections with steering you were making. All I got from that was "damn that guy is fucking fast" Clocked you at 1:33 with harry's timer. I personally did a 1:38.9 before the heat got to me (113 degrees ambient when I checked) and headed home. No videos doe to the overheating iphone. Car only had RS3 225 (same set I used at chucks) on RPF1 17x8, a set of camber bolts, and about 2500 miles on the ODO nothing else.
I'd recommend you run 0 toe in the rear, and learn to control the car.
A larger front sway will only make the car understeer more at terminal, and make any oversteers come on faster/harder. Roll isn't a bad thing. Have you seen who much roll we get with 10k/12k?
If your objective is lap times, then leave TC/VSC on. If your objective is to learn to drive the car, then turn TC/VSC off. Right now, at your level of driving, the two are mutually exclusive. You need to decide which is more important, your lap time or your driving progression. I'll tell you now that focusing on your driving will ultimately result in faster times.
I make a lot of small corrections because I'm trying to stay on the right line, not because I'm fighting for control. If I were past the limit of grip, there wouldn't be any grip left to correct with.
I've said this over and over: Seat time is king.
Old 04-22-2014, 03:12 PM   #773
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
@CSG_Mike
Agree on the tire sizes. The guys out here who I've seen racing them moved down from 275 tires to 245 because they handle better with them.
Being an official for a few different race series here on the East Coast, we've used tire widths to slow down cars that were over powered for a class. In particular a spec Cayman series I work with. The Gen 2 cars have a 35hp advantage over the gen 1 cars so they decided to require a wider tire on them which has slowed them down considerably in the straights while providing no additional grip in the turns.
-mike
AZP Installs is offline   Reply With Quote
Old 04-22-2014, 05:03 PM   #774
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by CSG David View Post
I haven't timed my laps in over a year.
Learning how to drive based on theory without application is like this example:
You want to learn how to swim so you learn all the theory behind every single stroke and technique possible to be the best swimmer in the world. What happens if you decide to actually put all that knowledge to work and finally immerse yourself into a pool? Are you going to turn into a Michael Phelps and win multiple Olympic Gold Medals?
The moral of this story is to show that whether or not you have the best knowledge in the world, it doesn't matter when you start executing and applying it. Application helps you understand that theory better. Your body does not know how to respond or react to these situations yet. Only your mind knows. Because of that, you need to train your body to respond exactly to what your mind wants you to do. With that said, we hope to see you out on track more.
Why is that you haven't timed yourself? Are you no longer trying to get faster? Or just don't care about lap times any longer? Very interesting, but probably not a mindset I will be in or understand any time soon. But yes I definitely know the value of practice. It applies to anything, so no need for analogies. Lol I hope to get out there much more often as well.
Old 04-22-2014, 05:26 PM   #775
Because Bunta.
Old 04-22-2014, 05:29 PM   #776
CSG David
CSG David's Avatar
I've been away from the track for a long time so I'm focusing on my driving skill rather than absolute times. Even though I was lapping approximately 2:04 to 2:06 at CVR that one day in my own car (based on video and times from other cars), I cared more about taking the right line and learning zero counter more than laptimes themselves. It will translate to sub-2 minutes in the future, but for now, confidence and driving skill are more important.
Old 04-22-2014, 05:29 PM   #777
kavanagh
Fat on Corn Syrup
Because Bunta.
Hahahahaaa!!!!!
That's it. Harry's Lap Timer is goin in the garbage
Old 04-22-2014, 05:31 PM   #778
CSG David
CSG David's Avatar
gdi...I only want to be like Mike...
Old 04-22-2014, 05:32 PM   #779
I wish I could ball like Mike too
Old 04-22-2014, 08:44 PM   #780
AZP Installs
As you already know, being smooth always translates to being faster. Timed or not.
I also don't remember when I last timed myself other than as you have anecdotally for reference. You KNOW when you have a fast lap and when you have a tense lap that isn't fast but feels fast cause you did it all wrong.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
Old 04-22-2014, 11:20 PM   #781
CSG David
CSG David's Avatar
Moar gas means faster.
-Mike Paisan
Old 04-22-2014, 11:24 PM   #782
gramicci101
Off Topic
"Less brake, more gas!"
- probably Juan Manuel Fangio
Old 04-22-2014, 11:58 PM   #783
CSG David
CSG David's Avatar
It has been quoted countless times at the track...
Old 04-23-2014, 12:06 AM   #784
becauseracecar1
becauseracecar1's Avatar
Drives:
Do you guys recommend putting that blue painters tape on my car for trackdays or is that only a auto x thing?
Thanks!!
becauseracecar1 is offline   Reply With Quote
