03-07-2021, 05:07 PM | #75951 |
extra what?
03-07-2021, 05:08 PM | #75952 |
extra what?
save brake lines. ditch pads
The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
03-07-2021, 05:28 PM | #75953 |
Drives: RX-7 / BRZ
Scrap both. If he in the future ends up selling the car; is it worth it to swap the OEM lines back on? Will selling used aftermarket lines be worth the hassle of swapping the OEM parts back on and replacing lost fluid for a car with such poor resale value? Keep them if you want piece of mind in the back of your head should your current brake lines fail... but, even then it is only a better safe than sorry mindset.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
The Following 6 Users Say Thank You to Kiske For This Useful Post: | Dadhawk (03-07-2021), humfrz (03-08-2021), soundman98 (03-07-2021), spike021 (03-07-2021), Spuds (03-07-2021), Ultramaroon (03-07-2021) |
03-07-2021, 05:46 PM | #75954 |
ProCrastinationConsultant
scrap both. you're never going to re-use old pads, and the likelihood of pulling, replacing, and re-bleeding the entire brake system is a pretty large stretch for stainless steel lines that cost less than $200 for a whole set.
The Following 4 Users Say Thank You to soundman98 For This Useful Post: |
03-07-2021, 05:56 PM | #75955 | |
extra what?
But yeah. Toss 'em.
The Following User Says Thank You to Ultramaroon For This Useful Post: | spike021 (03-07-2021) |
03-07-2021, 06:15 PM | #75956 | |
Yeah those are good points. Plus OEM lines probably aren’t super pricey if I absolutely had to swap back someday.
Instagram: @spike.brz
03-07-2021, 06:35 PM | #75957 |
rock auto shows the soft lines are about $10/corner.
The Following 2 Users Say Thank You to soundman98 For This Useful Post: | spike021 (03-07-2021), Ultramaroon (03-07-2021) |
03-07-2021, 06:36 PM | #75958 |
extra what?
I'm super leery of braided lines chafing but I have no long-term experience. That's the only reason I would save the stock ones. Plus I already have a couple boxes of shit I'll never use again. Would be easy to toss a set of brake lines in with the rest of it.
03-07-2021, 06:39 PM | #75959 |
extra what?
Yeah but those are untested ones. How much for a known good set?
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | bcj (03-08-2021), soundman98 (03-07-2021) |
03-07-2021, 06:47 PM | #75960 | ||
But yeah hopefully they're reliable enough to last.
03-07-2021, 06:53 PM | #75961 | |
Drives: RX-7 / BRZ
Roughly $20.03 each corner for OEM.
The Following User Says Thank You to Kiske For This Useful Post: | Ultramaroon (03-07-2021) |
03-07-2021, 06:58 PM | #75962 | |
Dude, I have seen your garage
The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
03-07-2021, 07:01 PM | #75963 |
Drives: Crapcan
Random Thoughts - Part Deux [NO POLITICS]
Getting closer to done. Outside is almost done, need 3-4 more yards of gravel, put expanded steel on the foundation vents and put hand rails on the porches. Inside is just little BS. Outlets, plug covers, install backsplash, hook up sinks and toilet.
03-07-2021, 07:03 PM | #75964 |
if he's selling, it doesn't matter how bad they bulge, as long as they don't leak!
The Following User Says Thank You to soundman98 For This Useful Post: | Ultramaroon (03-07-2021) |
Similar Threads | ||||
Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 10:31 AM |
Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
