02-13-2022, 08:47 PM | #757 |
Drives: Whiteout track car; lava donor
Regarding post #751.
From further down the page you quoted: •Smooth: k24 with stock oilpump •drivable: k20 with 60a is okey •my worst nightmare, a high comp (12,5:1 or higher) k24 with k20a2-oilpump! It’s kind of hard to argue with “worst nightmare” especially since he has driven so many k engine cars. While my car spends most of its life on track, I still want to drive the ~150 miles each way without having to trailer it. The vibrations will drive me crazy. Could it be as simple as running the “correct” oil pump? With the kpower kit, it’s an oil pan clearance issue, correct? That’s why they have you ditch the perfectly fine pump that come with the k24a2 and replace it? |
02-13-2022, 09:48 PM | #758 | |
Wears Pants
Drives: 14 FRS K24 swap - SOLD
The pump replacement kind of fixes two issues. Pan clearance but also adds quite a few extra RPM. Also I think it's worth noting the vibration that I am experiencing is mostly within a certain RPM under load. If I'm putting along the highway at 3k it's completely manageable. If I were further into the 4k range just holding it there you will notice it considerably. Above that or below is a nice mellow spot. I cruise around town mostly in the 2k range. With the old fa20 I could never feel comfortable in that range because it lacked any torque to get up to speed without needing to downshift 1-2 gears. The k motor doesn't seem to care as much. Personally I find it easier to drive compared to the fa20 in so many ways. |
The Following User Says Thank You to captain awesome For This Useful Post: | Four_wheel_drifts (02-13-2022) |
02-13-2022, 11:54 PM | #759 | |
Drives: Q5 + BRZ + M796
I need to do some testing on the vibrations and finish the tuning process before I make my final review.
02-14-2022, 08:39 AM | #760 | |
Wears Pants
I'm curious about your sound deadening as I was going to begin the process myself to quiet road noise and kill some audio buzzing/rattles. Did you do anything by the trans tunnel? Got a thread? |
02-14-2022, 01:07 PM | #761 | |
Meow
Drives: GT86, Volvo 996
Is there a video of this engine vibration? Could it "simply" be a matter of running overly hard silent blocs in the drivetrain? Has Irace tried running with the shifter disconnected from the tunnel (if that's even possible)? I did see a rise in NVH in my car following something as benign as using hose clamps around the two rear axleback SBs (which needed shortening), these can make a huge difference. |
02-14-2022, 01:24 PM | #762 |
Yes, it is all in my build link in my sig. I did everything except the firewall. I wonder what type of vibrations I would get without it. I can only imagine.
02-14-2022, 01:48 PM | #763 | |
I still need to see what I can do, but it might just be the driveshaft because that seems to be a recurring issue for people. Overall, as it sits now, it is night and day different in rattles. I can't disconnect the shifter without going to a IRP or something. I actually don't get much vibration through my shifter compared to other vibration and noise. I don't know if the driveshaft isn't aligned perfectly, but then in my mind, the driveshaft would always be loud and not quiet on the highway. The bump in vibration is like the bump in noise a person would expect going from a stock exhaust to a cat-less setup and an aftermarket catback, which is to say large, but not so bad the car feels like a straight piped race car. This video below kind of puts to words my same thoughts. My Lancer had these 5-10 pound rubber weights attached to the front of the front crossbar behind the bumper, and they were there to add a counter weight to offset vibration resonance. I removed them, and there was more vibration, but it wasn't a huge bump. The difference between an Accord and CTR with no or smaller balancing shafts on the CTR isn't a huge difference. This vibration is huge like in the video. If I can get a video later then I will do that.
02-14-2022, 08:03 PM | #764 | |
Road-hole
Drives: 2013 Whiteout FR-S
I'm thinking...
Here's why. A while back I drove to houston from SoCal for mud engineering school. Right after I got there, my car wouldn't start. I started diagnosing it and it was fuel, not spark, and since my eventual intention was to add FI, I went ahead and ordered an AEM 340lph in tank fuel pump. I still couldn't get it to start. I'm working on the car in a hotel parking lot in Houston. Between waiting for parts and everything, it took 3 weeks to get it working. I finally had to direct wire the fuel pump using a regulated 12v source. This worked. I deduced that since it wasn't the fuel pump relay, that it must be the fuel pump module (located behind the passenger side rear interior panel). I ordered a new one, but the car was running fine the way I had it so I didn't worry about it. FF to just recently when I finalized what I was going to do and I did it (twin supercharger install). Then all of a sudden when I'm logging, it starts running really rich when under light load. Like peg the O2 sensor level of rich, but under boost/under moderate load, the commanded and the actual are almost dead on. So my thoughts are the ECU is trying to limit the voltage to the fuel pump and the pump is just pumping away, so when it doesn't need as much fuel, it's overloading the fuel pressure and running rich, but when it does need the fuel, it runs right. So I just replaced the fuel pump module and rewired it back to the fuel pump and we'll see if that makes a difference. I'm thinking it has to, because nothing else makes sense. Jaden |
02-14-2022, 08:50 PM | #765 |
Drives: Crapcan
It is on the stock system. I have one controller on my desk and another on a chassis harness I just got. It is a little silver box behind the panel next to the passenger rear seat.
02-14-2022, 09:37 PM | #766 | |
Drives: brz
Regulator is not a sensor, it's a regulator like other oem regulators. Your pumping more fuel than the bypass, regulator and engine are flowing so pressure goes up. The controller works great. It ran a 535lph thru the factory jet pump, bypass and fuel dam nozzle. Last edited by brzlegend; 02-14-2022 at 09:50 PM. |
02-14-2022, 10:37 PM | #767 |
Maybe getting the stock driveshaft shortened locally is the ticket. Likely another advantage of the kpower kit retaining the stock trans and rear end.
I’ve never had this done. Can’t imagine it costing the almost $700 kpower’s aluminum driveshaft. |
02-15-2022, 02:35 AM | #768 | |
I mentioned it before, but I need to check that there is no rubbing anywhere from the oil pan to the strut tower to my downpipe and everything. I will also double check the engine mounts and make sure everything is secured. Overall, the car seemed less obnoxious today on my drive, so maybe I just needed some time with it, to break it in and to give the Haltech time to fine tune the driveability.
02-15-2022, 10:45 AM | #769 |
Wears Pants
I'm in contact with a local driveshaft shop that I previously planned to use for shortening the stock one. I've taken measurements and the front section will need to be shortened 5 1/2". This will be a fairly short piece before the carrier bearing but I think it will still work based on my discussion with the shop. It was mentioned that as long as I'm under a 20 degree angle of approach it will work fine. I probably will need to space the carrier bearing down just a smidge but if the angle isn't much it can be left alone. I plan to drop by the shop this afternoon or tomorrow and hopefully have a finished product by the end of the week.
I've also looked at shortening the stock shifter carrier. I plan to cut and have it welded back together to fit in the stock location. The front centerline marked above will need moved roughly to next longer line in sharpie. I may need to angle or pie cut the front hinge mount at the tail of the trans to get the right position. It may take more head scratching to get right but it looks doable as far as packaging goes. This will allow me to remove the solid mounted shifter and removes the need for the Whiteline insert. I don't know if this will really fix ALL of the vibration. At idle when cold it has a specific resonance that seems more at the firewall than anywhere else. Similar to what Irace describes. The best way for me to describe it is similar to when I went to a lightweight flywheel from a heavy dual mass one on an E30 m42 I had. It wasn't terrible enough for me to want to switch back but was noticeable. Maybe some well placed dampening material on the firewall will help? |
The Following 3 Users Say Thank You to captain awesome For This Useful Post: |
02-15-2022, 12:40 PM | #770 | |
Here is another option if it is part of the problem: we could add some tall, rubber grommets under the hard mounting points, so it can move a little, or something like that. Just a thought.
Similar Threads | ||||
Rigid Industries SR-Series Pro Light Bar on my BRZ | Stang70Fastback | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 12-29-2019 03:13 PM |
Airlift from industries finest | J_Nasty | Member's Car Journals | 0 | 02-04-2017 01:59 PM |
Carbox Industries - Introduction | CarBox | CANADIAN Sales | 5 | 04-22-2014 01:22 PM |
86 industries | Duthebarber | Northern California | 70 | 03-28-2014 04:10 PM |
Another 86 Industries another bad experience | sikest | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 03-13-2014 01:00 AM |
