02-19-2015, 05:26 PM | #7645 |
Winter ***e engaged
Drives: Ashpalt 2014 Frs Manual
Anyone that has there car in storage going to see andre?
I want to do full fluid change, id do it myself, but i dont have a way of doing the diff , and not sure how difficult the trans would be.. Wish I had the stuff to take the fluid out of the diff, and fill it easy myself, i enjoy doing this kind of stuff! |
The Following User Says Thank You to Ft86Chris For This Useful Post: | FRSToyota86 (02-24-2015) |
02-19-2015, 06:38 PM | #7646 |
Drives: '13 Ultramarine
They're both pretty easy. If you can do your own oil change, you can do the diff and (manual) transmission as well. I've done them myself a few times. The trans and diff both have drain plugs just like the engine. For filling them, a hand (siphon) pump is cheap, and makes the job a breeze. If it's not something you want to do yourself, Andre will treat you right.
The Following 3 Users Say Thank You to roddy For This Useful Post: |
02-20-2015, 09:29 AM | #7647 |
Drives: 2014 Scion FRS Monogram 6AT
What gas is everyone running in their car? Shell 91 or petro ultra 94? I definitely get better mileage with shell 91 but the car pulls better with ultra 94...although I get the damn crickets
The Following User Says Thank You to infamous_s For This Useful Post: | FRSToyota86 (02-24-2015) |
02-20-2015, 09:33 AM | #7648 | |
Drives: FR-S Firestorm 6MT
If you think 94 pulls better, wait till you try E85 (if you have a tune for it). I get shitty mileage no matter what I use (over 10l/100kms) but that's only because I drive it like a madman. |
The Following User Says Thank You to Slick For This Useful Post: | FRSToyota86 (02-24-2015) |
02-20-2015, 09:41 AM | #7649 | |
02-20-2015, 09:48 AM | #7650 | |
The Following 2 Users Say Thank You to Slick For This Useful Post: | FRSToyota86 (02-24-2015), KingGeo (02-20-2015) |
02-20-2015, 10:01 AM | #7651 |
Drives: 2013 Scion FRS Raven
Wings and Fast 7
Gauging interest for wings followed by a viewing of Fast and Furious 7. I believe the release is April 3, 2015 and I for one am curious to see how Mr. Walker fits in to the scenario.
Interested so far: 1.George 2.Andre 3.Paul 4. Kevin 5. Craig 6. Corey 7. Ken 8. Andrew Last edited by Pbrown; 02-20-2015 at 07:43 PM. |
The Following 2 Users Say Thank You to Pbrown For This Useful Post: | FRSToyota86 (03-13-2015), OrangeGuitar (02-20-2015) |
02-20-2015, 10:57 AM | #7652 |
In!
02-20-2015, 11:02 AM | #7653 |
On a similar note, here is the F&F spoof movie. Looks pretty funny.
[ame]http://youtu.be/rz5U47xGluQ[/ame] |
The Following 2 Users Say Thank You to Slick For This Useful Post: | FRSToyota86 (02-23-2015), Pbrown (02-20-2015) |
02-20-2015, 02:05 PM | #7654 |
Drives: FRS
02-20-2015, 05:28 PM | #7655 | ||
I've noticed the same. The car is not as sensitive in the cold weather, but in the heat of summer, I can notice the difference between Shell 91 and Petro 94. So much so that I run the 94 despite the crickets I get with it. I'm also one of those 2-stroke guys...I've found adding 2 ounces of good quality 2-stroke oil to my tank at fill-up effectively kills the crickets with Ultra 94. It sounds questionable, but it works. Quote:
Can you adjust the idle speed with the OFT? I sometimes get a bit of an off-idle stumble when leaving a stop light. For a 2 liter 4 cyl, I think 650 RPM is a tad low...being able to bump it up to around 800 should cure it for me. If it is possible, that alone would make it worth the money.
The Following User Says Thank You to roddy For This Useful Post: | FRSToyota86 (02-24-2015) |
02-20-2015, 05:52 PM | #7656 | ||
That used to be a common thing with the RX-8, but in that case it was to help lubricate the apex seals. Quote:
The Following 3 Users Say Thank You to Slick For This Useful Post: |
02-20-2015, 06:19 PM | #7657 |
Drives: '17 BRZ Dark Grey Sport-tech 6MT
02-20-2015, 06:32 PM | #7658 | |
Benched 86lb
Drives: Ultramarine FR-S
The Following User Says Thank You to pushrod For This Useful Post: | jhx741 (02-21-2015) |
