Old 09-22-2016, 10:52 AM   #743
Amputechture
Drives: 2014 BRZ
Originally Posted by BRZ68 View Post
I got my overboosting issue resolved! It turned out to be the hose from the Ebcs to the wastegate melted from the header proximity. Car's running well finally. The only problem left is the reading on my Aem boost gauge seems off.
What vacuum source did you guys use? I put a vacuum manifold connected to the top vacuum source of the intake manifold next to the pcv line for my bov and boost gauge.
I'm going off the brake booster currently. Everyone says purge valve underneath or where you are is the best location for vac source. Can you share a picture please and what type/size fittings you used?
Amputechture is offline   Reply With Quote
Old 09-22-2016, 11:02 AM   #744
Jonathanlim
Drives: 15' Frs
Originally Posted by JDLAutoDesign View Post
I'll give you a call tomorrow and we'll get it sorted one way or another. What's your order/invoice number for the kit so I can pull up all the info.
Thanks!
#1,000
Jonathanlim is offline   Reply With Quote
Old 09-28-2016, 08:54 PM   #745
Amputechture
Drives: 2014 BRZ
What are guys running the 4854 on Flex-Fuel putting down? Anyone know what I could expect going from 10 PSI on 93 to 12/13 (if safe and within efficiency range?) PSI on e85? And would the curve of my powerband change at all, or just increase?
The Following User Says Thank You to Amputechture For This Useful Post:
drambo136 (10-26-2016)
Old 10-20-2016, 08:20 PM   #746
Jonathanlim
Drives: 15' Frs
JDL turbo kit owners thread
Is this normal ? There's oil on my skid plate
Old 10-21-2016, 11:49 PM   #747
SpoochFRS
Drives: Steel FRS
Got my first box of parts today. Cant wait to install woot.
SpoochFRS is offline   Reply With Quote
Old 10-26-2016, 02:26 PM   #748
Amputechture
Drives: 2014 BRZ
Ronnie/Jessie/Lee,
I have the base kit 4854 with a 4 bolt flange. What would it take to upgrade to a GTX2863 or 2867? Or is there a BB Precision that is comparable that I could get out the door cheaper for?
Old 10-26-2016, 03:07 PM   #749
drambo136
drambo136's Avatar
Drives: 2013 Hot Lava
On 12psi and vp e85 we squeezed out just over 400hp but I don't think the dyno was righ
Sent from my SAMSUNG-SM-G930A using Tapatalk
drambo136 is offline   Reply With Quote
The Following User Says Thank You to drambo136 For This Useful Post:
Amputechture (10-26-2016)
Old 10-26-2016, 04:06 PM   #750
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
We've done slightly over 400 here and that's about it. They are rated 385 by PTE and their ratings are typically under rated a bit.
Jesse
JDLAutoDesign is offline   Reply With Quote
Old 10-26-2016, 04:17 PM   #751
Amputechture
Drives: 2014 BRZ
Man, that's promising to hear. Even if it were reading high that still exceeds my expectations for what I would have expected. I am debating between:
-Flex Fuel/550-700cc Injectors or just getting a GTX series and staying on pump.
Old 10-28-2016, 08:16 PM   #752
JDLAutoDesign
Drives: 13 FRS
GTX2867R Dyno
Old 10-28-2016, 08:33 PM   #753
drambo136
drambo136's Avatar
Ya I love it. Pulls good and as long as u have a e85 station near u it's not too bad. I only get like 17 to 20 mpg now tho
Old 10-28-2016, 10:30 PM   #754
Amputechture
Drives: 2014 BRZ
I've resisted the urge and stayed on my 7 PSI map for the past two weeks and averaged 19 on pump gas. No leaks and I'm not tuned all that rich. I dunno.
Old 10-28-2016, 10:31 PM   #755
Amputechture
Drives: 2014 BRZ
Thanks Jesse, do you happen to remember the boost pressure and ethanol content?
Old 10-28-2016, 10:35 PM   #756
nickg
Drives: 2014 Whiteout FR-S Manual
Are you sure you're not running rich or are you going into boost frequently?
Sent from my XT1575 using Tapatalk
nickg is offline   Reply With Quote
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 08:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 07:27 PM
