Old 10-14-2016, 04:11 PM   #7575
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
The kit works fine without an intercharger. Just gonna put that out there.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 10-14-2016, 05:54 PM   #7576
Kodename47
Kodename47's Avatar
Drives: UK GT86
It just gets very hot.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-15-2016, 01:09 AM   #7577
nmastereal
I understand that. I had the kit in stages. Started with the 210, then bought the upgrade. I think its just worthwhile for us to keep the first post that is pinned updated with statistics because we are reaching the point where these kits have been on cars for a few years and we may see issues.
nmastereal is offline   Reply With Quote
The Following User Says Thank You to nmastereal For This Useful Post:
riboyster (10-15-2016)
Old 10-23-2016, 08:49 PM   #7578
stevo585
Drives: White 2014 BRZ
Originally Posted by moto-mike View Post
no
Just how bad is the heat soak on these non intercooler? My tuner generally doesnt like them for tuning reasons. I have 93 pump and e85 available. On the 70mm would there be an issue?
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 10-23-2016, 08:51 PM   #7579
stevo585
Also anyone managed to get a custom air to air intercooled setup with this? Kits biggest downfall imo. I hear the cooler doesn't work as well as the other PD systems out there.
I have seen this on a mustang before at the track. No sure the brand but def a PD with an air to air cooler.
Old 10-23-2016, 08:54 PM   #7580
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
I don't think i've ever really experienced heat-soak on my non-intercooled. Then again, I'm just daily driving on 93 and only doing pulls every now and then. I live in Indiana where the temperature since purchase has been sub 80 degrees.
I have read almost all of this thread and 72.5mm seems to be the lowest diameter pulley you can run safely on non-intercooled. I am running that now and am happy with it. I wouldn't recommend 70mm. If you are running e85 you may be OK if you live in a cooler climate.
ajcarson11 is offline   Reply With Quote
The Following User Says Thank You to ajcarson11 For This Useful Post:
stevo585 (10-26-2016)
Old 10-24-2016, 04:37 AM   #7581
Kodename47
Kodename47's Avatar
Drives: UK GT86
@Rich196's water pump recently had it's fuse go and saw IATs move from 30C to 60C just cruising. Remember we monitor temps post compressor. I would assume that that would be a good indicator of temps, perhaps a little more as there was still water doing some cooling. How much hotter it would get after repeated pulls I don't know. I know I see roughly +15C on a single pull and seems to stabilize at ~+50C over consecutive runs, like track work. This is in addition to what I would expect at cruising which seems to be +15C over ambient.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-24-2016, 09:59 PM   #7582
riboyster
riboyster's Avatar
That would be quite the feat considering the design of the kit. Most of us aren't mechanical engineers.
Old 10-25-2016, 05:46 AM   #7583
Rich196
Drives: GT86
This is true. Cruising at 70mph in around 15C ambient temps, intakes stabilized at 60C, on a few pulls saw nudging 90C. Bare in mine mine did have a water cooler that was failing to pump so the water that was not flowing and there for probably holding heat and making it less dynamic.
Rich196 is offline   Reply With Quote
Old 10-25-2016, 10:31 AM   #7584
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
If you have e85 then the cooling matters very little since e85 does not have the same knock issues pump gas does. Street use on 93 and the 69 or 70mm is fine, but running on track or repeated pulls will both work much better on ethanol. We ran ours on track several times on e85, and the only issue we had was the sight glass melting when doing repeated sessions with two drivers and barely taking a break... That and the cooked brakes!
[ame="https://www.youtube.com/watch?v=lBSePSRmm3s"]BRZ w/Sprintex 335 Supercharger @ NJMP Thunderbolt - YouTube[/ame]
Xero-Limit is offline   Reply With Quote
The Following 3 Users Say Thank You to Xero-Limit For This Useful Post:
Chrisbrz14 (10-26-2016), riboyster (10-25-2016), stevo585 (10-26-2016)
Old 10-26-2016, 01:44 AM   #7585
riboyster
riboyster's Avatar
This is with no charge cooler, correct?
Old 10-26-2016, 10:25 PM   #7586
stevo585
Noted. Be interesting for you and my tuner (HRI - jamesm) who I'm sure you know, talk about this. He iirc claims you can't tell post cooler temps at all. Making pull to pull very inconsistent. Therefore you have to guess. On the edelbrock, for example, it has a TMAP which he claims is far better. What is your opinion?
Old 10-27-2016, 05:13 AM   #7587
Kodename47
Kodename47's Avatar
Drives: UK GT86
You'd be daft to run a 335 without one IMO. They get very hot.
There are ways to monitor the charge temps, I run a separate IAT sensor in the manifold. It's quite common on the kits here in the UK.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
stevo585 (10-28-2016)
Old 10-27-2016, 05:18 PM   #7588
riboyster
riboyster's Avatar
I'd assumed he was talking about a 210. Of course, I would never suggest a 335 without one. Need all the cooling you can get with that thing.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
