Old 02-20-2017, 02:59 PM   #7799
bfrank1972
Drives: 2013 FR-S Argento
Originally Posted by ajcarson11 View Post
Ordered Moto East Flex Fuel kit today! Getting excited now that I've located 2 seemingly-hidden stations nearby with E85.
Going to run stock injectors initially to get an idea of where things stand, but expecting to upgrade injectors. Figure i'll change one thing at a time, instead of 2 things at once.
Pretty sure you'll need bigger injectors as E85 runs a lot richer and you'll probably be pressing 280-290 whp. Might just want to jump in and do it, so you won't have to spend money on a new tune - but talk to Mike about it and take his advice.
bfrank1972 is offline   Reply With Quote
Old 02-20-2017, 03:36 PM   #7800
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Thanks --
Yes. I have talked to mike. I'm running non-intercooled at moment, and only on the 72.5mm pulley. Mike mentioned that I might be OK considering the above -- We will find out soon!
I don't expect to be up at 280-290 necessarily -- as I'm not running intercooler, or 69mm pulley.
We will see what mike says!
ajcarson11 is offline   Reply With Quote
Old 02-20-2017, 03:44 PM   #7801
xjohnx
Grip>Slip
xjohnx's Avatar
Thanks --
You should be more than fine on stock injectors from my experience. I'm ~310 to the tire now (intercooled, 69mm, flex fuel) and still fine with stock injectors.
Old 02-20-2017, 04:15 PM   #7802
bfrank1972
Thanks --
He's the man that knows, especially when it comes to these Sprintex kits. I know that fuel capacity can be stretched because we have both DI and port injectors, just not sure if that limits you in other areas. I'd bet E85 will surprise you how it transforms your power output, even on a non IC syste
Old 02-20-2017, 04:32 PM   #7803
ajcarson11
I'm excited for that! I bet I will be surprised as well, and definitely have no issue with upgrading injectors, and eventually clutch (as I will imagine that will be the next thing).
I'm going to monitor temps and blow-by and may do catch cans and intercooler just for longevity. I've not seen high temps under daily driving yet.
This will be my last power upgrade on this car unless I build the motor!
Old 02-21-2017, 10:42 AM   #7804
xjohnx
Grip>Slip
xjohnx's Avatar
Anyone upgraded the intercooler's pump to this one? Any improvements?
http://www.moto-east.com/store/subar...oler-pump.html
Old 02-21-2017, 11:55 AM   #7805
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Running high boost no intercooler aggressive tune on gasoline!
Don't waste you're money on IC!
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 02-21-2017, 07:40 PM   #7806
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I have that pump sitting in my garage right now, I'll be doing a write up for us/Mike.
It's MASSIVE compared to the baby one that comes in the s/c kit. Should work really well.
Old 02-22-2017, 10:34 AM   #7807
CarzCarzCarz
CarzCarzCarz's Avatar
Drives: 2014 WRB BRZ
Alright, looking forward to hearing about it. Thank you
CarzCarzCarz is offline   Reply With Quote
Old 02-22-2017, 12:18 PM   #7808
sirsol66
Drives: 2013 FRS- Hot Lava
So question for the innovate owners. I'm planning on purchasing this kit (already own another twin with the vortech kit) for my 2.0 as an "easy, bumper removal free" (to avoid the dreaded bumper gap) forced induction.
I recently took a drive in a twin with this kit+ stock air box and the sound was not where I wanted it to be. I know many people run the perrin intake (which significantly amplifies the sound) but I do not want to since you have to remove the bumper to install it.
So, question: Are there any "short ram" style intakes (which do not sit inside the bumper) that can be used for this supercharger? I believe airraid works as well but I'd prefer an open filter. I dont track the car and live in Michigan, so I'm not worried about heat soak.
Any suggestions?
sirsol66 is offline   Reply With Quote
Old 02-22-2017, 12:43 PM   #7809
riboyster
riboyster's Avatar
A lot of us here are on the quest for more power, and would probably avoid that kinda intake.
You should throw a post on the intake thread as well.
What's up with not wanting to drop your fender?
Old 02-22-2017, 01:45 PM   #7810
xjohnx
Grip>Slip
xjohnx's Avatar
Going to still power it off the injector harness or a different method?
Old 02-22-2017, 02:05 PM   #7811
continuecrushing
No, I wasn't a fan before of that powering the pump, and this new one is HUGE. Gonna setup to power off a relay. I'll have a write up/video done though.
I don't know how much power goes through the injector wire, but there's no way it could support this pump reliably.
Old 02-22-2017, 04:40 PM   #7812
Kodename47
Kodename47's Avatar
Drives: UK GT86
Does the pump definitely draw more current rather than just being a bigger pump?
.: Stealth 86 :.
Kodename 47 DJ:
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
